Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 10-08-2008, 10:30 AM   #1
pcconsultant
Member#: 10050
Question JDM STi Headlights Questions (2002 WRX)
Greetings All:
I am looking for some help and couldn't find all my questions answered in previous posts. I have a 2002 WRX that I am thinking of swapping the OEM lights to the JDM STi type (if I can find them at a decent price). I'm not that technical, so I apologize if these are stupid questions, but here goes:
1. Are there two versions of the same JDM light, an HID and a non-HID (that would not require the ballasts)? I have seen some on eBay that do not include the ballasts and I do not know if it is a missing part or not needed if not going HID. Where are the ballasts installed as this would be a new part in the engine bay.
2. Wire modification: I believe if there are two versions, both would need wire modification or a wire harness that I have seen for sale. Is it true plug and play (for lack of a better term!)? I would not have to do any wiring? What about the fuse...does it need to be updated for either HID or non-HID?
3. While I realize the HID are brighter, etc., if there is such a thing as non-HID (thus going the cheaper route), how is the light (meaning, similar to OEM)?
4. Would I have to aim them, and if so, is it easy (I understand the HID may have a motorized wire, but couldn't I just use a screwdriver)?
5. The OMS lights have the daytime running lights when the trans is in drive, and off when lights are turned on. If fog lights are on and then lights are switched to high beam, the fog lights go off. Does this all work the same way with the JDM's?
Thank you all so much for the advice to come!!!
pcconsultant is offline   Reply With Quote
Old 10-08-2008, 11:03 AM   #2
wrx03.4wz
Member#: 122375
03.7 I own 2 of them
White & Black
Originally Posted by pcconsultant View Post
Greetings All:
well there are actually 3 versions 1the JDM (NON-HID), JDM (HID), And the EURO SPEC: these are not hid's but the beam direction is the same as the US, also remember just because it dosent have HID's dosent mean you cant buy them later on I was looking for a set myself but then i crashed my car drifting, so i just said F' it and did a full 07 STi body swap, but if i were you i would just get some brand new stock lights and then go check out www.Lightwerks.net trust me you will not be disapointed.
wrx03.4wz is offline   Reply With Quote
Old 10-08-2008, 03:23 PM   #3
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Ok, I will add even more to that...
There are actually 4 different types... JDM (non-HID), JDM (HID) JDM STi Wagon (HID - black chrome) and EDM (non-HID).
1 - The ballasts are little boxes about 3 inches x 4 inches, 1 inch thick. You can install them anywhere, usually right behind the headlight (in between the headlight and the battery is the normal spot). You need the ballasts to run the HID's, if they are non-HID you don't need anything.
2 - The plug and play harness SubyDude sells is for the non-HID lights, and is truly plug and play. Plug it in, your headlights work. You can use this harness for the HID lights, you just have to swap two wires (took me a while to figure this out when wiring up my lights). No fuses need to be changed, or relays.
3 - The non-HID lights will have the same output as stock, which is sufficient. But I will say the light from the HID's is far superior, and frankly teh sexAy
4 - Yes they can be aimed with a screw driver
5 - All of the light functions will work the same. Daytime running lights will be on, foglights will turn off when you switch to high beams. The low beams come out of the projectors, while the highbeam is the reflector part on the top of the headlight housing.
I paid a pretty penny for my headlights (I have JDM STi wagon headlights, factory HID's in black chrome)... but they are easily the favorite thing on my car. The light output is awesome, and they just look damn good.
Now... a word on beam pattern. In Japan they drive on the left side... so all JDM headlights are designed such that the light output is higher (physically higher, not brightness) on the left side (off the road). In the US, since we drive on the right, the headlights will be aimed up towards oncoming cars. That is why a lot of people prefer the EDM lights, they are designed for LHD cars. BUT they don't exist with factory HIDs.
I have the JDMs, and have them aimed lowed enough that I do not blind anybody. Some people will say no, stupid idea, you're blind the world! But honestly - from personal experience, my headlights do NOT shine into oncoming cars, I have plenty of light output in front of me.
If you have any other questions, feel free to PM me.
twizzstyle is offline   Reply With Quote
Old 10-09-2008, 10:46 AM   #4
pcconsultant
Member#: 10050
Thank you both!
Twizzstyle...GREAT info! I might even be more confused now! First, your car looks great...that is exactly the look I am going for. Of course, now I think the HID is the way to go, but you also threw me with EDM's! I didn't even realize they existed. So my options are the JDM HID/JDM non-HID or EDM non-HID (do you know if the harness would work with the EDM non-HID as well? I could inquire with SubyDude on my own about that).
Back to a bit more research, along with trying to find any/all varieties so I can decide on which way to go!
Peace!
Old 10-09-2008, 12:05 PM   #5
Handsdown
Member#: 29355
it's easy to retrofit other projectors into any of these lights. unless you have LHD EDM projectors, you should consider it...
i had JDM projectors and used them in a variety of different roads and environments. they either blind others or blind you. there is no best of both worlds. they are unsafe for use on our roads. i took them off my car in favor of LHD projectors in homemade housings, and now the JDMs sit awaiting retrofit.
Handsdown is offline   Reply With Quote
Old 10-09-2008, 02:25 PM   #6
pcconsultant
Member#: 10050
Tell me more, Handsdown. Do you mean like from a company such as lightwerx? If not, do you have any links that I can take a look at? Thanks!
Old 10-09-2008, 04:40 PM   #7
illmatic
Member#: 3536
2017 SWP BRZ PP, FXT
2002/2003 AW/PSM WRX
I just picked up a set of JDM HID headlights.
http://forums.nasioc.com/forums/show....php?t=1138757
illmatic is offline   Reply With Quote
Old 10-10-2008, 06:40 AM   #8
Handsdown
Member#: 29355
i mean doing what they do, but doing it yourself.
if you measure exactly, use a level, and can drill holes in metal, you can do it.
there are lots of threads. search for tsx retrofit jdm sti projectors
Old 10-10-2008, 09:56 AM   #9
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
How do they blind you?
You can see the light cutoff pretty clearly, as long as it is below the windshields/windows of the other cars, you aren't blinding anybody. There are MANY people running JDM headlights without issue.
Old 10-10-2008, 12:02 PM   #10
Arctic Penguin
Member#: 119532
2006 WRX
the sadest thing is that aimed low enough that(you thnik) they don't glare oncoming traffic, makes them pointless
there IS no happy medium
the jdm lights are the wrong lights for any LHD car and that's that
Arctic Penguin is offline   Reply With Quote
Old 10-10-2008, 12:45 PM   #11
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
I see you have a 2006 WRX, so do you speak from experience?
I was very concerned with this when I got my headlights, so I did a lot of checking with friends driving their cars in front of me, in on-coming lanes, varying distances, varying heights of their cars, etc. Blinded nobody. The step in the cutoff isn't that big.
Old 10-10-2008, 01:15 PM   #12
Arctic Penguin
Member#: 119532
2006 WRX
sorry, but it is impossible to use the 'wrong' lights the right way
can NOT happen
can NOT be done
a PROFESSIONAL may be able to refit the housings properly but that level is WAY beyond the average kid wanting kool and hacking things
and ive been there seen all that and know what it is all about
EDM lights are the only thing id use and even they aren't RIGHT
and the usdm stock bugeye headlights are just about worthless, yes--I know that
Old 10-17-2008, 06:11 PM   #13
MY EJ20T
Member#: 133324
2002 MBP Stg 2 Rally
MBP
Default my experience
i own a 2002 midnight black pearl wrx, and i found the jdm projectors on ebay for a good price a few months ago. well the ballast have the single harness plug that connects to the nissan maxima style ballast, with 2 wires in, 3 wires out in a single plug.
i did not have suby dude's easy wiring harness so I made my own and i figured with two wires, black and white from subaru, that black would be the neutral and white was the feeder (12v +) The hid bulbs crackled and wanted to come to life but my mistake, i fed the ballast the wrong voltage, possibly damaging them and shortening the life of the bulbs. ill never do that again. all is fine now, but that day taught me to NEVER assume what colors go to where on any japanese car. it might just be the opposite.
my ej20t
MY EJ20T is offline   Reply With Quote
Old 10-19-2008, 08:17 PM   #14
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
By lighting up the pavement directly in front of the car, you force your eyes to adjust to a higher brightness than is actually lighting objects down the road. So, while you see things right in front of the car very nicely, you don't see the stuff that's important. Anything you see is going to be too close to react to.
sniper1rfa is online now   Reply With Quote
Old 10-24-2008, 02:25 PM   #15
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
what bulb size does the jdm black chrome hid ones use? Can you put aftermarket bulbs in there or no?
Reason I ask is I have jdm non hids with mccolluch hids and found a good deal on the black chromes, so I wanted to know! lol
D Money is offline   Reply With Quote
Old 08-21-2016, 07:54 PM   #16
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
Sorry if this was covered but what is the replacement size of the JDM headlight low beam bulb?
pointblink19 is offline   Reply With Quote
Old 08-21-2016, 07:57 PM   #17
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/05 GTO
2008 called, it wants its thread back.
H1 if they are halogen/non-HID.
I hope you're not using them with the RHD beam pattern.
Old 08-06-2019, 03:57 PM   #18
NRadonich
Member#: 503581
2002 Impreza 2.5TS
2019 called.
2002 Bugeye GG Wagon, going with some appearance upgrades.
Looking at these -
https://www.ebay.com/p/DEPO-Bugeye-B...xoCb3kQAvD_BwE
NRadonich is offline   Reply With Quote
Old 08-06-2019, 05:47 PM   #19
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/05 GTO
I wouldn't, you get what you pay for and Ebay stuff is generally poop.
But there's also a whole thread just on those-
https://forums.nasioc.com/forums/sho....php?t=2462696
*help* Jdm Bugeye Headlight Question! min88 Interior & Exterior Modification 3 10-01-2009 09:31 PM
JDM HID Headlight question brex16 Electrical & Lighting 4 08-24-2006 08:18 PM
Help installing 2002 JDM STi headlights/HID kit mbraun20 New England Impreza Club Forum -- NESIC 8 06-25-2004 12:44 AM
JDM Projector headlights for 2002 wrx wrx2nv Electrical & Lighting 2 01-09-2004 02:17 AM
new JDM WRX headlight question Bugsie1 General Forum Archive 8 11-20-2000 12:30 AM
