Welcome to the North American Subaru Impreza Owners Club Saturday July 11, 2020
Old 05-07-2019, 01:31 AM   #1
BajaTim
Member#: 472383
2005 Baja Turbo AT
Default High Beams = Low Beams
Can anyone see any difference in beam pattern (from 25’) between my high beams and low beams (2005 Baja)?
The left/right bolts do not seem to adjust direction, and only the passenger side height adjustment did anything (raised cutoff about 4-6”).
Maybe the adjuster bolts were already “maxed out”?
Overall pattern (eg, height of cutoff) was same before, and I’ve been using my high beams as low beams with zero comments from oncoming drivers. Now I see why
Low beams have essentially been useless.
BajaTim is offline   Reply With Quote
Old 05-07-2019, 01:46 AM   #2
BajaTim
Member#: 472383
2005 Baja Turbo AT
And here is the low beam (in case you were wondering) with fogs on...
Old 05-08-2019, 07:17 AM   #3
thatgarrett
Member#: 497099
2007 Outback Sport
Urban Gray
Do you have the non-turbo lights that have a single dual filament bulb for high and low? I had a legacy of that generation I swapped outback lights to that were a night and day difference, they will fit your Baja too
thatgarrett is offline   Reply With Quote
Old 05-08-2019, 01:52 PM   #4
BajaTim
Member#: 472383
2005 Baja Turbo AT
No - I have the separate high and low beams - the bulbs (PIAA?) I got are very close in brightness - 55W vs. 60w - which probably explains similarity.
Old 05-08-2019, 02:11 PM   #5
Mahend21
Member#: 501149
+1
Mahend21 is offline   Reply With Quote
