Welcome to the North American Subaru Impreza Owners Club Monday October 21, 2019
Old 01-01-2003, 05:30 PM   #1
rwroth
Member#: 6431
Midnight Black Pearl
Default UTEC fuel tuning question
I've been trying to create a "stage 2+" map for these mods (91 octane):
STI Intercooler
Godspeed uppipe
TXS axel back, stock midpipe (with cat) and a Stromung catless DP
colder plugs
Hyperflow CAI
I started with the stage2 + uppipe map I found here as a reference. I cut timing by 1 across the board and have the same boost setup (open control). My question/issue is that whenever I'm in the 60% + TPS area (i.e. UTEC controlling) then I'm ALWAYS rich for AFR. I've even reduced the fueling to levels below the stage 2 setup and I'm still rich. Am I doing something wrong? I can't see how this is so rich....
Here a section of the log:
Code:
3611 -7.1 2.9 65 10 0 13.9 30.9 22 ECU. 0 ECU. 2.9
3703 -3.6 3 77 10 0 13.5 27.2 28 ECU. 0 76 3.1
3753 0.4 3.3 79 20 0 13.1 23.6 36 ECU. 0 75 3.3
3954 3.1 3.4 80 30 0 rich 18.6 47 ECU. 1 75 3.5
4065 5.3 3.5 80 50 0 rich 18.6 52 20.4 0.7 75 3.5
4214 7.4 3.5 93 50 0 rich 18.3 54 20.8 0.2 75 3.5
4351 9 3.5 93 60 0 rich 17.6 55 21.4 0.1 75 3.5
4522 9.4 3.6 94 50 0 rich 17.4 61 22 0.2 75 3.7
4662 9.2 3.7 93 50 0 rich 19.3 66 22.8 0.2 75 3.7
4816 9 3.7 88 50 0 rich 21.1 68 23.9 0.2 75 3.7
4945 8.6 3.7 79 50 0 rich 22.8 71 25.8 0.2 75 3.8
5081 9 3.8 55 0 0 rich 23.4 73 ECU. 0 ECU. 3.7
5224 9 3.7 39 0 0 rich 23.3 68 ECU. 0 ECU. 3.5
5274 6.6 2.9 11 0 0 rich 41.6 15 ECU. 0 ECU. 2.1
5184 2.1 1.9 0 0 0 rich 10.6 7 ECU. 0 ECU. 2
4975 -3.4 2 0 0 0 13.1 10.5 7 ECU. 0 ECU. 2
4675 -8.5 2 0 0 0 20.1 10.8 7 ECU. 0 ECU. 2
rwroth is offline   Reply With Quote
Old 01-02-2003, 06:23 PM   #2
paul99se
Member#: 17822
You are seeing normal behavior.
The factory 02 sensor is not accurate below 12.1, so the utec simply displays "rich" below that afr.
On my wideband-tuned map, Nathan targeted 12.1:1 (before spool up) to 10.6:1 afr, so if you see anything but "rich" at WOT with the UTEC logger, you are running WAY too lean.
Here is a very nice post from Nathan on the subject with target afr graphs:
http://forums.nasioc.com/forums/show...ghlight=target
-Paul
paul99se is offline   Reply With Quote
Old 01-02-2003, 06:25 PM   #3
rwroth
Member#: 6431
Default Thanks
Thanks - exactly what I was looking for. I didn't want to be too much on the rich side, but definately not lean!
UTEC Fuel Cutoff Question... striklybidnis Engine Management & Tuning 4 06-23-2003 08:01 PM
UTEC fuel tuning question Davenow Engine Management & Tuning 2 02-27-2003 01:46 PM
New UTEC software/tuning questions RIDEwrx Engine Management & Tuning 48 01-23-2003 02:20 PM
UTEC Fuel tuning question? muddywaters Engine Management & Tuning 2 01-17-2003 08:44 PM
TXS UTEC sowtware/tuning question RIDEwrx Engine Management & Tuning 1 01-12-2003 06:47 PM
