Welcome to the North American Subaru Impreza Owners Club Tuesday June 25, 2019
Mid Atlantic Impreza Club
Old 06-14-2018, 04:01 PM   #4176
binlogic01
Member#: 487217
2006 9-2x Aero
All kinds of things.. been chasing a really strange multiple misfire issue
binlogic01 is offline   Reply With Quote
Old 06-15-2018, 02:28 PM   #4177
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Removed the shredded remains of exhaust wrap from the single-port UEL header on the beater Impreza. It's a stainless header, so the wrap isn't needed, anyway.
I've been hearing a buzzing/rattling that I was hoping was due to the stainless straps rattling against the header as the wrap fell apart. No such luck - pulled everything off and I still hear the buzzing. Guess I'll have to investigate a bit more thoroughly.
Old 06-16-2018, 02:19 PM   #4178
tramp
Member#: 459629
2017 WRX base
WR Blue
Spark plugs 2017 WRX. Noticeable difference but the old plugs looked great. Gap was a bit wide and I'm sure that cause the cold idle stumble.
tramp is offline   Reply With Quote
Old 06-25-2018, 10:36 PM   #4179
chansdaman
Member#: 457390
Installed a used turboXS DP, modded blue injectors, aps CAI, and rocksteady flex fuel kit. BTW, found rocksteady’s kit to be a phenomenal value at $250. Customer service was very responsive and personal. Highly recommend Donnie!
chansdaman is offline   Reply With Quote
Old 07-02-2018, 09:11 PM   #4180
sailil
Member#: 26390
2016 WRX Whiteness
1993 Del Sol
Default nameless
ordered an axleback!
Maybe not that exotic - but still fun
sailil is offline   Reply With Quote
Old 07-05-2018, 12:04 AM   #4181
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Black Saabaru got a UKDM Prodrive gauge cluster.
Desert silver Saabaru is in the process of getting a new rear sway bar, bushings sway bar mounts and endlinks. Broke one bolt due to corrosion. Spent some time drilling the broken bolt.
D-Rodman is offline   Reply With Quote
Old 07-06-2018, 12:48 AM   #4182
Dibaltic
Member#: 485271
2003 Forester
Red
Never had that happen to me as much as I have with Subarus!
I bled my brakes a set my height
Dibaltic is offline   Reply With Quote
Old 07-08-2018, 09:25 PM   #4183
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Default What did you really do to your car today? V3.1
Desert silver Aero:
Finished drilling and fixing the threads on the broken bolt for one of the rear sway bar mounts. Installed fresh rust free mounts, hardware, bushings, stock sway bar and endlinks. All replacement parts came of a friend’s 04 wrx sedan with less than 10,000 miles of use, everything is in like new condition. Anti seized all the threads. Feels tighter than before, worth the effort.
Old 07-10-2018, 04:24 PM   #4184
Philwrx94
Member#: 488190
New Subaru owner, but I waxed the car for about 5 hours. Clay bar, cleaner wax, glaze sealer, and pure carnauba wax to finish it off.
Philwrx94 is offline   Reply With Quote
Old 07-11-2018, 04:41 PM   #4185
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Replaced the cruise control actuator on the beater Impreza to restore CC functionality. It's still not quite right - the actuator I installed has a longer cable than the old actuator, so I had to shift the throttle cable bracket to get it to work. I'll have to fiddle with it more later.
Old 07-12-2018, 09:08 PM   #4186
chansdaman
Member#: 457390
Installed v7 seats, BC-ER coilovers, and picked up some new coil packs to replace the ones with 230k miles. Productive day!
Old 07-13-2018, 11:59 AM   #4187
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Ooooh, jealous of those seats!
Old 07-13-2018, 04:45 PM   #4188
chansdaman
Member#: 457390
Thank you! If interested MD JDM in Beltsville has a few more set. They are good source for well priced JDM and OEM stuff. There is also a place a Arbutus with a full set (front and rear, but not for a wagon).
Old 07-13-2018, 09:20 PM   #4189
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Old 07-19-2018, 11:20 PM   #4190
Spoolinva
Member#: 268071
2011 STI SWP
"I" didnt really do anything but pay Sweenybuilt to perform the 60k & 105k service on my 2011 STi with about 128k miles on it. I must say that if any of you guys need any kind of work done hit this dude up. Now I can move on to doing more to the car with all the major services done now.
Spoolinva is offline   Reply With Quote
Old 07-21-2018, 05:42 PM   #4191
Harry
Member#: 23390
2010 WRX STI SE
Smile Installed Ecohitch and towed trailer
Last weekend, I installed an Ecohitch on the STI, put in new turn signal bulbs (PITA) and fixed some rust I found under the battery. Then drove to Atlanta and picked up Dad's old furniture and trailered it back to the DMV in a U-haul 4x8 trailer. No issues towing the trailer, except gas mileage - got better mileage in 5th gear but only 17 versus normal 21 - 22 mpg.
Rust-stop and re-painted WRB on battery tray:
Hitch install (took awhile in the heat!):
Done:
Trailer:
Trailer's tow bar was crazy long for such a small trailer but worked fine except backing up was royal PITA.
Harry is offline   Reply With Quote
Old 07-23-2018, 10:25 AM   #4192
D-rock240
Member#: 284221
2011 WRX GV SSM
01 Legacy/03 Outback wgns
Changed the spark plugs and wires on my Outback yesterday. Much easier on the EJ251 than the EJ255.
D-rock240 is offline   Reply With Quote
Old 07-23-2018, 11:26 PM   #4193
Dibaltic
Member#: 485271
2003 Forester
Red
Got my intake figured out. It's an eBay intake for a Subaru Baja. Needed something to clear my tubs. Some modifications to it and it fits nicely now.
Old 07-27-2018, 08:25 PM   #4194
metros
Member#: 111343
Last weekend
Used a transport pass to get the 818 to our new house. No mechanical issues, fires, overheating, scraping, odd noises or discussions with the police. That's success by any measure. I do need to get the alignment done as it was road tracking all over the place. I think I'm going to invest in a bumpsteer set up as many have commented how that has improved road tracking.
I'll have to update my build thread. I've made lots of progress to get it ready to drive to the new house.
Pictures: Now with 100% more speed holes!
[IMG][/IMG]
[IMG][/IMG]
metros is offline   Reply With Quote
Old 07-29-2018, 11:17 AM   #4195
Harry
Member#: 23390
2010 WRX STI SE
Thumbs up Sweet 818!
Originally Posted by metros View Post
Last weekend
Looks great - what motor did you use? IIRC, Factory Five was thinking about adding an option for a Ford EcoBoost, as well as the 2.0 and 2.5l WRX motors.
How tough was the build?
- Harry
Old 07-30-2018, 12:57 AM   #4196
Dibaltic
Member#: 485271
2003 Forester
Red
Spark plugs on my STI. Nothing of fun to mention
Old 08-02-2018, 06:10 PM   #4197
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I'm a couple weeks behind, but I updated the driver side door moulding to match the passenger side. I washed the car (for I think the 2nd time since I've owned it) and found the driver's door moulding was about 1/2-way off. The two rear-most clips had broken and would no longer hold the moulding in place. (Maybe the victim of the bump strip doing its job? Got hit by someone in a parking lot and that popped the clips?)
As discussed when I went through this on the passenger side, the pre-'97 mouldings are no longer available, so I ordered an '01 moulding. Fits fine, just doesn't match up right where the door and front fender come together.
Old 08-03-2018, 10:17 AM   #4198
VXSS
Member#: 115345
'18 FXT Touring
Finally pulled the trigger on some Goodyear Sport A/S tires for my XT. Had new wheels sitting in my garage all year and just dragged my feet on it. Just need to get them mounted (now watch me sit on THAT for another 6 months....). :\
VXSS is offline   Reply With Quote
Old 08-04-2018, 08:02 PM   #4199
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
What are the new wheels?
Old 08-06-2018, 12:53 PM   #4200
VXSS
Member#: 115345
'18 FXT Touring
Just some cheap old 18x8 Motegi Traklites. Good enough for my daily commute.
