Welcome to the North American Subaru Impreza Owners Club Thursday December 13, 2018
Old 11-28-2018, 01:37 AM   #1
welding rod
Member#: 116108
Default 2019 WRX or STI? My Take
Just got rid of my 2019 WRX that was just under a month old and just under 6,000 miles. Picked up a 2019 STI. First time I have ever done anything so financially reckless but at my age, after having seen almost all of my family go into the ground, I decided to go for it after essentially finding I was not satisfied with the WRX driving experience when I was pushing the car.
I debated hard about just waiting for the new STI to be released, but over the years I have found I am generally a lot happier with something that is towards the end of its development cycle and that has had its bugs worked out, even if it is not as advanced. My gamble is that whatever the STI offers in the next generation will be plagued for at least a couple of years with some newly surfacing annoyances or problems.
WRX (base model) +'s:
*Handles and grips great on asphalt, including wet and leafy asphalt
*Great gas mileage - about 31-35 MPG on car's computer for long trips.
*Excellent, strong and smooth torque from 2,500 - 4,000 RPM
*Feels light and agile
*Excellent suspension setup compromise for a daily driver
*Excellent headlight illumination (base model)
*Smooth engine
*Low sensation of speed, cuts wind effortlessly
*Smallest wheels in current WRX family (I don't like big wheels as they bend too easily)
*Strong brakes that took a fast trip down 9 Mile Canyon in CA without issue
*Seems to be a good value for a daily driver
WRX -'s:
*Dip in power deliver about 4,500 RPM was very annoying
*Low ground clearance (same for STI of course)
*Brake locking action to control wheel spin on dirt road or snow, or when a tire is off the ground, feels like a 1st generation attempt (honestly I was expecting more from THE AWD car manufacturer)
*Grabby clutch (and fair bit of force required to actuate)
*Hyper sensitive throttle, and the "rev hang"
*The last two lines above combine to make the WRX the hardest car to drive smoothly that I have ever driven from a stop up to 3rd gear - requires an undue amount of mental attention
1st impression of new STI (base model) after about 150 miles including my favorite cold wet paved bumpy hilly and twisty forrest road:
*Ridiculous grip on wet asphalt
*Lower effort and smoother clutch engagement action than WRX
*Smoother throttle mapping (all 3 modes) than WRX
*STI LED Headlights not quite as bright as WRX, but the cornering function makes them still preferable - that cornering function is a HUGE asset on tight twisty roads! Really brilliant.
*Drinking gas like crazy, though my WRX was somewhat thirsty too until it has a little mileage on it.
*Gear box shifting is a little less effort and more positive than WRX (both have Short shifter)
*Leather trimmed seats, like the WRX cloth seats, lack adequate lumbar support
*"Triple gauge" lacks oil temperature gauge capability that WRX had
*Suspension feels very similar to WRX when at speed, and a little rougher at slow speed
*Feels like there is more unsprung weight on STI, WRX feels a little lighter on its feet
*STI sounds better in the Burger King drive through
This is just based on first impression on STI. I may update later after trying it on dirt and at higher RPM / loads if anyone seems interested.
welding rod is offline   Reply With Quote
Old 11-28-2018, 01:45 AM   #2
kenef
Member#: 493122
2019 WRX
Both are rally inspired 'race' cars, with the STI being more aggressive. It is what one would expect. I was deciding between both and went with a WRX.
What is it that you want, more power? Have you been in a car with a more aggressive seating position? That might help fuel your craving...
kenef is offline   Reply With Quote
Old 11-28-2018, 02:03 AM   #3
welding rod
Member#: 116108
Actually I found the power of the WRX adequate. More is always welcome, but the power output didn't play into my decision to axe it. My spirited driving interest is in the corners, not the straights so I think the peak power output of the WRX is pretty good. The DELIVERY of the WRX power definitely played into the decision though.
Old 11-28-2018, 09:59 AM   #4
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
I thought about an STi but I can't justify the engine being so old and thirsty.
jasonwrx86 is offline   Reply With Quote
Old 11-28-2018, 10:06 AM   #5
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
It isn't so bad with a protune and with a good protune + DP, you should be seeing gas efficiency much closer to the WRX's (with a combined probably around 23mpg, which in my mind is just fine for a performance car over 300 bhp). And the design is older, not "old", nor would a new one have "old engine" issues. It's a very well understood block, which is a good thing.
SirBrass is online now   Reply With Quote
Old 11-28-2018, 10:41 AM   #6
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Both are fine cars.
The STi is a bargain against an RA or a GT-R.
The WRX in base form is a huge bargain against an STi Limited.
Anyone can find problems with any car. I personally don't like the mirror shape on the Pagani Huayra.
Old 11-28-2018, 12:00 PM   #7
anarekist
Member#: 468117
2017 WRX
DMG
thanks for your review op, in your opinion do you think the sti upgrade is worth the money? have you ever driven a modified wrx in comparison?
anarekist is offline   Reply With Quote
Old 11-30-2018, 12:47 AM   #8
yusuke280
Member#: 494659
2006 WRX STI
i would definitely go for a STI... its like buying a non-M or non-AMG car in that sense
yusuke280 is offline   Reply With Quote
Old 11-30-2018, 01:13 AM   #9
Underboosted
Member#: 100760
2018 STI
Well put! That's the way I viewed it too. I can't understand why anybody would by a WRX for "gas mileage," as though brakes, suspension, interior, engine and all around performance are just worthless?
Underboosted is offline   Reply With Quote
Old 11-30-2018, 01:38 AM   #10
transmutation
Member#: 467769
2018 STI Limited
The question of whether an STI is worth the premium over a WRX is, in my opinion, a personal choice. Its already been shown that to get the same hardware upgrades for the WRX that the STI has by default its cheaper to just get the STI. Mod for mod though varies depending on what is important to you.
transmutation is offline   Reply With Quote
Old 11-30-2018, 09:01 AM   #11
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Don't forget the insurance premium hike of an STI over a WRX, too.
When I got my first WRX in 09, it wasn't too much more to insure than my Forester. When I got my STI in '13, it was a gut-punching insurance premium increase for the same coverage for the STI over the WRX.
And when we sold the Malibu and got the WRX, it was a negligible insurance increase going from that Malibu to the WRX.
So, factor in the premium increase (which in my case was nearly $80/mo increase) when factoring in cost of the car.
Other than that, yeah, definitely a personal decision. But depending on what you want and/or need, both are excellent choices.
Old 11-30-2018, 08:52 PM   #12
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Regarding "low ground clearance", I measured that my STI is a good 10mm+ lower ride height vs my WRX.
oichan is offline   Reply With Quote
Old 12-01-2018, 01:55 AM   #13
Abismo
Member#: 99707
2018 WRX Premium CWP
If i could have afforded an STi I would have gotten it.
however. my wrx is averaging almost 28mpg on my commute into work.
both are good cars there really isnt a bad choice. just depends on what you want.
Abismo is offline   Reply With Quote
Old 12-01-2018, 02:26 AM   #14
GlarryHoodDIT
Member#: 460907
2016 WRX
Goodness an entire centimeter. Must really aid downforce.
GlarryHoodDIT is offline   Reply With Quote
Old 12-01-2018, 09:55 AM   #15
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Downforce? The OP was concerned about ground clearance and coincidentally I had measured my cars a couple of weeks ago so just posted my findings.
You have a good day.
Old 12-01-2018, 02:53 PM   #16
GlarryHoodDIT
Member#: 460907
2016 WRX
Not sure why you're getting so defensive, I'm not holding you responsible for Subarus manufacturing.
It's a joke not a dick, no need to take it so hard.
Old 12-01-2018, 03:39 PM   #17
anarekist
Member#: 468117
2017 WRX
DMG
I agree it is cheaper to just get an sti if you're trying to achieve parity between the wrx and sti, but I was asking the op if he ever driven a modified wrx because alot of his cons are remedied ( my opinion) with an ots tune (pro tune is bettter) and simple modifications to the shifter+ transmission.
The drive train swap is the most expensive part of that effort. Wrx to STI is about a 10k price difference. I calculated aprox 8k to get same brakes and more power than the sti.
But yeah there just to many variables in parts and prices to get a definitive answer.
Old 12-01-2018, 07:16 PM   #18
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Sure, take it easy. Enjoy your evening.
Old 12-01-2018, 07:20 PM   #19
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
OP - the 4500RPM dip as you described was really annoying for me too when my WRX was completely stock. While AP did take care most of that on my car, Subaru should've made a better map when they did the 18+ refresh. Even with AP (Stage1+) the part throttle is no where near as linear as my STI with AP (Stage1). As you said, the STI is much easier to drive smoothly with consistency.
Old 12-01-2018, 07:32 PM   #20
Straight6
Member#: 419593
Did anyone ever confirm why that dip is there ? I am thinking either emissions or not to step on the toes of the STI. ANY stage 1 tune completely eliminates it so it is a tuning issue rather something that has to do with the engine design. I absolutely hated it, that along with the horrible rev hang and super sensitive throttle made me get a tune. Coming from a TSI EA888 engine (which felt so much more smooth in comparison) I cannot believe they release these cars like this.
Straight6 is offline   Reply With Quote
Old 12-01-2018, 11:08 PM   #21
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Yeah, emissions, mpg, and needing to run the engine 87-93 octane most likely.
Old 12-01-2018, 11:25 PM   #22
welding rod
Member#: 116108
Hmm, weird, my premium increase for SIX months was about 80 bucks for the STI over the WRX.
Old 12-01-2018, 11:33 PM   #23
welding rod
Member#: 116108
I have not driven a modified WRX. But, I definitely think the STI is worth the extra money, at least if you want to leave the cars basically stock. I spent some time on logging roads today and the limited slip differentials in both ends of the STI are fantastic compared to the WRX that always seemed behind or wrong in guessing how to try to electronically manage traction on dirt / gravel. And I just can't get over the better drivability of the STI. It is night and day. Shifting is better, clutch is worlds better, and electronic engine management is better.
Old 12-01-2018, 11:37 PM   #24
welding rod
Member#: 116108
Thanks for info. Yeah, way too low. I was bombing some main line logging roads today and was pleasantly surprised how well the STI managed washboards. I wouldn't think of taking it off the main lines though as the crown of the secondary roads can get the car close to scraping even before allowing for the odd rock or whatever between the wheel tracks.
Old 12-02-2018, 12:48 AM   #25
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Yeah, I agree 100%. The STI is better than the WRX in every way except for comfort. But I still love my WRX in a different way. It's funny how different these two cars are even though they look similar.
PS: no problem on the ride height.
