Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 07-19-2019, 06:18 AM   #1
BajaTim
Member#: 472383
2005 Baja Turbo AT
Default Anyone running new Morimoto LED 2.0 H1?
Curious if fit and performance as stated.
BajaTim is offline   Reply With Quote
Old 08-04-2019, 02:45 AM   #2
BooSTIn_wrx
Member#: 365426
2002 Wrx
My suggestion to you is if this is your main driving beam, stay away from leds.
BooSTIn_wrx is offline   Reply With Quote
Old 08-12-2019, 02:47 PM   #3
BajaTim
Member#: 472383
2005 Baja Turbo AT
Frankly, I’m a little tired of being blinded by 50% of oncoming driver’s LEDs, while my own driving path is in shadows when using low beams; and only adequately illuminated when using my high beams which are set to a low beam pattern (beam approved by several local police officers as “fine” - and have never received a “flash).
Did you go and watch the Headlight Revolution review video? The LED beam “coverage” was identical to halogens - just brighter.
My question was to doublecheck this by asking current Subaru drivers on this forum - doublecheck ease of install/fit and result.
Old 08-18-2019, 08:07 AM   #4
fox252
Member#: 505416
Can't wait to be blinded by you someday
fox252 is offline   Reply With Quote
Old 08-18-2019, 08:10 AM   #5
fox252
Member#: 505416
I think my 2017 WRX Limited adjusts the LEDs downward to avoid blinding other drives.
Old 08-20-2019, 09:18 PM   #6
BajaTim
Member#: 472383
2005 Baja Turbo AT
That is a super idea if it is built-in.
Old 08-20-2019, 10:16 PM   #7
Windsor14STI
Member#: 505473
2014 STI
Plasma Blue Pearl
Sorry to post my own thread, but maybe it will help. I used morimotos, they are a nice beam.
http://https://forums.nasioc.com/forums/showthread.php?t=2907437
Windsor14STI is offline   Reply With Quote
Old 08-22-2019, 10:56 AM   #8
BajaTim
Member#: 472383
2005 Baja Turbo AT
No problem! In fact thanks!
So to sum up: if we install the Morimoto 2.0 as they come in the box, WITHOUT adding your resistor solution, our daytime running lights will NOT function 100% correctly? Will they function at all?
Personally I don’t see that as a problem - in high risk traffic I would just put in my low beams.
Thanks!
Old Yesterday, 08:17 PM   #9
Windsor14STI
Member#: 505473
2014 STI
Plasma Blue Pearl
They will be the same brightness as high beam all the time which is why folks complain about being blinded. If you unplug the factory resistor you can disable your DRLs and your headlights will otherwise operate normally.
