Welcome to the North American Subaru Impreza Owners Club Friday September 17, 2021
Old 04-01-2014, 11:53 AM   #1
th283819
Member#: 295063
2011 Stg 2 WRX Hatch
Default 08+ STi Rear Sway Bar Size (Comparing stock '08/'09 to '10+)
I am trying to confirm my research on 08+ STi rear sway bar sizes.
From what I have gathered,
the '08 and '09 STi rear sway bar size is 18mm,
and the '10+ STi rear sway bar size is 19mm.
Can someone confirm this? I havn't found a clear source from someone who has measured both. I know the 19mm from the '10+ STi is a cheap upgrade for the WRX, and I have an opportunity to pick up the rear sway bar from a 2008 STi for basically nothing, but was trying to research my options and determine whether the cost difference was worth trying to find something from a '10+ vs. basically getting something free from a 2008 STi.
Also, I know the difference is minor but noticeable for the upgrade from the stock 16mm rear wrx sway bar to the stock 19mm rear STi sway bar. But would the 18mm be that much different from the 19mm?
Looking for some clarification and if anyone has any experience with the above upgrade. I know most will say just upgrade to aftermarket and go 24mm/22mm f/r, but I don't really have the funds for that at the moment. So if i could upgrade the rear for basically nothing, I might do it.
Thanks
Last edited by th283819; 04-01-2014 at 02:43 PM. Reason: Clarification of Title (don't want people to think I'm asking "which aftermarket size do I choose")
th283819 is offline   Reply With Quote
Old 04-01-2014, 04:12 PM   #2
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
you have the sizing and year differences correct.
http://www.subarugenuineparts.com/pr...oducts_id=1518
http://www.subarugenuineparts.com/pr...oducts_id=1690
i recently swapped my wife's 2012 impreza sport's 16mm rear sway bar with the 19mm STi one. while it made a nice improvement, i was quite underwhelmed.
if you're getting the 18mm one for free, why not, but it's not going to blow your socks off.
isotopesope is offline   Reply With Quote
Old 04-01-2014, 08:37 PM   #3
jaboyd
Member#: 247304
2011 STI
WR Blue
STI OEM bars
2008 - 2009, front 20mm, rear 18
2010 SE, front 20, rear 19
2011 -14, front 21, rear 19
STI Oem springs
2008-2009, front 217 #in, rear 194 #/in
2010 SE, front 251 #/in, rear 249 3/in
2011- 14, front 251 #/in, rear 297 #/in
jaboyd is offline   Reply With Quote
Old 04-01-2014, 09:08 PM   #4
th283819
Member#: 295063
Thank you both.
Yeah I can get the 18mm for free so I might as well spend the half an hour installing it and see what happens.
Again. Thank you for the confirmation of the info.
Old 04-02-2014, 11:29 PM   #5
Slasenger
Member#: 382731
2012 WRX
Rally Blue
If you really want a difference, get new 24 mm in front, 22 in back, and new end links. I take my wrx on the track and it made a world of difference around the corners.
Slasenger is offline   Reply With Quote
Old 04-03-2014, 05:58 AM   #6
th283819
Member#: 295063
Thats the plan. I just don't have the money for it right now.
Old 04-03-2014, 12:22 PM   #7
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
Originally Posted by jaboyd View Post
STI OEM bars
STI Oem springs
thanks for this! didn't realize 2010 SE STi's have unique spring rates. do you know when the shorter rear springs started? was that in 2010 or 2011?
Old 04-03-2014, 12:58 PM   #8
jaboyd
Member#: 247304
2011 STI
WR Blue
I believe the 2010 SE was the basis for tweaking and setting the stiffer rear 2011 spring rate and imm larger front bar. Not sure what "shorter" means...not aware of a height change.
Old 04-03-2014, 01:23 PM   #9
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
i believe the ride height is the same, but the rear shocks have a shorter stroke and shorter springs, at least on the 2011+. i know the 08 STi has the same length spring as the WRX though... and *maybe* 09 too, since they share the same spring rate? i always thought 2010 was the same as 08/09... and wondered if they also had the longer spring.
phenryiv1 installed 08 STi rear and 2011 STi front springs and koni's on his widebody 2011 wrx:
http://forums.nasioc.com/forums/show....php?t=2322600
i have 2011 STi springs and Koni's on my 08 wrx. i didn't compare them to my wimpy 08 stock springs, but the rear STi springs are 30mm shorter than some 2012 WRX springs i also had laying around...
i machined some spacers to raise my spring perches about 8mm to accommodate the shorter spring, with very little pre-load. at first, my spacer was 30mm to make up the exact difference and add 3/4" preload (like on a stock WRX), but that made my rear end monster truck high... about 30mm too high.
Old 09-14-2021, 08:26 PM   #10
Speed Assault
Member#: 289598
2008 impreza wrx
The important missing detail here is what Suspension dampening you all have?
You are forgetting that it Depends on your Struts or if using Coilovers also.
my 08 WRX is 20mm Front sway , 15mm Rear . so reading these threads that the rear sway is 18 is not accurate. My wrx bought from Subaru Dealer all stock)
I swapped in a 22mm rear not knowing at the time that its not good to have larger rear but obviously it was a world of difference. I cannot say for sure I I felt anything bad as I soon added a STI LSD rear diff, another HUGE improvement!
Now I have Coilovers they seem to handle the sway as well and I just swapped back the 15mm rear, but on a hard fast turn with dip in the road while turning the rear slid out a bit, but I believe the LSD and the coilovers helped the card more than the rear sway did.
Speed Assault is offline   Reply With Quote
