Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 06-27-2017, 11:42 PM   #1
repoofrs
Member#: 191934
Default Wheel fitment for 2018 STi
Now that the 18 STi's are rolling in, and with the increase in caliper size, do we know what size wheels will fit? I've been scouring the internet for days and cannot find an answer to that question. Living in New England, summer tires as OE just won't cut it for when I get the car. I'm left with trying to find a set of 19" tires to replace the Yoko's or a winter wheel setup. Appreciate the advice.
repoofrs is offline   Reply With Quote
Old 06-27-2017, 11:48 PM   #2
TERMIN8TED3148
Member#: 150233
Trying to find out same thing. Going to need a snow setup asap
TERMIN8TED3148 is offline   Reply With Quote
Old 06-28-2017, 12:09 AM   #3
repoofrs
Member#: 191934
I'm very concerned about this. I am supposed to get the car in August. That leaves me with 2-3 months to find a solution. I've even asked my friend at Konig, but he doesn't seem to have an answer for me and of course the dealership wasn't any help either. There doesn't even seem to be a good selection of tires that fit the OE rim. I'm probably gonna find an all season tire and just sell the stock tires to offset the cost.
Old 06-28-2017, 01:19 AM   #4
Mach V Dan
Member#: 12029
Our Wicked Awesome wheels (18x9.5" +42) have a lot of brake clearance, and they fit every 6-pot aftermarket system we've tried, including Stoptech and the Brembo Trophy kit. My guess is the Subaru brakes will fit.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-29-2017, 01:19 PM   #5
Fixxxr
Member#: 180960
2016 STI
white
Did a quick search on Subaru Canada's website and it shows the base model sporting the same 18" base rims that they've had on from 2015 and up. That should tell you what you need to know.
Fixxxr is offline   Reply With Quote
Old 06-29-2017, 01:52 PM   #6
TylerLieberman
Member#: 416864
2016 STI
The 6 pots are the same thickness as the 4 pots. Therefore, if the wheels fit the 4 pots, they'll fit the 6 pots.
The only thing to be concerned about is wheel diameter. 19s and 18s will fit. I can't confirm 17s though.
TylerLieberman is offline   Reply With Quote
Old 06-29-2017, 03:12 PM   #7
repoofrs
Member#: 191934
That's good information to know. I would much rather 17's and a bigger sidewall for a winter set up, especially with our crappy roads in the north east. I can settle for 18's if I really have to. 19's scare me for winter roads plus they are just too expensive for the winter abuse.
Old 08-04-2017, 12:48 PM   #8
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
Thanks! Did you find this our yourself or how did you come accross this info? Im about to pick up some 2008-14 18" BBS STI wheels.
JJay03 is offline   Reply With Quote
Old 08-05-2017, 01:02 AM   #9
TylerLieberman
Member#: 416864
2016 STI
Subaru STI R205 used 6 & 4 pot brakes with the standard 18x8.5 wheels they were sold with in Japan. Same size and offset as the wheels we get here in the US.
https://www.autoblog.com/2010/01/07/...n-still-not-c/
The overall rotor diameter and thickness is slightly larger than the 4 pot rotors, but the calipers themselves are the same thickness. Check the link for pictures.
Old 08-05-2017, 01:03 AM   #10
TylerLieberman
Member#: 416864
2016 STI
And here's another article with more pictures confirming fitment of 18s on 6 pots
http://www.speedhunters.com/2010/07/..._impreza_r205/
Old 08-05-2017, 03:32 PM   #11
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
Im sorry but I am still not seeing where it says about the 6 pot being the same width as the 4. I know on my last car Chevy SS when going from the 4 to 6 pot calipers that it would be very very close to the wheel and most had to run a small spacer. The Diameter was ok but it was caliper to the back side of the spoke making contact. It sucks to buy wheels from a private seller that do not fit so just trying to make sure.
Old 08-05-2017, 08:23 PM   #12
TylerLieberman
Member#: 416864
2016 STI
The 18x8.5 wheels in the pictures above clear the 4 pot calipers by all of 5mm. As you can see in the pictures, they also clear the 6 pot calipers by about the same amount, roughly 5mm.
That being said, if you put your thinking cap on, you can pretty easily deduce that the 4 and 6 pot calipers are the same thickness, seeing how the same OEM wheel fits over both of them with the same amount of clearance from the spokes.
Old 08-05-2017, 08:55 PM   #13
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
I have not seen those wheels on a STI with 4 pots. Im not one who knows every subaru wheel though so I was getting my info from this thread.
https://forums.nasioc.com/forums/sho...1#post35072501
I know the diameter and offset are good so even if I have to add a small spacer I guess its no big deal. I will most likely buy them tomorrow and report back once I mount them.
Old 08-06-2017, 06:52 PM   #14
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
Got my winter wheels.
Old 08-17-2017, 05:27 PM   #15
Roylfrancis
Member#: 472356
2018 STI
Crystal Black Silica
Thinking about trying a set of BBS 17" for my 2018, seller said they fit his 2017. Don't really want to drop the money just to do a fitment test.
Roylfrancis is offline   Reply With Quote
Old 08-17-2017, 05:30 PM   #16
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
17's would be really close. You might want to stick with 18's at least.
Old 08-17-2017, 05:42 PM   #17
Roylfrancis
Member#: 472356
2018 STI
That's what I was thinking, really good deal on them 500, no curbing of bending. Just need to be painted. I guess I'll continue my hunt.
Old 08-17-2017, 05:59 PM   #18
Chuckable
Member#: 447566
2017 WRX
With 13.4 inch rotors, I can't imagine that 17" wheels (except maybe Braids?) will fit the 2018+ STI brakes. Best to at least stick with 18s.
Chuckable is offline   Reply With Quote
Old 08-18-2017, 04:11 PM   #19
matt06wrxwgn
Member#: 172027
2006 CGM Wagon
322WHP 355 WTQ
I can confirm that a 17" barrel will clear the 2018 STI brakes, barely.
For example, the Mach V Awesome wheels, 17x9 +42, DO indeed fit, though the wheel weights would need to be carefully placed as the caliper would scrape them off.
matt06wrxwgn is offline   Reply With Quote
Old 08-18-2017, 04:33 PM   #20
frederik
Member#: 64405
2018 STi
I have seen this from member tylerlieberman at iwsti. This sparco wheel fits but no more details on the wheels specs. Looks like the 17" that fit are going to be a very tight fit and probably won't be a lot of them that fit.
Originally Posted by tylerlieberman View Post
2018 on 17s. Barely clears when static. Pretty sure the calipers would make contact with the wheel weights under load though.
frederik is offline   Reply With Quote
Old 08-18-2017, 08:31 PM   #21
Chuckable
Member#: 447566
2017 WRX
Wow I had no idea that wheel barrels of those 17" wheels would fit!
Old 08-19-2017, 05:53 PM   #22
willimprez
Member#: 91655
15 STI
CWP
Running Bronze Work Emotion CR Kiwami in 19x9.5 +38 wrapped in the OEM 245/35-19 lowered on RCE Yellow springs. No roll and rubbing yet.
willimprez is offline   Reply With Quote
Old 08-20-2017, 10:31 PM   #23
Roylfrancis
Member#: 472356
2018 STI
That's a slick car man how do you like the rce springs?
Old 08-21-2017, 12:53 PM   #24
STI 2 NV
Member#: 31748
'18 WRX STI Limited
LBP
Any update on this?
STI 2 NV is offline   Reply With Quote
Old 08-27-2017, 11:52 AM   #25
Snow Drift
Member#: 75071
'18 STI Ltd 15XV Hy
Past: 05, 08, 11 Red WRXs
Will 18x8 fit the calipers? Or do I have to stick with 8.5"? I'm looking for narrow snow rims.
