Welcome to the North American Subaru Impreza Owners Club Thursday February 20, 2020
Old 02-13-2020, 03:36 PM   #3676
Zabnorg
Member#: 511126
2003 Impreza Outback
silver and gold
Originally Posted by Kito818 View Post
Go for it! Keep us up to date, if you want to save some money and do your own wiring I can share the pinout for the two connectors on the back of the engine, though I encourage you to check it against your motor, since you wont have the AVLS(or is it the AVCS?) and that may change the pin outs in the plugs. Good luck, and I look forward to some nice pictures!
https://www.subaruoutback.org/thread...utback.517305/
see above link for gory details.
No AVC/LS on this lump, all mechanical with the alu intake.
I'd love to see pinouts for lolz but I'm going to leave this harness in better hands than mine for the electrical. I need my brainpower for other stuff. Also, iWire has a warranty on their work, so no headaches...
Zabnorg is offline   Reply With Quote
Old 02-14-2020, 12:57 AM   #3677
Kito818
Member#: 480045
2009 3.0R Impreza
Dark grey/light black?
I just realized you're trying to swap the ECUs instead of going stand alone. Thats why you were talking about the auto AC feature. That confused me, for far longer than it should have lol. If thats the case my wiring list isn't going to do you any good anyway, as I would only have something short of half of what you need. Some questions though, is the bug eye drive-by-wire, or a cable driven throttle body?
Kito818 is offline   Reply With Quote
Old 02-14-2020, 08:51 AM   #3678
Zabnorg
Member#: 511126
silver and gold
I need the car to pass emissions as this is my daily driver. It's the older EZ30D with cable throttle and cruise control, which matches the cable setup on the bugeye, although the routing and positioning of the cruise control actuator are different. I'd like the setup to be same as stock in terms of creature comforts, so I'd like to have working and AC and cruise when I'm done. I've pulled the whole clutch off of the donor car's AC compressor to see if they will swap but I haven't checked the fit yet. When I grab the motor from the junkyard I will have another compressor to play with.
Old 02-14-2020, 04:58 PM   #3679
Zabnorg
Member#: 511126
silver and gold
Originally Posted by Patrick Olsen View Post
However, that doesn't address the issue addressed in the 2nd post I've linked above. Because of the shape of the EZ30's intake manifold, the A/C line has to come forward to clear; your stock Forester line probably doesn't do that. So even if you're able to fit your original compressor, you're most likely going to have to do something custom to fit the lines.
Note that my car has still never been completed, so I have no idea if the A/C works, but I don't see any reason why it won't when that time comes.
Dood, when u gonna get that thing on the road? From what I've read, it's spent the better part of the last decade sitting in yer garage!
Old 02-14-2020, 06:11 PM   #3680
Kito818
Member#: 480045
2009 3.0R Impreza
It's time for the 6spd! Finally got the STI differential front companion flange to install on the differential so that the stock STI driveshaft can be used without having to use a hybrid U-joint. So it's FINALLY time for this 6spd to be installed, after a year of driving on the engine swap.
Old 02-15-2020, 12:48 AM   #3681
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Some day. Hopefully in the coming months, but I've said that many times over the past few years.
Old 02-16-2020, 05:50 PM   #3682
Kito818
Member#: 480045
2009 3.0R Impreza
6spd is in and working, bleeding the clutch system was backwards, but I'm now running a complete 05 JDM Legacy spec.b drivetrain, minus the driveshaft from a 14 STI.
Vag-Com cable resource thread cooleys04 Open Source Reflashes 283 04-03-2018 02:04 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 05:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-20-2007 12:36 AM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-17-2005 12:11 AM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 06:04 PM
