Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 08-10-2019, 09:54 AM   #1
stevevetter
Member#: 505136
Default Dead dead , not mostly dead, but totally dead
Okay, so I have an '03 wagon suffering from wanton and severe neglect. It hasn't been driven properly in 10 years and the last 5 have been having it moved 20-50 feet every 12 months or so. The story is long (donor to become a Factory Five 818 ... someday, I swear).
Anyway, this is the first sign that I cannot get ANY life to show from the car. I hook up my batter charger/starter (usually I do this, fill up the flat, ancient dry rotted tires, can get the car started and move it under its own power).
The weird part is I cannot get it to show any signs of life at all when I put battery charger to it. To be clear, yes all wiring and everything under the hood is in a state of advanced entropy. I do not expect anything normal here.
However, I can put positive directly to the starter and negative to the negative wiring (let's leave the battery out of the equation) and not only do I get no sign of life (no key in the ignition beeping, etc.) but it even makes my charger 'I'm charging' light click off.
To be clear, the car is doing this. Another example, I put charger to battery and the 'I'm charging' light goes on. THEN, if I complete what I hope to be a circuit (touch positive wiring to the post, and negative similarly) it actually makes the charger 'click off' (a protect mode I suspect.
It is almost as if it is the OPPOSITE of corroded cables/bad ground ... it's like it is a super-conductor to ground. Anyone EVER seen or heard of such a thing? Any sneaky way of getting around all the stuff I don't care about and just get power to starter, computer and minimally necessary items to make it possibly try to start?
BTW - no animals involved or nesting. Nothing except pure time (under a cheap cover) has happened since the last time I successfully got her to lite up.
Truly a puzzle here. Any ideas?
- Steve ... confounded and filled with shame
stevevetter is offline   Reply With Quote
Old 08-10-2019, 12:05 PM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Check the ground from the battery to the block. As well as the main fuse.
Old 08-10-2019, 03:13 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
From what you stated about the issue it sounds like you may have a defective battery. A shorted cell possibly. Have the battery checked out. Once that is done, and if you still have a problem with the power, check the smaller positive battery wire that supplies power to the distribution panel under the hood. Check the voltage on each side of the main fuse and make sure those connections are snug tight.
