Welcome to the North American Subaru Impreza Owners Club Saturday March 17, 2018
Old 10-18-2010, 11:34 PM   #1
Member#: 238755
Question 96 outback 25DOHC to a 2.2 SOHC 93
here is what we have! a possibly bad 2.5 dohc. i have a 2.2 soch motor from a 93 legacy easy swap. my biggest question is cam sensor since the 2.2 has its own separate wiring for that sensor will the sensor from the 25 work in the 22 if i swap the intake manfold? next is the crank sensor it also has its own separate wiring for the sensor so back to swapping the oil pump so the crank sensor from the 25 will plug into the 25 intake manifold harness.
thanks john
06PrecisionSTI is offline   Reply With Quote
Old 10-19-2010, 07:38 PM   #2
Member#: 215017
97OB 2004 civic
The 93 is a OBD1 engine.
I think it would be far more easier to source a 1996 up OBD2 engine.
bangedlegacywagon97 is offline   Reply With Quote
93 2.2 sohc heads on a 02 2.5 sohc, will they fit? Oldbluelegacy Normally Aspirated Powertrain 17 05-05-2010 01:22 AM
WTB: PA 96 Outback 5 speed 2.2 Driveshaft michaelSVX Private 'Wanted' Classifieds 0 01-11-2009 11:46 AM
96 2.2 impreza outback bughunter Normally Aspirated Powertrain 8 02-05-2008 01:24 PM
engine swap 2004 2.5 sohc to 2000 2.5 sohc rickinne General Community 4 06-08-2006 05:29 PM
Engine nocking noise in 2002 2.5L SOHC phase 2 Outback rjp98outlook Normally Aspirated Powertrain 7 02-15-2005 07:33 PM
