Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 09-26-2007, 01:39 PM   #26
ScoobyDrooler
Member#: 135420
04 WRX "Casper"
Wingless White
Can anyone find a part number for the stock BCS?
Need the # for an 04 WRX and 04 STi... is it the same?
ScoobyDrooler is offline   Reply With Quote
Old 03-05-2008, 10:57 PM   #27
bulletSTI
Member#: 142184
Do you guys think I should upgrade my stock BCS to Prodrive BCS on an 05 STI when I swap to a TD06 20G next month?
bulletSTI is offline   Reply With Quote
Old 05-14-2008, 07:33 PM   #28
DriftinS14
Member#: 52110
02 DB Monster 16G
06 blk on blk Revo'd A3
Awsome thread Bomber,.. I just changed out my turbo and I couldn't remember which side the pill was on.
DriftinS14 is offline   Reply With Quote
Old 11-17-2008, 02:34 AM   #29
bikergreen
Member#: 192157
04 BMW 325xi Wagon
Grey
Default No ristrictor pill??
I have been reading through all these FAQ lately being a noob and they are GREAT btw!! as i was reading through this one noticed the note on the restrictor pill which I don't seem to have in my boost controll system in my 04 WRX... sooo should I have one? there is a joint in the line between the T and the acctuator but no pill - I don't have a boost gauge yet to tell me whether or not I am getting the right amount of boost - would I be getting less then stock boost with out the pill? I wasn't quite sure after reading it..
Thanks!
bikergreen is offline   Reply With Quote
Old 11-17-2008, 01:25 PM   #30
Cody
Member#: 42048
03 WRX Wagon
Sonic Yellow
Thanks!
Without the pill, everything else stock, your WG will be opening earlier and more than it should. This shouldn't be dangerous, but you'll definitely lose performance and have issues building boost.
http://www.cobbtuning.com/info/?ID=3482
Cody is offline   Reply With Quote
Old 12-06-2008, 07:09 PM   #31
apple14527
Member#: 196773
2008 imprezra wrx
grey
Default i need some help and im new to the site
i bought a new 08 wrx and am pretty happy with it, though i didnt test drive a 09. but i wanted to raise the boost a few pounds and was wondering what kind of boost controller i should get, but in order to raise boost wouldnt you need to get more fuel to it as well? or no? see im new to wrx's and turbo's
apple14527 is offline   Reply With Quote
Old 03-20-2009, 12:07 AM   #32
STiluv55
Member#: 206102
1999 2.5 RS
Originally Posted by Unabomber View Post
ALWAYS take your tuner's advice on these matters no matter what the internet tells you!
wait, im lost the internet told me to listen to my tuner and not the internet?? lol jk, great post!
STiluv55 is offline   Reply With Quote
Old 06-28-2009, 05:04 AM   #33
my76wrx
Member#: 205036
2005 wrx sedan
psm
help~~ today i just installed the manual boost controller and the glowshift boost gauge. the problem is the gauge point to 0 when my engine started (it's not like what i saw some people's gauge they always point to -10) and when i put the gas hard, it just point to 6 psi whatever i turned the controller to both side... is it something wrong for the installation or i missed something important?? can i see some pics for the engine bay if you guys have? plzzzz help me out! >_<
my76wrx is offline   Reply With Quote
Old 06-28-2009, 09:40 AM   #34
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
This is an informational thread, not a troubleshooting thread. Start your own thread after you fill out your profile and post pictures.
Old 12-04-2009, 02:09 AM   #35
soob noob
Member#: 220158
02 bugeye
medamullet tuned
part number for the stock bcs? either im blind or something... thanks
soob noob is offline   Reply With Quote
Old 01-09-2010, 12:02 AM   #36
NorCalSubie07
Member#: 156751
07 LMTD sti #359
is there any way we can see a diagram for a 06 07 wrx? Cause i can't figure out with vacuum line goes to which side on the Solenoid. Its different then the one pictured above.
NorCalSubie07 is offline   Reply With Quote
Old 01-09-2010, 04:30 AM   #37
soob noob
Member#: 220158
02 bugeye
medamullet tuned
does this help? the first one is from the 07 wrx and the second is from the 02 wrx.. i just replaced mine with the 07 and this is how i hooked up my lines and everything is working perfectly
Old 01-09-2010, 03:14 PM   #38
NorCalSubie07
Member#: 156751
07 LMTD sti #359
thanks a lot soob noob, now in line labled "2" is there stiffness in the length of the line? mine seems to have something in it.
Old 01-10-2010, 07:00 PM   #39
soob noob
Member#: 220158
02 bugeye
medamullet tuned
im not sure.. really all i did was unhook my old one and put this one in its place and it works perfectly. i just had to drill a hole in my mounting bracket for my old bcs because i was unable to get the mounting bracket for the 07 one...
Old 01-10-2010, 07:11 PM   #40
XmikeX
Member#: 184768
05 WRX
toasted white
im still kind of unsure about restrictor pills, i read everything and saw about drilling them if you need to...im doing a vf series swap from my td04 can i take the pill out of an sti and put it in my wrx for the right pill size or since the turbo isnt that big will the stock wrx pill work?
thank you
XmikeX is offline   Reply With Quote
Old 01-10-2010, 08:22 PM   #41
NorCalSubie07
Member#: 156751
07 LMTD sti #359
i'm pretty sure that i read that you need to use the sti pill for the vf swap. better be safe then sorry.
Old 01-10-2010, 08:40 PM   #42
soob noob
Member#: 220158
02 bugeye
medamullet tuned
^norcalsubie did what i said make sense?
and yes im pretty sure that you need to use the pill from the STi
Old 01-10-2010, 08:45 PM   #43
XmikeX
Member#: 184768
05 WRX
toasted white
can you order the pill from the dealer? or can a tuner jsut drill it to the right size?
Old 01-10-2010, 08:47 PM   #44
soob noob
Member#: 220158
02 bugeye
medamullet tuned
im sure you could do both..or ask in your local forum. you never know someone near you might have one lying around
Old 01-10-2010, 08:50 PM   #45
XmikeX
Member#: 184768
05 WRX
toasted white
thank you
Old 01-10-2010, 08:55 PM   #46
soob noob
Member#: 220158
02 bugeye
medamullet tuned
np man
Old 01-15-2010, 06:13 PM   #47
not2fast
Member#: 230574
2015 MB C300
Any 08 WRX MBC advice (can we push to 09 levels?)
Thanks
not2fast is offline   Reply With Quote
Old 01-15-2010, 08:29 PM   #48
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks
You didn't read the first post, do so again.
Old 01-16-2010, 09:56 AM   #49
not2fast
Member#: 230574
2015 MB C300
Sorry, I should rephrase,
I understand what the MBC can do (enough PSI to blow the whole car up if I wished :-) ).
I am asking more if anyone has done a moderate boost control setup with verified safe numbers (air/fuel, timing...etc) for the 08 on a stock setup.
Thanks
Old 07-10-2010, 07:54 PM   #50
SonicScooby27
Member#: 154085
2001 2.0 WRS
blueee
i may have missed it, but i just got a manual boost controller...it only has 2 spots, one to the turbo and one to the ewg..now what happens to the spot on the intake where the stock solonoid has a line running to?
SonicScooby27 is offline   Reply With Quote
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 337 11-12-2018 06:55 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 118 12-08-2016 01:24 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 386 09-10-2016 07:42 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 11:03 PM
