Welcome to the North American Subaru Impreza Owners Club Wednesday June 19, 2019
Old 05-01-2019, 12:21 PM   #276
kopele
Member#: 363007
2008 STI
How are you testing with vodka?
I tried submerging the bottom of the sensor in vodka and got strange readings.
Does the fuel need to flow through the sensor for accurate reading?
kopele is online now   Reply With Quote
Old 05-01-2019, 01:41 PM   #277
HyperBSTI
Member#: 498589
2016 WRX STI
Hyper Blue
Just needs to be full. I capped one end and filled it up. The sensor doesn't care if the liquid is moving or not.
HyperBSTI is offline   Reply With Quote
Old 05-01-2019, 04:02 PM   #278
kopele
Member#: 363007
2008 STI
Thanks, I'll try testing it at the car like you suggested.
Old 05-01-2019, 04:51 PM   #279
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
I built a custom circuit board and found a box to package them in.
all finished
AFBeefcake is offline   Reply With Quote
Old 05-04-2019, 10:29 AM   #280
redrexmeister
Member#: 111692
04 WRX wagonette
SRR
Very nice!
what's the cost of custom cuitcuit board project vs. original setup with Arduino?
I assume to go this route one needs access to specialty equipment?
redrexmeister is offline   Reply With Quote
Old 05-04-2019, 11:04 AM   #281
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Originally Posted by redrexmeister View Post
Very nice!
You still need the Arduino. I just made a board for it to sit on and mount the regulator and resistors to. I allso made a header to connect a LCD screen if I later want to add it. I used a board house to make them.
Here is the back of the board.
Old 05-06-2019, 09:24 PM   #282
Jakek969
Member#: 477328
Is everyone using Ardunio brand boards? or generic?
Jakek969 is offline   Reply With Quote
Old 05-06-2019, 10:01 PM   #283
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
I'm using a knock off. It' snot in the car yet, as the car isn't on the road. However, everything is programmed the same.
fbi is offline   Reply With Quote
Old 05-17-2019, 02:01 PM   #284
kopele
Member#: 363007
2008 STI
I'm not sure what I'm doing wrong, but I cannot get any meaningful output.
I have the arduino plugged into a laptop and the flex fuel sensor connected to the car
battery. I have a counter set to increment inside the TIMER1_CAPT_vect ISR.
The counter stays at 0, so it looks like the event never triggers.
I have continuity from the sensor input to pit 8, 4.66K resistance between the sensor input and the +5V pin, and 4.47K resistance between pin 8 and +5V pin.
I have tried 2 of these sensors: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Any ideas?
Thanks for the help!
Old 05-17-2019, 02:33 PM   #285
HyperBSTI
Member#: 498589
2016 WRX STI
Hyper Blue
Any ideas?
Are you grounding the arduino to the car as well? Wire from the USB to a chassis bolt or back to the battery negative.
Old 05-17-2019, 02:44 PM   #286
kopele
Member#: 363007
2008 STI
I'll try grounding the arduino, I thought it was grounded via the USB.
Thanks for the suggestion.
Old 05-17-2019, 04:52 PM   #287
kopele
Member#: 363007
2008 STI
I got better results by grounding the arduino to the car battery.
It does seem that fuel needs to be flowing through this sensor to get an output.
When I just fill the tube and let it sit the frequency goes to 170Hz instantly and doesn't change.
When I try pouring vodka through the sensor I get frequencies within range, but I cannot get a stable reading, probably because I cannot get a steady flow through the sensor.
I'm just guessing at this point.
Old 05-27-2019, 06:10 PM   #288
kopele
Member#: 363007
2008 STI
I put the sensor on the car and got a good stable reading. I wired the read O2 sensor connectors and I get 12V, but only when the O2 sensor is disconnected. As soon as I connect it I lose power on the additional wires.
Any thoughts on this?
Thanks again for all of your help!
Edit: Looking at the Cobb kit pictures it looks like I've wired the wrong pins, I'll try to redo it.
Old 05-29-2019, 06:52 PM   #289
zcivic
Member#: 199691
04 Forester XT
I was wondering if anyone has been able to make an external display work with this
like this:
https://www.ebay.com/itm/0-91-128x32...72.m2749.l2649
Currently Cobb doesn't offer flex fuel for my 04 FXT but I still would like to try to get this set up and working in case they do.
I have the code for it but I can't figure out how to add it to the code in the first post.
If I overlooked it in this post already I'm sorry. I also did find a set up on Audizine but its not using the NANO and its also using a different OLED screen, its square.
zcivic is offline   Reply With Quote
Old 05-29-2019, 08:18 PM   #290
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
like this:
I'm using a different screen. I posted the code I'm using in this thread. Not sure the page.
Old 05-29-2019, 09:54 PM   #291
zcivic
Member#: 199691
04 Forester XT
Found it on page 8. I copied and saved that code just in case. I noticed it has the dimensions written in the code not sure if changing that is all I need to do or not but once I get parts in I'll get more into it, or if someone smarter then me can dumb it down on what I need to code for the one I ordered.
Old 05-29-2019, 11:10 PM   #292
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
Yeah, just post up when you're having issues.
B
Old 05-31-2019, 12:41 PM   #293
Onelownismo
Member#: 492323
2017 STI
How many of you guys are successfully running this flex fuel sensor on your car?
My tuner is recommending against me doing this and recommending I go with Cobb instead. I was told that the Cobb sensor is much more than a 0-5v sensor and that it has proprietary software and failsafes built in.
Anyone have any insight on this? I don't want to lose my dyno deposit if the sensor doesn't work right.
Onelownismo is offline   Reply With Quote
Old 06-02-2019, 01:06 PM   #294
kopele
Member#: 363007
2008 STI
Got everything wired up in the car and still struggling to get it working. The frequency is bouncing all over the place and I cannot get a stable reading, like before. It seems to be wired ok when I check with a multimeter. I'm tempted to try a different kind of sensor.
Old 06-02-2019, 06:00 PM   #295
kopele
Member#: 363007
2008 STI
When the arduino is powered by USB (and common ground connected) everything works fine, but when the external power is connected the input goes nuts. Is 8V too much for the nano or is the 12V input wire causing interference by being too close to the 5V output pin? I don't see any fluctuation when I measure the voltage, so I think I'll try a 5V regulator instead of the 8V.
Old 06-02-2019, 10:50 PM   #296
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
Definitely check the voltage. Some Arduino can handle 12v, some cannot. Test it after your regulator, and monitor?
Old 06-04-2019, 06:53 PM   #297
kopele
Member#: 363007
2008 STI
The 5V regulator didn't help. The nano is supposed to support 5V-20V 6V-12V unregulated on the Vin pin because it has an internal regulator. I tried direct 12V with the same result. Voltage on other pins was consistent with the board being powered with USB. I think I'll try a nano from a different place.
Old 06-07-2019, 04:12 PM   #298
kopele
Member#: 363007
2008 STI
Well I'm not sure what the issue is, but I can power it on the +5V pin with the 5V regulator and it works fine, so that's what I'll do. Thanks again for the help!
Old 06-13-2019, 04:13 PM   #299
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
Nice work! Any chance you could share a link to where you purchased that enclosure/box?
pearson222 is offline   Reply With Quote
