Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 05-20-2018, 07:13 PM   #2026
Zumiez87
Member#: 206481
2013 WRX STI
Originally Posted by Scargod View Post
You talkin' to me? 2008 STi. (2011 is same as '08, but don't know about '13's)
Enkei RS05-RR, 18" X 10.5" +35ET. Run fronts with 5mm spacers. I am running -3.5° camber. Tires would rub the coilovers without the spacers. YMMV! You will have to figure out strut spring diameter vs my 2.5" dia. coilover springs.
Note: front fenders have no lip and are stretched a bit to make everything clear. I am running 285 DOT radial slicks and coilovers. Rears are fine with just rolling.
I'd say you cannot stuff anything bigger in there without flares.
From this data and a good tire calculator you should be able to figure it out.
You don't mention tires...
Looking to run 265 all around with the 18x9 +35. Like I said I'm looking for the same type of fitment NY current stock bbs with spacers have
Zumiez87 is offline   Reply With Quote
Old 05-20-2018, 07:18 PM   #2027
Zumiez87
Member#: 206481
2013 WRX STI
I think that the size I'm looking at will be exactly what I'm looking for. Thanks for that website and your advise!!
Old 07-23-2018, 02:43 PM   #2028
rulenjon
Member#: 485841
2011 Impreza WRX STI
World Rally Blue
Does anyone know if ESR SR07 18x9.5+35 (TE37 Style) clear 2011 sti brembos with 5mm spacer?
rulenjon is offline   Reply With Quote
Old 07-28-2018, 05:43 PM   #2029
RedShred
Member#: 363388
2017 STI
Dark Gray
Hi. I can confirm that Work Emotion 11R fit 15+ STI 18x9.5 +38 even with 265/35 tires.
RedShred is offline   Reply With Quote
Old 09-07-2018, 02:17 PM   #2030
Crash Test Dummy
Member#: 490361
17 STI
Can anyone confirm the Motegi MR131 Traklite’s will fit 17 STI?
18 x 9 +35
255/35/18
Swift springs, 1” drop.
Brembo’s.
Crash Test Dummy is offline   Reply With Quote
Old 09-16-2018, 12:11 AM   #2031
Crash Test Dummy
Member#: 490361
17 STI
18 x 9 +35
255/35/18
Brembo’s.
They fit.
Old 09-27-2018, 06:52 PM   #2032
wangman
Member#: 269602
2018 Type RA
Nice, I was about to ask almost the same.
'18 STI-RA stock suspension
Motegi 131 Traklite but with
255/40-18 et 35
Looking for more footprint for track only and wondering if there will be rub.
BTW, Crash, love the TMGPS sticker on the rear window!
wangman is offline   Reply With Quote
Old 09-27-2018, 06:54 PM   #2033
wangman
Member#: 269602
2018 Type RA
Sorry, correction...
255/40-18
on Motegi Traklite 18x9.0 et 35
Old 09-27-2018, 08:46 PM   #2034
Scargod
Member#: 260314
2007 STI
silver gray metallic
255/40-18 et 35...
You are not asking (and others are not asking) the obvious questions. Are you willing to do any mods? Roll, pull cut? What's your level of comfort?
You don't mention a tire. That's important. You say stock suspension so it won't be lowered nor negative cambered...
As you pose the question the answers are fairly worthless.
Last edited by Scargod; 09-28-2018 at 07:50 AM. Reason: word correction: answering should have been asking
Scargod is offline   Reply With Quote
Old 09-27-2018, 09:47 PM   #2035
wangman
Member#: 269602
2018 Type RA
Not looking to do any mods. Stock body. No lowering or negative camber.
Yoko Advan A05 or Toyo Proxes 888R
Was originally looking at 265/35-18 but might switch to 255/40-18 for the Motegi wheel above.
Old 09-28-2018, 08:03 AM   #2036
Scargod
Member#: 260314
2007 STI
Width of wheels and 35 offset, right? Might work in the larger 265 size. Use this calculator. I am not sure of stock wheel entries are correct.
Old 09-28-2018, 02:51 PM   #2037
wangman
Member#: 269602
2018 Type RA
Thanks for the help.
Old 10-13-2018, 09:07 AM   #2038
Ekire2019
Member#: 484285
Hi everyone,
Curious if anyone had ever tried these wheels or knows if they will work on a 2018 STI sport tech. Heres the info:
Model # FC04
P.C.D.:5x114.3mm
Offset:+40
Finish Metallic Black
Bore:72.6 mm
Seat:60
Lip Size:N/A
Load Rating:1521 lbs / 690 kg
Winter Approved Finish:Yes
Ekire2019 is offline   Reply With Quote
Old 10-17-2018, 04:05 AM   #2039
Johhn2
Member#: 490304
ok thanks
Johhn2 is offline   Reply With Quote
Old 10-29-2018, 09:43 PM   #2040
Lennonp
Member#: 493293
Default 2018 Sti
Hello,
I was wondering if anyone has experience with this particular fitment, with the new brakes on the sti. I am a newbie to this stuff, so please forgive me if this is a dumb question.
I am looking to putting on a set of 19×9.5 +35 TE37 Ultras. They are quite expensive, so I dont want to make a mistake. Will these fit on my car, and will they work with the stock suspension? Will I have to do any fender roll? The car came with 19s, so I'd like to keep the same diameter of wheel. Also, in the future, I'd like to change out the suspension to aftermarket, with control arms. Does anyone have a similar set up, who can give me solid advice please?
Thanks!
Lennon
Lennonp is offline   Reply With Quote
Old 12-16-2018, 08:35 PM   #2041
Chip_04sti
Member#: 434474
Default 04 sti brembo clear question
I’m looking to pick up a set of work emotion d9r 17x8.5 +32, anyone know if they will clear brembos!?? I email work wheels and haven’t heard back.
Chip_04sti is offline   Reply With Quote
Old 12-25-2018, 07:43 PM   #2042
azak907
Member#: 432487
2013 WRX STI Hatch
Default Work D9R 18x9.5 +30
Anyone know if these will clear the 2013 STI Brembos without spacers?
azak907 is offline   Reply With Quote
Old 01-08-2019, 12:48 AM   #2043
FIGURRAMOTORS
Member#: 482561
Default SSR Integral GT2 17*7.5 +50 5*100
This model fits Brembo Gold without spacers
FIGURRAMOTORS is offline   Reply With Quote
Old 01-08-2019, 12:56 AM   #2044
FIGURRAMOTORS
Member#: 482561
I think this one might be very useful as well:
https://www.wheel-size.com/calc/
Use these:
http://www.1010tires.com/wheeloffsetcalculator.asp
http://www.rimsntires.com/specs.jsp
http://www.rx7.org/Robinette/tire_diameter.htm
Try and avoid spacers.
When you get to a realistic offset (like 40-55), you may find someone who has used the specific rim you are interested in and they may know if it will clear the calipers. Don't hesitate to call the wheel seller or manufacturer and ask if they will clear the Brembos. Some have drawings you can print out and cut out that will show you clearly, in a visual manner, how the wheel will fit.
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 10:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 02:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 02:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 04:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 01:51 PM
