Welcome to the North American Subaru Impreza Owners Club Tuesday June 18, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Aristocrat Autosport
Old 10-15-2018, 02:14 PM   #1
NASIOC Storefront Vendor
Vendor Sales Rating: (97)
Member#: 384404
MANY WRX, STI, 997TT
wrb
Default Perrin Performance Turbo Inlet Hose
ARISTOCRAT AUTOSPORT is having a SALE on PERRIN TURBO INLET HOSE for SUBARU WRX/STI.
Improve airflow, increased horsepower, and add style to your engine bay with the proven PERRIN Turbo Inlet Hose for your Turbo. Silicone technology allows us to design a turbo inlet hose that is better in all aspects than the OEM part and increases your engines horsepower and performance. The PERRIN Turbo Inlet Hose is perfectly smooth on the inside and has a significantly larger internal diameter than the OEM part. The increased air flow by removing the pleats found in the OEM hose makes more horsepower, decreases turbo spool time, improves acceleration, and increases throttle response.
CORE SPECS
Inner Diameter 2.4
Hose Material Silicone
Internal Support Stainless steel wire
The PERRIN Turbo Inlet Hose is perfectly smooth on the inside and has a significantly larger internal diameter than the OEM part. The increased airflow by removing the pleats found in the OEM hose makes more horsepower, decreases turbo spool time, and improves acceleration.
The PERRIN design has been further improved with the use of a glass filled reinforced nylon coupler, allowing for an even smoother transition from intake to turbo inlet hose while also maintaining rigidity and strength.
The PERRIN Turbo Inlet Hose is the only turbo inlet hose on the market to include an OEM-like connector that does not require defeating the emission control device.
The PERRIN Turbo Inlet Hose is reinforced with a stainless steel support wire that is embedded within the silicone layers. The support adds rigidity to the hose and prevents collapse when used with restrictive filter elements and large turbo applications running extreme amounts of boost.
PM with your ZIP CODE & MODEL/YEAR for an accurate quote!
Facebook:https://www.facebook.com/AristocratAutosport
Instagram:https://www.instagram.com/aristocrat_autosport/
Website:www.AristocratAutosport.com
CALL OR TEXT: 714-340-6596
Email/Paypal:[email protected]
Aristocrat Autosport is offline   Reply With Quote
Old 03-04-2019, 07:50 PM   #2
VinnieT8
Member#: 392323
Hey guys, Fellow Subie owner and Youtuber here, I make videos on all kinds of things about my 2006 Subaru WRX. Just posting this here to help out the community. Check out my Youtube page, https://www.youtube.com/user/VinnieT8
And For an Turbo Inlet Hose Install on my 2006 WRX and (for most subaru's) Check out this video.
Hope this helps!
VinnieT8 is offline   Reply With Quote
