Welcome to the North American Subaru Impreza Owners Club Monday August 19, 2019
Old 08-13-2019, 12:12 AM   #1
pyraxv
Member#: 493972
2002 built wrx/sti
grey
Default Scratched Crank Help
So i was doing the pesky rear main seal and i ended up scratching my crank. What should i do? i just rebuild the engine so i really donít want to have to do it again. had to redo rear main because i did it wrong. Is it possible to just send it? Maybe push it farther back behind the scratch? Thanks.
pyraxv is offline   Reply With Quote
Old 08-13-2019, 02:20 AM   #2
pyraxv
Member#: 493972
2002 built wrx/sti
grey
so i did also see something called a speedi sleeve for the crank. Does anyone know which size i need to get for a 2.5L crank?
Old 08-13-2019, 07:01 AM   #3
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
We use Speedi Sleeve on a few areas on helicopters and they work great. Same type of seal (garloc). If they make the right size go for it.
ROTORCRAFT230 is offline   Reply With Quote
Old 08-13-2019, 03:09 PM   #4
pyraxv
Member#: 493972
2002 built wrx/sti
grey
im not too sure which size i need or how to measure it. i have a micrometer so ill try and measure the precise outter diameter
Old 08-13-2019, 07:05 PM   #5
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
Measure the dia of the crank and the width. The sleeve is only Iíve never measured it but guessing .015-.020Ē. Thick.
Old 08-14-2019, 07:31 AM   #6
bp05obxt
Member#: 459799
I am not sure how this will work but if it works on helicopters then a Speedi sleeve may do the trick. Only thing I would add is that ASF Machine makes a rear main install tool to make life easy pressing the new one in; may come in handy. One of the best tools I have ever bought.
bp05obxt is offline   Reply With Quote
Old 08-14-2019, 12:04 PM   #7
pyraxv
Member#: 493972
2002 built wrx/sti
grey
i actually just bought one lol it comes in today
