Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 05-24-2013, 07:11 PM   #101
cheddle
Member#: 357384
lmao, my father-in-law couldn't figure this out and used to disconnect the battery each night because he didnt want it going flat... he did this for about 3 months until he finally mentioned it to me... lol
cheddle is offline   Reply With Quote
Old 08-09-2013, 01:22 PM   #102
Nahtanojon
Member#: 364890
This happened to me. Didnt realized it until i cleaned my dash.
Nahtanojon is offline   Reply With Quote
Old 08-21-2013, 08:50 PM   #103
belchfire
Member#: 67098
2000 impreza OBsport
green
I will never live this down. 10 years of ownership, 234K miles. First time.
belchfire is offline   Reply With Quote
Old 10-06-2013, 06:01 PM   #104
99screwbaru
Member#: 332912
2002 stage 2 wrx
rally blue
HAHAHAHA thats f****** awsome omg
99screwbaru is offline   Reply With Quote
Old 03-06-2014, 10:16 PM   #105
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
I'd like to add that the new gen soobies do not have the switch. If you turn the car off before cutting the lights off, they automatically turn off.
You can turn them on without the keys, but you will get a warning buzz with the door open.
Tha Chakal is offline   Reply With Quote
Old 03-14-2014, 07:12 PM   #106
zombiez07
Member#: 335919
2004 wrx
wrb
Default along the lines
so my parking lights/tail lights/dash lights will NOT turn off. and it's NOT the parking switch, i've tried. the only way i'm able to get them to turn off is to pull the clock/room fuse in the engine bay. is there a relay somewhere that could be bad? seemed to start happening after an ecu tune... but can't see how?
04 wrx
zombiez07 is offline   Reply With Quote
Old 03-19-2014, 11:33 PM   #107
Dito14411
Member#: 362966
2004 Wrx STI
For my 04 it is not the all the lights but just the parking lights. And i did actually just recently get an ecu tune. Any ideas for the bad relay switch or an easy fix??
Dito14411 is offline   Reply With Quote
Old 03-20-2014, 12:15 AM   #108
zombiez07
Member#: 335919
2004 wrx
wrb
Wish I knew. Mine fixed itself. I jiggled some wires, there was a puff of smoke, then everything worked again . My problem spot seemed to come from behind the stereo for whatever reason. Check for crossed wires or errant grounds.
Old 03-20-2014, 12:16 AM   #109
zombiez07
Member#: 335919
2004 wrx
wrb
And make sure your parking switch isnt flipped on top of steering column
Old 03-21-2014, 04:14 PM   #110
Dito14411
Member#: 362966
2004 Wrx STI
It is not the parking switch, that was the first thing that i checked...
Old 04-02-2014, 09:23 PM   #111
05rshatch
Member#: 386530
Default 2005 impreza rs issue (no running lights or dash lights)
the lights worked fine the first day after having this car, then i cleaned the interior and now there are no running lights or dash lights. headlights work, turn signals work. Checked all the fuses, they are good. When you turn the headlight switch to first position (running lights) you can hear a click under rh side of dash but no lights (dash/running). They also don't come on from the switch on top of the column. Has anyone had this isssue or have access to running light wiring diagram?
05rshatch is offline   Reply With Quote
Old 10-23-2014, 08:52 AM   #112
Gnudoll
Member#: 262823
I'm on my third Subaru. (Two Legacy wagons that each bested 350k miles, and now my Impreza wagon is about to hit 300k) I learned about this switch very early on, but then it was called the "Subaru virgin switch" I even heard about a guy that claimed to have bought a few Subarus really cheaply (due to the "electrical problems), only to then turn the switch off after driving a few blocks... (seems dishonest to me)
As for why these lights would not turn ON... That may likely be a completely different problem. Unless, of course, the Previous Owner had hacked into something to get them to turn off... (?)
Gnudoll is offline   Reply With Quote
Old 10-23-2014, 09:44 AM   #113
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Your dash lights could have had the brightness knob turned during cleaning. Have you checked that? For the running lights, you mean the parking lights? Daytime running lights? Does your year even have DRLs? I doubt its an issue that would require a wiring diagram. Go check everything you touched when cleaning, I bet the dashlights are turned down to all the way dim after cleaning.
Was surprised to see that my 15 forester no longer has the column parking light switch.....
left footed whooten is offline   Reply With Quote
Old 02-05-2015, 11:20 PM   #114
Steve2015
Member#: 412793
I just had this same problem! haha golly gosh new toys and all there buttons
Steve2015 is offline   Reply With Quote
Old 05-24-2015, 01:15 PM   #115
dieckhoff
Member#: 420827
02 Legacy
Pearl White
God.. Glad to see I'm not the only one who had issues with this. Got a call from the neighbor that my lights were still on and me and him sat out there for 30 minutes until we figured it out. Must've hit the little switch on the column when I cleaned it earlier that day. Felt brilliant.
dieckhoff is offline   Reply With Quote
Old 05-26-2015, 12:06 AM   #116
DsB
Member#: 379896
i have an Rsti and just last night this started. my parking lights, hvac, and glovebox light are all stuck on. i checked the switch first and that isnt doing anything. i also checked all the fuses i could think of. does anyone have any ideas???? thanks.....I got angry and was hitting my dash. Turns out I had a lose wire on my clock pod. So problem fixed.
DsB is offline   Reply With Quote
Old 09-06-2016, 01:10 PM   #117
inxsible
Member#: 454018
I have a different problem though.
My driver side tail light/brake light won't come on when the headlights are off. When the headlight is on, the driver side tail light is very dim compared to the passenger side.
When applying brakes (with headlights on), both brake lights seem to be about equally bright.
Where do I start looking? Would it be one of the fuses or the bulbs itself? The fact that it turns on (although dim) makes me believe that its not drawing enough power on the driver side instead of the bulb being bad. Do driver side and passenger side tail lights have different circuits altogether ?
inxsible is offline   Reply With Quote
Old 07-11-2017, 11:03 PM   #118
vic2340
Member#: 469934
Does anybody know how to get the light to shut off entirely while driving? I have a 2002 Impreza ts and would like to know if their is a way to get them to go off. I noticed if I pull the e brake up one notch they go off but I would like to just be able to turn the knob off on the signal indicator and have the lights go away on command for stealth mode reasons. My lights are Always ON!!!!
vic2340 is offline   Reply With Quote
Old 07-11-2018, 11:46 PM   #119
ImOnTheWrongForum
Member#: 383247
This damn thing almost cost me my job haha! I was replacing the steering column cover on a 06 WRX at work (used car dealership) and hit the switch in the process. Not a single person there could figure out why the lights wouldn't turn off and assumed I must have f*cked some wiring up. This thread saved my job lol.
ImOnTheWrongForum is offline   Reply With Quote
Old 10-19-2018, 08:10 PM   #120
g77
Member#: 492809
Default the parking light switch
Originally Posted by munkis View Post
Q. Why wont my parking lights shut off?
A. Turn the parking light switch on top of the steering colulm off.
http://www.scoobymods.com/forums/sho...=&threadid=448
Jay
g7[/the positive + power contact in the switch may be touching do to the plastic being broken]
g77 is offline   Reply With Quote
Old 12-04-2018, 09:38 PM   #121
ElementGFX
Member#: 494856
14 years on and this thread is still helping people... I just had this problem lol thank you
ElementGFX is offline   Reply With Quote
My parking lights won't turn off?... Sharky Service & Maintenance 29 03-19-2010 03:55 PM
question of the day: why does my earphones.. iRick. Off-Topic 13 02-03-2009 03:20 AM
Computer guys, why won't my comp. shut off???? Eric SS Off-Topic 36 08-29-2002 03:53 AM
My parking lights won't go off LiquidForce General Community 22 01-06-2002 10:18 PM
