Welcome to the North American Subaru Impreza Owners Club Saturday July 20, 2019
Old 07-10-2019, 05:20 PM   #1
Kenword
Member#: 504011
Outback Sport What color is Subaru coolant?
Hi all, I recently bought my first Subaru ever, a '99 Impreza Outback Sport. I've been checking it over carefully as I have no maintenance records. I noticed the coolant was not the bright green color I expected so I decided to change it. When drained it out I was shocked to see it was kind of an amber color, closer to the color of new engine oil than the shades of green I've always seen before. To my relief, all the cooling passages seem to be surprisingly clean and corrosion free.
Last night I was reading through some old End Wrench articles posted on SCOOBY enthusiast and read that Subaru anti-freeze has a unique formula which makes it quite a bit different from the standard anti-freeze I have used before. While I learned quite about coolant, I don't remember any mention of what color it should be. Since GM makes it's unique long life formula red I wondered if Subaru uses a unique color as well.
Kenword is offline   Reply With Quote
Old 07-10-2019, 05:26 PM   #2
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
I know my 2018 is blue ish green.
jasonwrx86 is offline   Reply With Quote
Old 07-10-2019, 06:43 PM   #3
crick0234
Member#: 319696
2012 Subaru WRX STI
i'm gonna assume its the subaru blue coolant, which is an HOAT coolant? wonder if u gotta use the subaru longlife green coolant if that's still available?
the greenstuff that autozone and oreilly's marks as "Universal" was actually something similiar to DexCool... even tho it says its safe, i shoved that green stuff into my car and with in 10K miles, massive precipitation from it , brown gunk everywhere. Flushed my car and went back to HOAT coolant (subaru long life).
Something about our engine blocks and how its grounded causes it it to precipitate a bunch (electrolysis). last time i used that over the counter stuff.
crick0234 is offline   Reply With Quote
Old 07-10-2019, 08:48 PM   #4
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
Subaru switched to the "Super Coolant" around 2008- it's teal in color, and comes pre-mixed.
The old "long Life" coolant is green, and it comes as a concentrate. It is very much still available.
CaptainSlowbaru is offline   Reply With Quote
Old 07-11-2019, 03:50 PM   #5
curiousfish
Member#: 89283
2017 WRX Premium
ISM
yup! and only some late 2008 vehicles came with the blue.
curiousfish is offline   Reply With Quote
Old 07-11-2019, 04:36 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
When in doubt, use a "universal" coolant from any parts place.
To be totally sure....drain coolant...refill with distilled water (or filtered water from your house dehumidifier......as I have done for decades....), run a few weeks, drain, fill, repeat.
Then, use a correct coolant (for aluminum engines) and distilled water mix to make things right.
Old 07-12-2019, 12:34 AM   #7
CRSPlayer
Member#: 504161
Default Why blue?
Along with Honda why dye blue? So American motors go orange or red when use to be green?
CRSPlayer is offline   Reply With Quote
Old 07-12-2019, 01:35 AM   #8
LKN624
Member#: 496900
2006 WRX STI Limited
Obisidian Black Peal
Here in Europe, at least in Germany for my 2006 STI Limited...from I think 2001 until 2006 Subaru uses a Pinkish Red. Weird I know as I am used to seeing the Dark Green or Teal. Guess different markets have different colored fluid.
LKN624 is offline   Reply With Quote
Old 07-18-2019, 01:57 PM   #9
AWxGD7
Member#: 502539
2005 Impreza WRX STi
Alpine White
id stick with OEM blue or green coolant, but i heard if you have blue coolant in your car. you shouldn't mix green in. if you want to be on the safe side just get a coolant flush with blue and stick to it.
AWxGD7 is offline   Reply With Quote
Old 07-18-2019, 02:53 PM   #10
curiousfish
Member#: 89283
2017 WRX Premium
ISM
I have an old email from Subaru stating just that. Not backwards compatible.
Old 07-18-2019, 04:28 PM   #11
mishapopa
Member#: 393629
newer subarus use blue
older subarus use green
a 99 would use the green stuff
mishapopa is offline   Reply With Quote
