Welcome to the North American Subaru Impreza Owners Club Tuesday June 25, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Normally Aspirated Powertrain
Old 11-15-2018, 11:53 AM   #1
parkitgary
Member#: 473958
Default Fa20dit what is this noise?
Take a close listen to this video. At about 30 seconds as I switch two lanes over you can hear a high pitched noise. I can reproduce the noise and usually happens at about 4-6k rpm under medium throttle. Is my engine knocking? What should I do?
https://youtu.be/VLT1Th5btXU
parkitgary is offline   Reply With Quote
Old 11-15-2018, 09:44 PM   #2
jcf_dori
Member#: 484219
i can't hear anything
jcf_dori is offline   Reply With Quote
Old 11-16-2018, 05:03 PM   #3
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Sounds like some kind of buzzing.
jasonwrx86 is offline   Reply With Quote
Old 11-17-2018, 04:38 AM   #4
parkitgary
Member#: 473958
Sounds like something is rattling. Itís high pitched and happens only in like 4-6k rpm. I reved my engine in neutral and still heard it. I hear it coming from my left air vent...
Old 11-17-2018, 12:38 PM   #5
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Could it be some kind of loose exhaust shield?
Old 12-04-2018, 01:35 PM   #6
killadawg
Member#: 424203
2016 WRX stg 4 Rally
STI Drivetrain GM
That sounds like knock ;-)... bad gas? also in higher gears at low rpm you put lots of stress on the engine.. downshift, don't go into Neutral (some countries even prohibit that is it is dangerous) my 2 cents.. Here is a great solution on the cheap that works as good or better than the highend versions.. http://tunernerd.com/
Is you car tuned? what mods? etc..
killadawg is offline   Reply With Quote
Old 12-07-2018, 12:40 PM   #7
Prodrive_sti
Member#: 357918
Check the exhaust manifold nuts , either loose or fallen off
Prodrive_sti is offline   Reply With Quote
