Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Old 10-16-2018, 12:20 AM   #1
Cpip333
Member#: 488787
Default P0244 overboost?
I have a 2005 forester xt
Vf39 turbo
STi TMIC w/ sti bov
Accessport v3
Invidia downpipe w/ High flow cat
Catless STi uppipe
AEM fuel pump 320lph
K&N intake
Mishimoto PCV hoses
Mishimoto radiator
GrimmSpeed ebcs
Perrin turbo inlet
Turboxs catback
I was overboosting (blinking cruise and cel) every time in WOT at 110 mph then he did something and now itís at 120. He said the logs look great and he canít do anything on his end. What can I do to get this resolved?
External wastegate??
Port my turbo??
EDIT
Iím the picture you can see my idc drop
Since I have ported iwg and no longer overboosting Iím just experiencing a fuel cut once my tires break loose on launch and I canít seem to find out why Iím still waiting to hear from my tuner
Cpip333 is offline   Reply With Quote
Old 12-01-2018, 05:48 PM   #2
Cpip333
Member#: 488787
Hey guys donít know whatís going on I ported my wastegate I havenít gotten the new map for it but my boost stays at 16 psi so I know Iím not overboosting now but my car still hits fuel cut launching the car and at 120mph (on track) I have some logs showing my issue if anyone will look at them my idc drops from 91% to 3%
Old 12-01-2018, 05:49 PM   #3
Cpip333
Member#: 488787
Old 12-01-2018, 05:51 PM   #4
Cpip333
Member#: 488787
Car has been dyno tuned since not getting any cels either
Old 12-01-2018, 05:55 PM   #5
avikm289
Member#: 315748
2017 wrx sti
ice silver metallic
get an ewg, i got it and have'nt had creep since then. you can fabricate a small pipe to route the waste air back into the dp but you may not have the same power levels as dumping it overboard. subaru's are known for boost creep
avikm289 is offline   Reply With Quote
Old 12-01-2018, 05:57 PM   #6
Cpip333
Member#: 488787
Itís not creep my boost stay under 16lbs now after porting my iwg
Old 12-01-2018, 05:58 PM   #7
Cpip333
Member#: 488787
I was overboosting when I posted this thread now Iím just expieriencing fuel cut
Old 12-01-2018, 06:07 PM   #8
avikm289
Member#: 315748
2017 wrx sti
ice silver metallic
you usually get fuel cut when you creep. what size injectors you got? if youre maxing duty cycles on oem injectors that may be an issue. my tuner reccomended idi 1050x's, im running with those and a similar set up making 324whp/332wtq.
Old 12-01-2018, 06:57 PM   #9
Cpip333
Member#: 488787
Iím on stock injectors which I wasnít sure about either but everyone says there plenty for what is done. I realize fuel cut happens when you get boost creep that was my reason behind porting in my logs you can see that Iím not overboosting at all just going through a fuel cut
Old 12-03-2018, 11:10 PM   #10
Cpip333
Member#: 488787
Bump please lmk if you guys have any idea for fuel cut reason
