Welcome to the North American Subaru Impreza Owners Club Monday June 17, 2019
Old 05-18-2019, 11:07 PM   #1
journey
Member#: 74555
2006 WRX Wagon-Stg 3
San Remo Red
Default Use left caliper on right side?? 2006 WRX 4-pot
I have a 2006 WRX limited with the 4-pot front brakes. The driver side caliper was sticking, so I ordered two replacement calipers to replace both at the same time -- of course, I ordered two left / driver side calipers.
Can I use the driver side caliper on the right / passenger side? I understand that the bleeder valve would be in the wrong location (i.e., on bottom of caliper rather than the top). I could bleed the caliper before before mounting it -- I would invert it and used my brake spreader tool (or a block of wood) to keep the pads separated. Once the air was out of the lines, I would mount the caliper.
Any idea if this would work? If not, I will be shipping the caliper back...
journey is offline   Reply With Quote
Old 05-19-2019, 11:47 AM   #2
MrPhiscal
Member#: 47843
Ship it back imho the point of a bleeding to to get air out with the bleeder in the wrong place it will be way harder
MrPhiscal is offline   Reply With Quote
Old 05-20-2019, 01:09 PM   #3
journey
Member#: 74555
San Remo Red
Originally Posted by MrPhiscal View Post
... imho the point of a bleeding to to get air out with the bleeder in the wrong place it will be way harder
Originally Posted by journey View Post
... I could bleed the caliper before before mounting it -- I would invert it and used my brake spreader tool (or a block of wood) to keep the pads separated. Once the air was out of the lines, I would mount the caliper.
Understand that the air would need to be bled from the caliper with the bleeder valve upright, which is why I mentioned inverting the caliper to get the bleeder valve to the top. I would need to place something between the pads as well, and once done, I would remove the object from between the pads and then mount the caliper upside down.
I would like to understand if anyone else has done this before.
I wanted to replace both calipers at the same time, and of course RockAuto doesn't have a rebuilt right/passenger caliper. My inclination is to send it back and just watch for a rebuilt one to become available.
