Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 12-02-2018, 07:32 PM   #1
GosuWRX
Member#: 494095
2014 WRX Hatch
Satin White pearl
Default Water leak whenever turning AC on (passenger side)
Hey guys, so I bought my first Subie (2014 WRX Hatchback) about a month ago. However, what I've been noticing is a leak whenever the AC is turned on, this leak varies but recently I've been starting to notice it get a little worse. From where the red box is, there is a wire hanging out of the area where a screw is missing and the head of the cable is brown. Can anyone give me guidance as to what this is? It seems like the previous owner just chopped up a bunch of things on the passenger side.
GosuWRX is offline   Reply With Quote
Old 12-02-2018, 09:26 PM   #2
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
I don't know the answer to your question, but have you checked whether the drain hose for the evaporator under the car is blocked or not?
oichan is offline   Reply With Quote
Old 12-02-2018, 10:01 PM   #3
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Drain hose is clogged. Do you see water dripping under the car?
jasonwrx86 is offline   Reply With Quote
Old 12-02-2018, 10:35 PM   #4
GosuWRX
Member#: 494095
2014 WRX Hatch
Satin White pearl
I do not see water dripping under the car, maybe slight. How would I go about unclogging it? Also the panel where the water seems to be coming from has a wire with the brown head coming out of it
Old 12-03-2018, 08:52 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Agreed, hose is clogged. It is likely the hose just below your red box.
Pull the hose off, blow through it, poke a wire down through it, whatever.
Also, check where it comes through the firewall, sorta common for the turbo cars to melt the hose closed.
Old 12-03-2018, 10:10 PM   #6
GosuWRX
Member#: 494095
2014 WRX Hatch
Satin White pearl
So I gave it a shot, and the leak is coming out of the box itself. The leak is where the wire is coming out of. It seems to be missing a screw and it's open. Any thoughts on that?
Also, water is coming out of the car so the pipe isn't clogged, I did blow air through it just incase though.
