Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 05-26-2018, 03:53 AM   #1
KoachKoKo
Member#: 456501
2015 WRX
WHITE
Default 2015 WRX Gear Indicator issue- need help
I have a 2015 WRX 6MT, base model.
I bought the car new.
Just went over 70 K miles.
Something funky happened about 2 and months ago for the first time since I owned the car.
When I stepped on the brake, gear indicator will show "R" and the rear view camera will turn on and display on the info screen.
This happens only when I press on the brake, doesn't matter which gear I am actually in. (not counting when I am in reverse gear)
When I let go of the brake, the gear indicator will go back and show the ACTUAL gear I am in, and the info screen will go back to it's original state.
I have checked. While this is happening. The reverse lights does NOT turn on. Reverse lights only turn on when the car is actually in reverse gear.
The time between the first and the second time this happened was about a month. But since then it has happened more frequently.
Now it's happening almost daily. At random.
Has this happened to anyone else? Please help.
Thank you.
KoachKoKo is offline   Reply With Quote
Old 05-26-2018, 03:11 PM   #2
n2oiroc
Member#: 141952
18 golf arrrr!
id start by checking the brake switch wiring and look for any bad insulation.
n2oiroc is offline   Reply With Quote
Old 06-01-2018, 03:47 PM   #3
KoachKoKo
Member#: 456501
2015 WRX
WHITE
Thank you. I will have brake switch wiring checked.
Any one else encountered this issue?
Old 06-01-2018, 05:04 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suspect that the problem might due corrosion at a connection possibly in the rear area of the car. Voltage can cross over to places it shouldn't when corrosion gets in between the wire connections in a terminal. Check the connections in the rear area of the car to see if water has gotten to any of the connections. When you press the brake pedal the brake switch passes voltage on to the brake lights and if there is a bridge of corrosion between the brake light wiring and the rear camera then some power gets applied to the camera circuit also. If there is no corrosion issues then I would suspect something metal has worn through the wire insulation somewhere and the cross between the two circuits is happening that way.
Old 06-02-2018, 03:57 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Any windshield work recently? Stereo work?
CosmoTheCat is offline   Reply With Quote
Old 06-02-2018, 09:37 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Or, sunroof with clogged front drains?
Old 08-16-2018, 10:58 PM   #7
immortal
Member#: 408776
15 WRX EFR 7064
Hey ...help! why would the windshield or sunroof mess with the gear indicator?
Mine is stuck in reverse... i did just replace both windshields and actually deleted the sun roof - put a carbon roof in.
immortal is offline   Reply With Quote
Old 08-16-2018, 11:19 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Windshield leaks as well as roof drain leaks gets water inside the car. This leads to high humidity which can cause corrosion, shorts in wiring/connectors, etc.
All wiring, connectors, modules inside the car can have issues with water inside.
Old 08-17-2018, 01:36 AM   #9
immortal
Member#: 408776
15 WRX EFR 7064
Ahh...well, no water inside my car...it's been in my garage and I literally just put the carbon roof on and threw the windshields back on.
No corrosion either, I'm in California...keep everything nice and dry.
I'm going NUTS here...I have modified tons of electrical ****, so I know it's related obviously.
But I just can't pin point the problem. Stuck in Reverse on gear indicator, reverse lights on...whats funny is my fog light has a reverse light and it's tapped into the tail lights and the fog light reverse isn't on...
I'll paypal anyone $100 if they can help me diagnose and fix this... I got a multimeter and the skills, just not all the smarts here...
Old 12-25-2018, 07:22 PM   #10
rpanunzio12
Member#: 464796
Default Help same issue!
I am encountering the same issue, have not had time to look into yet but Iím thinking itís the GCS 4th brake light.
Have you figured this out itís gonna make me crazy!!
rpanunzio12 is offline   Reply With Quote
Old 12-26-2018, 07:01 PM   #11
Cougar4
Member#: 53443
Winestone
The trouble is either on the power side of the brake light circuit passed the brake switch or on the ground return side of the brake lights. I suspect the power side is more likely where the trouble is at. That would mean that power is somehow bridging to other circuit areas after the brake switch. I suggest you purchase a factory service manual for the vehicle so you can check out the wiring to the brake lights. The manual is your best friend for these kinds of troubles and can save you all kinds of time and money on electrical repairs.
Check connections for signs of corrosion and wires for insulation damage. The trouble is most likely under the dash but it could possibly elsewhere.
Old 02-12-2019, 05:49 PM   #12
Cbusaurus_wrex
Member#: 466792
2015 WRX Prem.
CBS
Thank you.
I have almost the same issue! My 2015 WRX's reverse camera and gear indicator are stuck in Reverse. Not when I press on the brake though. All. the. time. It used to just do it every once in a while. But now it's constant. Even worse, this has spiraled into my Hill Assist and Vehicle Dynamics to both be disabled. And now, today, my cruise control is disabled. So frustrating. Did you ever find a fix?
Cbusaurus_wrex is offline   Reply With Quote
Old 02-12-2019, 06:26 PM   #13
anarekist
Member#: 468117
2017 WRX
DMG
sounds like a short, drastic, but maybe take apart the whole dash and look for corrosion, lift the passenger side foot cover as a ton of wires move along there to the back too.
does your reverse lights come on too?
there's a subispeed button that activates the rear camera and reverse lights. for reference.
anarekist is offline   Reply With Quote
Old 02-12-2019, 06:29 PM   #14
Cbusaurus_wrex
Member#: 466792
2015 WRX Prem.
CBS
I should also add that I have the iJDMtoy F1 fog/reverse light. But I'm not sure that's the issue. It's been installed for a while. Even if it's shorting out, I can't imagine it having that large of an effect on my car.
Old 07-20-2019, 05:01 PM   #15
BlueBlur211
Member#: 464004
Iím going to bump this. This has been happening to my 16 STI for over a year. Iíve almost given up as I couldnít find any thread on this when my issue first started. I do have lots of aftermarket electrical stuff. IIRC my issue started after I installed the ijdmtoy rear fog/brake light. However I soldered my wires to the driver tail light and electrical taped everything as well. My issue only happens when the headlights are turned on and I press on the brake. I did not happen immediately after install btw. I also get hill assist and other things disabled.
BlueBlur211 is offline   Reply With Quote
Old 07-22-2019, 02:26 AM   #16
CosmoTheCat
Member#: 3409
98 My FMIC
The reason I asked about windshield work is due to the fact that there is wiring to the rearview mirror that can get shorted out, relates to the reverse circuit and I don't believe it's listed in the FSM. Check the wiring above the mirror, look for pinched wires.
Old 07-22-2019, 06:30 PM   #17
BlueBlur211
Member#: 464004
OP, you find a solution? Do you happen to have a jdm rear fog/brake installed? Another guy in this thread has one and has the same problem Iím beginning to thing itís the cause...
