Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 03-28-2018, 05:48 AM   #1
Woojen
Member#: 339264
1997 Impreza GC8 JDM
Default Electric Pins that fit OEM Subaru connectors
hello im about to rebuild my Engine Loom, to my standalone ECU, but i have one issue, i will reuse my connectors that fit my Engine Sensors but as the loom is pretty old i wanna "repin" the connectors with new fresh electric pins
but i cant find any that fits, what have you guys used? and where can i buy them?
2nd Option, where can i buy complete "pigtail" connectors to AVCS sensor and all those Trigger sensor (cam and crank sensor) etc etc
best regards
Woojen is offline   Reply With Quote
Old 03-29-2018, 01:46 AM   #2
MrWRX17
Member#: 458676
2017 WRX
The shop manual for the vehicle may list the type of pins needed.
You may be able to order them from a subaru dealer service dept. That is also where you can get the shop manual.
MrWRX17 is offline   Reply With Quote
Old 03-29-2018, 08:28 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I highly doubt the dealer can help with pins like that. They would just sell a new harness, not likely even a pigtail but the whole harness.
OP, there are going to be several types and sizes of pins in the engine bay, not just one.
A company like iWire here in the US may be able to help.
Frankly, unless you KNOW you have bad connections, I would just clean them with contact/electrical cleaner, use a little dielectric grease and just use what you have.
Old 03-31-2018, 04:03 AM   #4
Woojen
Member#: 339264
exactly, i will see if the pins or connectors is reuseable aprox what price do you think a pigtail will be?
best regards
Old 03-31-2018, 09:10 AM   #5
Wayne Suhrbier
Member#: 144044
2006 STI
There is a for sale classified with a bunch of pigtails for sale. They might have what you want. Shipping to Sweden will probably end up in the $20-60 USD depending on how many you need.
Wayne Suhrbier is offline   Reply With Quote
Old 04-10-2018, 10:11 AM   #6
chchchino
Member#: 303355
https://www.bmotorsports.com/shop/index.php/cPath/109
some of the connectors used are under the sumitomo category
chchchino is offline   Reply With Quote
Old 07-29-2019, 03:12 PM   #7
Keenah
Member#: 133754
1998 3.6RSTi
All blue, all blue baby
Guessing you already got your problem sorted but iWire sells a ton of Subaru connectors and plugs.
https://www.iwireservices.com/online-store
Keenah is offline   Reply With Quote
Old 07-29-2019, 08:16 PM   #8
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Sumitomo and Yazaki are common connectors used in Subaru models. Sometimes it takes a little work to find a matching contact.
mrsaturn7085 is offline   Reply With Quote
Old 07-30-2019, 08:03 AM   #9
Barge
Member#: 62941
2004 #LesboRacer
You can get most every pin/connector you need from Corsa-Technic.com
Depending on your time frame they will even add connectors to their inventory if they don't already stock them.
If you need something now and don't mind paying $20 a connector kit then iWire has pretty much every subaru connector there is.
Barge is offline   Reply With Quote
