Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Old 11-13-2018, 11:34 AM   #1
Fars666
Member#: 493987
2012 WRX
Default help spacers WRX
Hi all,
I been struggling for a very long time not knowing what spacers to get for my 2012 WRX hatch. I know that 25mm is the direct bolt on where I don't need to cut my original lugs. however, I don't like the way they look. So I was planning to get something less aggressive - 15 mm and was told that I would need either to cut my original lugs or screw extended ones. I don't really feel like doing either of that. So my question is that will 20 mm spacers will be a direct fit or would I still need to mess with lugs?
Fars666 is offline   Reply With Quote
Old 11-13-2018, 11:52 AM   #2
Loyale93
Newbie Moderator
Member#: 91347
2004 Tacoma Crew Cab
2012 Triumph 1050
Why... Why are you doing spacers??
Loyale93 is offline   Reply With Quote
Old 11-13-2018, 12:02 PM   #3
Fars666
Member#: 493987
2012 WRX
Want more flush look but not too aggressive.
Old 11-13-2018, 12:15 PM   #4
Loyale93
Newbie Moderator
Member#: 91347
2012 Triumph 1050
Change your wheels?
Also, your best bet for confirmation is to look at or get a copy of the installation guide from the manufacturer you're planning on buying from. Especially if you're buying from a company like ISC, those guys are awesome and will be happy to discuss this stuff with you.
Don't go off of "I was told that". That's not a fact. That's a rumor. Work off facts.
Old 11-13-2018, 12:37 PM   #5
Fars666
Member#: 493987
2012 WRX
Change your wheels?
Thanks for a heads up. I'm trying to get the ones of ebay however, the supplier doesn't provide accurate information. Got a replay back from him stating that I may need to cut my original lug set if they would stick out alot. Though I would find someone who already went thru installation process.
Old 11-13-2018, 12:40 PM   #6
Slim_Jim
Member#: 473831
2018 WRX STI Limited
Lapis Blue Pearl
Change your wheels?
^^^^^ This ^^^^^
25mm is quite a bit for each wheel. Definitely look into the installation manuals from each brand before buying....
Slim_Jim is offline   Reply With Quote
Old 11-13-2018, 12:51 PM   #7
Loyale93
Newbie Moderator
Member#: 91347
2012 Triumph 1050
"the ones off ebay". There's the rub.
eBay is not a brand. So we don't know what actual product you're planning on buying.
eBay is also not a reliable source for things that are literally the FOUNDATION of your car.
Don't skimp out. Go buy from a reputable shop. Ask that supplier what you need to do for installation.
If you're asking these seemingly simple Questions, you really shouldn't be putting any amount of trust into an eBay seller.
https://www.boredpanda.com/funny-online-shopping-fails/
Old 11-15-2018, 12:56 AM   #8
Fars666
Member#: 493987
2012 WRX
You are not helping guys.. Anyone installed 20mm spacers on this forum that can share some info.. I have installed spacers on multiple vehicles just got this subi as a weekend car. My primary is a bimmer. Spacers is no fatal mod. I guess ill try it out and post my results on here.
Old 11-15-2018, 08:38 AM   #9
Loyale93
Newbie Moderator
Member#: 91347
2012 Triumph 1050
We are helping. You just don't like the answers we're giving.
Why are you going with eBay? Because they're cheaper?
Look at the VALUE you get by buying a reputable brand/vendor. You get expertise and actual answers. Spend the extra $20 and make sure it all works. don't be a cheapskate.
Old 11-15-2018, 09:33 AM   #10
LedDriver
Member#: 451791
2015 WRX
Dark Gray
Wheel spacers work great till your wheel passes you on the freeway...
Get wheels with the offset you're looking for. If you insist on spacers buy a quality set from a reputable brand and follow their instructions.
LedDriver is offline   Reply With Quote
Old 11-15-2018, 10:17 AM   #11
Jack
Add Lightness
Member#: 13699
not my president
(From General)
At the thickness you're talking, I believe you're talking about "adapter" type spacers. Like this:
Not this:
I used the first example years ago to change bolt patterns on a Wrangler to accept some wheels and brand new snows that came off an explorer. Some issues:
The studs and lugnuts were a different thread pattern from my Jeep. So I needed to buy another set of lugnuts to bolt the adapters to the hubs of the Jeep. I then needed to use a different set of lugnuts to bolt the wheels to the adapters because the old school open lugnuts wouldn't fit the alloys.
Once in place, as with any new wheel installation, I want to retorque the nuts after about 100 miles of driving. This required removal of the wheels and retorquing the adapter nuts to the hub. Then, of course, re-install the wheels.
Most adapters are NOT hub centric. So there is some chance that you're going to introduce some off centered wobble with both the adapter to hub and adapter to wheel connections. This can become near impossible to find. With a Wrangler, it's not as bad because the sidewall is huge and the width of my tires was pretty wide so the cushion of the tires helped me.
In short (too late, right?) you're cheaping out and will pay for it in headache. Don't say I didn't warn you. Buy proper wheels with the offset you're looking for.
Old 11-15-2018, 11:02 AM   #12
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
And even though, OP, we shouldn't need to remind you, get wheels that are hub centric.
SirBrass is offline   Reply With Quote
Old 11-15-2018, 08:03 PM   #13
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Most aftermarket wheels (including the stock wheels actually) are lug-centric by design. You can tell by the type of nuts used. Our wheels use tapered lugs that center the wheel while its torqued down. You can remove centering rings on lug-centric wheels and they will work fine unless garbage wheels.
Unless its for a Euro car (OZ wheels, etc) that runs ball type lugs, I've not seen true hubcentric aftermarket wheels for j-cars. Sure they come with centering rings but those are used mainly to aid in centering the wheels to the hub when mounting. It's not there to take on the weight of the car like true hub-centric wheels.
Hub-centric wheels primarily use washer type and ball type lugs. Anyway just for your info.
oichan is offline   Reply With Quote
Old 11-15-2018, 11:30 PM   #14
wrx43v3r
Member#: 331119
spacers = ricers. you would be better off with a Civic.
wrx43v3r is offline   Reply With Quote
Old 11-16-2018, 01:23 AM   #15
Fars666
Member#: 493987
2012 WRX
Not this:
Yes that's it adapter type spacers sorry I should have mentioned it earlier. In theory all 20 mm adapters are the same. The thikness and original lug size are two main factors here. I also noticed there some extra cavities in the back of oem wheels what in my believe would help with proper fitment. And after all I do appreciate all recent replies except the civic part.
Old 11-19-2018, 02:40 PM   #16
cerbomark
Member#: 475983
2018 WRX Limited
https://forums.nasioc.com/forums/sho...hlight=spacers
20mm spacers. If you install them correctly you won t have a problem. I ve had them on my WRX and have spacers on my Porsche Panamera also, no issues if you keep it mild.
cerbomark is offline   Reply With Quote
Old 11-23-2018, 11:26 AM   #17
pmanliu
Member#: 361107
2017 WRX
I'm guessing you're going to get bolt on spacers so make sure that the back hub of your wheel has 'cutouts' in case there are any threads from the OEM lugs sticking out after installing the spacers.
Also quality matters. I tend to stick to Perrin or H&R Spacers (read somewhere Perrin is rebranded H&R). Never tried ebay ones nor do i want to... but have used Ichiba and ISC and the quality is no where near as good as the Perrin/H&R spacers.
pmanliu is offline   Reply With Quote
Old 11-25-2018, 09:09 PM   #18
BLACK GIZMO
Member#: 493976
I have 20 mm spacers on my car with coils they are not rice. I race my car on the track gives me a wider stance. Def big difference.
BLACK GIZMO is offline   Reply With Quote
Old 11-25-2018, 09:14 PM   #19
BLACK GIZMO
Member#: 493976
Not trying to be a dick but the way the stock wheels stick in on the wrx is horrible. I bought 2,500 dollar coils. 20mm Perrin spacers. Sway bars. And the wheel alignment cost 250 for track not bragging about money spacers are not rice. If done write.
Old 11-25-2018, 09:16 PM   #20
BLACK GIZMO
Member#: 493976
Have to learn before you say stuff that people are going to read.
Old 11-25-2018, 09:25 PM   #21
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Are you sure those are legal with whoever you track with? I ask because the club I raced with for 25 years and instructed with for a dozen would not allow those. This is COM Sports Car Club who has been doing track events since the 50's. Section 8 if you want to look it up.
Old 11-26-2018, 06:49 PM   #22
thatdamnalex
Member#: 441196
2016 sti
If done write.
thatdamnalex is offline   Reply With Quote
Old 11-27-2018, 09:19 AM   #23
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
If you need that much offset, get different wheels.
Now, if your expensive racing wheels need extra offset that just isn't provided, maybe its not a terrible idea, especially if you get quality.
However, spacers to make the stock base wheels stick out? Just get different wheels!
I went with +45 offset wheels for my winter setup, and they look fantastic on the WRX. Pushes the wheels out just enough.
I'm considering ditching the OEM 18s after next winter (going to drive on them at least one summer. Might as well use up the OEM tires first), and getting similarly offset 18's... or going full baller and getting STI BBSs (though maybe a Mach V wicked awesome wheel would be better, who knows. I've got lots of time to change my mind repeatedly).
Thing is, you've got lots of wheel choices. Use those, not spacers.
Old 11-27-2018, 01:14 PM   #24
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
You don't want to spend a few extra bucks on proper studs for your setup? Smh.
Do your own math then. Get the stud specs (or measure them yourself, get the factory lug seat depth on your rims, then do the math adding 10, 20, or 25 mm of spacing.
bdubblu is offline   Reply With Quote
Old 11-27-2018, 05:02 PM   #25
fuelMuncher
Member#: 301554
2002 WRX Wagon
PSM, 2007 OBP WRX Limited
How much extra is doing ARP studs and install? I was quoted $600 for installation-is that nuts? I passed after buying them and hearing what the shop wanted to put them in.
fuelMuncher is offline   Reply With Quote
