Welcome to the North American Subaru Impreza Owners Club Saturday September 26, 2020
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 12-07-2003, 04:07 PM   #151
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
1. As you change the ABC, you will need to change the CLB values as well. The comment regarding "safety" is probably not relevant, as this is more about CLB control, not "safety."
2. I'm interested in this as well. I don't recall reading that ABC opening is directly linked to temperature related boost variability.
Methinks boost tuning has multiple strategies that work, each has their advantages and disadvantages. Until TXS comes out with some form of temperature compensation, we'll just have to pick a strategy and adjust accordingly.
edit: own3d by the 7th page.
T-WRX is offline   Reply With Quote
Old 12-07-2003, 04:14 PM   #152
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default Humm ...
I can see a direct correlation between the CLB values and the BCS % use. I was pondering about your theory of not maxing out the BCS, which is reasonable, and thus I think I'll keep my values between 70-90 and just mess w/ the ABC. I figured since I've tested w/ 5 turns out that I got 15.5psi+/-, thus it can't be too far to obtain 16-16.5psi just by turning the ABC out more. I did a quick test and I can go as far as 10 turns out if necessary. I'll do some logging tomorrow and see what psi I get w/ turns out and go from there.
Right now I know w/ the current CLB vales of -100 from the previous ones posted I'm only utilizing the BCS 1.3% more than 70-90 since my values in Log 3 are 70-90 from 3250-5500rpm+. I'm sure turning the ABC will allow me to obtain 16-16.5psi before the 10th turn, somethign which I hope I will not have to use.
chuglobal is offline   Reply With Quote
Old 12-08-2003, 09:18 AM   #153
chuglobal
Member#: 10041
ISM
Default -100 w/ ABC @ 7 turns out
04706134 3505 +5.9 3.7 100 60 00 rich 91 325.00
04706534 3538 +9.6 3.8 101 80 00 rich 84 325.00
04706934 3591 +13.3 3.8 101 90 00 rich 81 325.00
04707334 3639 +15.5 3.8 101 90 00 rich 79 325.00
04707734 3695 +16.8 3.8 101 90 00 rich 82 325.00
04708134 3736 +17.0 3.8 100 90 00 rich 81 325.00
04708534 3753 +16.6 3.9 101 90 00 rich 79 325.00
04708934 3858 +16.4 3.9 101 90 00 rich 80 325.00
04709334 3827 +16.4 3.8 101 90 00 rich 86 325.00
04709734 3889 +16.1 3.9 101 90 00 rich 82 325.00
04710134 3935 +15.7 3.9 101 80 00 rich 86 325.00
04710534 3987 +15.7 3.9 101 80 00 rich 85 325.00
04710934 4006 +15.7 3.9 100 90 00 rich 79 325.00
04711334 4030 +15.9 3.8 99 90 00 rich 89 325.00
04711734 4065 +16.4 3.9 98 90 00 rich 86 325.00
04712134 4151 +16.6 3.9 98 90 00 rich 86 325.00
04712534 4177 +16.6 3.9 98 90 00 rich 81 325.00
04712934 4187 +16.8 4.0 98 90 00 rich 82 325.00
04713334 4290 +17.0 4.0 97 90 00 rich 72 300.00
04713734 4306 +17.2 4.0 96 90 00 rich 71 300.00
04714134 4363 +16.8 4.0 96 90 00 rich 77 300.00
04714534 4380 +16.8 4.0 96 90 00 rich 73 300.00
04714934 4432 +16.8 4.0 96 90 00 rich 72 300.00
04715334 4444 +16.4 4.0 96 90 00 rich 73 300.00
04715734 4480 +16.6 4.0 95 90 00 rich 74 300.00
04716134 4541 +17.0 4.0 95 90 00 rich 66 300.00
04716534 4547 +17.4 4.0 95 100 00 rich 69 300.00
04716934 4566 +17.6 4.0 95 90 00 rich 66 300.00
04717334 4636 +17.6 4.1 95 90 00 rich 70 300.00
04717734 4675 +17.4 4.1 94 90 00 rich 71 300.00
04718134 4741 +17.4 4.1 94 100 00 rich 68 300.00
04718534 4708 +17.2 4.1 94 90 00 rich 73 300.00
04718934 4768 +17.0 4.1 94 90 00 rich 78 300.00
04719334 4796 +17.0 4.1 94 90 00 rich 73 300.00
04719734 4837 +15.9 4.1 93 80 00 rich 78 300.00
04720134 4823 +15.9 4.1 93 80 00 rich 69 300.00
04720534 4901 +15.7 4.2 93 80 00 rich 74 300.00
04720934 4990 +16.1 4.2 93 90 00 rich 71 300.00
04721334 4967 +16.1 4.2 93 90 00 rich 77 300.00
04721734 5027 +15.5 4.2 93 80 00 rich 76 300.00
04722134 5096 +15.7 4.2 92 80 00 rich 71 300.00
04722534 5065 +15.3 4.2 91 90 00 rich 71 300.00
04722934 5058 +15.1 4.2 92 80 00 rich 76 300.00
04723334 5112 +15.7 4.2 91 80 00 rich 73 300.00
04723734 5159 +15.3 4.2 91 80 00 rich 81 300.00
04724134 5291 +15.3 4.2 90 80 00 rich 70 300.00
04724534 5324 +15.1 4.2 90 80 00 12.5 81 300.00
04724934 5257 +15.3 4.2 90 80 00 rich 84 330.00
04725334 5350 +15.9 4.2 90 90 00 rich 78 300.00
04725734 5393 +15.3 4.2 89 80 00 rich 74 300.00
04726134 5385 +15.7 4.2 90 80 00 rich 74 300.00
04726534 5393 +14.9 4.2 88 80 00 rich 83 320.00
04726934 5420 +15.3 4.2 88 80 00 rich 78 320.00
04727334 5473 +15.1 4.2 88 90 00 rich 89 320.00
04727734 5491 +15.1 4.2 87 80 00 rich 91 330.00
04728134 5491 +15.1 4.2 86 80 00 rich 86 320.00
04728534 5564 +14.9 4.2 85 80 00 rich 77 320.00
04728934 5537 +15.5 4.3 85 90 00 rich 79 320.00
04729334 5621 +15.9 4.2 85 90 00 rich 83 320.00
04729734 5611 +15.9 4.3 85 80 00 rich 85 330.00
04730134 5659 +15.5 4.3 84 80 00 rich 82 330.00
04730534 5659 +14.9 4.3 84 80 00 rich 88 320.00
04730934 5649 +14.1 4.2 84 70 00 rich 95 330.00
04731334 5659 +13.9 4.2 84 70 00 rich 89 330.00
04731734 5868 +14.3 4.3 82 80 00 rich 89 330.00
04732134 5797 +14.1 4.3 82 80 00 rich 94 330.00
04732534 5817 +14.7 4.3 82 80 00 rich 93 330.00
Old 12-08-2003, 09:23 AM   #154
chuglobal
Member#: 10041
ISM
Default Humm ...
It seems like w/ the ABC @ 7 turns out and the boost values dropped -100 from the beginning boost values, I'm hitting the mid 17+psi which is "not" what I want. However if I look at Log 3 it's having this problem around 3500-4750 so I just dropped the boost values another -25. The BCS seems in the middle range which is what I've been trying to do since the original post about the BCS. Technically I would increase the boost values from 5000-redline rpm too or it it better to run 15psi around 5K rpm and let it die down till redline?
Old 12-09-2003, 09:33 AM   #155
chuglobal
Member#: 10041
ISM
Default ABC @ 7 turnsout
03954934 3290 +4.5 3.6 100 50 00 rich 99 330.00
03955334 3310 +8.0 3.7 101 70 00 rich 89 330.00
03955734 3363 +11.3 3.7 101 80 00 rich 87 330.00
03956134 3360 +13.9 3.6 102 90 00 rich 83 330.00
03956534 3408 +15.5 3.7 102 90 00 rich 84 330.00
03956934 3508 +16.1 3.7 102 90 00 rich 71 300.00
03957334 3557 +16.4 3.7 101 90 00 rich 71 300.00
03957734 3580 +16.4 3.7 101 90 00 rich 73 300.00
03958134 3642 +16.4 3.8 101 90 00 rich 73 300.00
03958534 3691 +16.4 3.8 101 90 00 rich 73 300.00
03958934 3716 +16.1 3.8 101 90 00 rich 75 300.00
03959334 3770 +16.1 3.8 100 90 00 rich 72 300.00
03959734 3805 +15.9 3.8 99 90 00 rich 73 300.00
03960134 3844 +15.7 3.9 99 80 00 rich 77 300.00
03960534 3889 +15.7 3.8 98 80 00 rich 71 300.00
03960934 3944 +16.1 3.8 97 90 00 rich 69 300.00
03961334 3944 +16.4 3.8 96 90 00 rich 77 300.00
03961734 4011 +16.1 3.9 96 80 00 rich 79 300.00
03962134 4074 +16.1 3.9 95 80 00 rich 74 300.00
03962534 4105 +16.1 3.9 93 90 00 rich 69 300.00
03962934 4177 +16.4 3.9 93 90 00 rich 75 300.00
03963334 4219 +16.6 3.9 92 90 00 rich 75 300.00
03963734 4246 +16.6 3.9 92 90 00 rich 72 300.00
03964134 4290 +16.4 3.9 92 90 00 rich 61 275.00
03964534 4290 +16.4 4.0 92 90 00 rich 64 275.00
03964934 4357 +16.8 4.0 91 90 00 rich 60 275.00
03965334 4438 +16.6 4.0 91 90 00 rich 63 275.00
03965734 4468 +16.6 4.0 91 90 00 rich 62 275.00
03966134 4444 +16.8 4.0 90 90 00 rich 62 275.00
03966534 4510 +16.4 4.0 90 90 00 rich 63 275.00
03966934 4535 +15.9 4.0 90 80 00 rich 70 275.00
03967334 4572 +15.7 4.0 88 80 00 rich 65 275.00
03967734 4604 +15.9 4.0 87 90 00 rich 60 275.00
03968134 4636 +15.9 4.0 87 90 00 rich 66 275.00
03968534 4714 +17.0 4.1 86 90 00 rich 60 275.00
03968934 4721 +16.4 4.0 85 90 00 rich 68 275.00
03969334 4796 +16.1 4.1 85 80 00 rich 58 275.00
03969734 4830 +16.4 4.1 84 90 00 rich 60 275.00
03970134 4873 +15.7 4.1 84 90 00 rich 65 275.00
03970534 4880 +16.4 4.1 83 90 00 rich 62 275.00
03970934 4880 +16.1 4.1 82 90 00 rich 71 275.00
03971334 4967 +15.5 4.1 82 80 00 rich 65 275.00
03971734 4982 +16.4 4.1 82 90 00 rich 68 300.00
03972134 5065 +15.9 4.1 81 90 00 rich 80 300.00
03972534 5065 +16.4 4.1 80 90 00 rich 67 300.00
03972934 5104 +16.4 4.2 80 80 00 rich 80 300.00
03973334 5159 +14.9 4.2 80 80 00 rich 82 300.00
03973734 5151 +14.7 4.2 79 80 00 rich 72 300.00
03974134 5274 +14.9 4.2 79 90 00 rich 73 300.00
03974534 5341 +14.7 4.2 79 80 00 rich 76 300.00
03974934 5341 +14.9 4.2 78 80 00 rich 76 300.00
03975334 5307 +15.1 4.2 78 80 00 rich 70 300.00
03975734 5376 +14.9 4.2 77 80 00 rich 68 300.00
03976134 5402 +14.9 4.2 76 80 00 rich 80 300.00
03976534 5428 +14.7 4.2 75 70 00 rich 88 320.00
03976934 5500 +15.1 4.2 74 80 00 rich 78 330.00
03977334 5527 +14.9 4.2 74 90 00 rich 79 320.00
03977734 5546 +14.7 4.2 74 80 00 rich 89 320.00
03978134 5583 +14.7 4.2 74 70 00 rich 88 320.00
03978534 5952 +13.7 4.2 74 70 00 rich 87 320.00
Old 12-09-2003, 09:36 AM   #156
chuglobal
Member#: 10041
ISM
Default Boost 4-6K rpm
[0] [0] [0] [0] [0] [0] [0] [300] [300] [300] [300]
[0] [0] [0] [0] [0] [0] [0] [270] [270] [270] [270]
[0] [0] [0] [0] [0] [0] [0] [275] [275] [275] [275]
[0] [0] [0] [0] [0] [0] [0] [290] [290] [290] [290]
[0] [0] [0] [0] [0] [0] [0] [320] [320] [320] [320]
[0] [0] [0] [0] [0] [0] [0] [330] [330] [330] [330]
[0] [0] [0] [0] [0] [0] [0] [335] [335] [335] [335]
Old 12-09-2003, 09:36 AM   #157
chuglobal
Member#: 10041
ISM
Default 2nd-3rd Knock
04523734 3584 -4.3 3.3 102 10 00 13.5 106 300.00
04524134 3757 -0.6 3.7 101 30 00 rich 92 300.00
04524534 3903 +4.7 3.8 101 60 00 rich 76 300.00
04524934 4070 +9.2 3.9 102 80 00 rich 78 300.00
04525334 4284 +13.1 3.9 101 90 00 rich 73 300.00
04525734 4432 +14.9 4.0 101 90 00 rich 69 275.00
04526134 4681 +15.1 4.1 101 80 00 rich 72 275.00
04526534 4844 +15.7 4.1 101 80 00 rich 61 275.00
04526934 5112 +15.7 4.1 101 90 00 rich 72 300.00
04527334 5274 +15.5 4.1 100 80 00 rich 80 300.00
04527734 5402 +15.5 4.2 101 80 00 rich 79 300.00
04528134 5630 +14.7 4.2 100 80 00 rich 86 320.00
04528534 5817 +13.7 4.3 101 70 00 rich 96 330.00
04528934 6105 +13.5 4.2 100 70 00 rich 101 335.00
04529334 6218 +13.1 4.3 100 70 00 rich 91 335.00
04529734 6349 +12.7 4.2 100 70 00 rich 95 335.00
04530134 6447 +12.7 4.3 100 70 00 rich 96 335.00
04530534 6734 +12.5 4.3 101 70 00 rich 95 335.00
04530934 6775 +12.5 4.4 100 70 00 rich 95 335.00
04531334 6802 +11.0 3.9 11 00 00 rich 0 ECU.
04531734 6447 +5.7 2.0 0 00 00 rich 18 ECU.
04532134 6082 -0.2 2.1 0 00 00 17.1 20 ECU.
04532534 5678 -5.9 2.3 4 00 00 lean 19 ECU.
04532934 4990 -8.7 3.5 26 00 00 17.3 0 ECU.
04533334 4975 -5.1 4.0 74 10 00 rich 77 275.00
04533734 5073 +1.5 4.1 100 60 00 rich 73 300.00
04534134 5136 +7.8 4.2 102 80 02 rich 74 300.00
04534534 5151 +12.7 4.2 101 80 00 rich 71 300.00
04534934 5393 +15.3 4.2 101 80 00 rich 68 300.00
04535334 5359 +14.9 4.2 101 80 00 rich 81 300.00
Old 12-09-2003, 09:41 AM   #158
chuglobal
Member#: 10041
ISM
Default Humm ...
Everything seems fine as boost is between 16.1-16.4 however I did have a few spikes of 16.8-17psi. All of this was done at 39F degrees. I also got knock in a 2nd-3rd run w/ boost being fineat the 5000 rpm point? I've adjusted the boost map: 4250-4500rpm went from 275 to 270 and 5000rpm went from 300 to 390. Do you think it's necessary to adjust these two sets of rpm points or should I let it go? I know that sudden boost spikes will cause knock so I'm trying to stay under 16.5psi all 90% of the times.
Old 12-10-2003, 07:06 PM   #159
chuglobal
Member#: 10041
ISM
Default Humm ...
Is a good assumption to have 16psi average w/ a max boost of 16.5psi, thus I could run more timing?
Old 12-10-2003, 09:11 PM   #160
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Not necessarily.
I'd be really careful hitting 17psi on pump gas without tuning fuel. Even then, I'd be really careful hitting 17psi on the stock turbo. It can be done, but it's just not efficient. Pull some boost out - run 16 perhaps. Remember, when it's colder, the air is more dense. When the air is more dense, it's holding more O2 at a given boost level AND flow rate boosting your AFRs.
Also, don't tune for MAX boost in 3rd. If you do, I can practically guarantee you will knock in 4th and 5th, under higher loads. 17psi in 3rd can easily be 18 in 4th.
Since you're seeing knock, the last thing you want to do is add timing.
-Sean
big_adventure is offline   Reply With Quote
Old 12-11-2003, 04:13 PM   #161
chuglobal
Member#: 10041
ISM
Default Yo
I meant ... I do NOT want to see more than 16.5psi at any time. I can target 16psi in "4th;" I've beeing tunning all of my boost values in "4th" from 3K-5.5K rpm +. I've seen 17psi in cold weather ... 25-35 degree however it's only in a certain range. I can lower the CLB values. I think I'll try to hit 16psi and no more than 16.5psi at any time including 20s degree weather.
Old 12-11-2003, 06:23 PM   #162
big_adventure
Member#: 40501
One WheelSeanPower
That's a good plan - tune for that, get det free, and then tune from there.
Det free is the key, of course, you REALLY don't want a cylinder to let go.
-Sean
Old 12-11-2003, 07:58 PM   #163
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Made this a sticky....Plan on some cleanup of this forum soon...
Enought of....UTEC this ...Utec That...How do I tune a UTEC....just so you guys know.....FAQ's are coming.. so this forum can be worthwhile to nOObs and experts alike....
Thanks
Bill
2000 WRX/RS Utec tuned
Old 12-11-2003, 09:09 PM   #164
big_adventure
Member#: 40501
One WheelSeanPower
Excellent idea - it could definitely use some cleaning.
Lots of handy UTEC info in one place would fix lots of questions. Now all we need is loaner WbO2's in AutoZones nationwide.
-Sean
Old 12-11-2003, 10:42 PM   #165
chuglobal
Member#: 10041
ISM
Default Yo
1. Thanks Bill for making this stick. I'm hoping that my "million" questions will help someone in the future.
2. I just spent another 1.5hrs doing some more runs. I've changed my target ... I'm now shooting for 16psi w/ a max psi at 16.5psi; thus the psi range will vary between 15.7-16.1psi w/ spikes at 16.5-16.8psi. All of this was done at 35 degrees however if CLB works as it should; I should still see similar results during higher temperatures. I've been thinking more and more and I can see to inverse effect of "either" more timing or higher boost. I can see 16psi from 3500-5500rpm and of course it's not consistent. I'll post my CLB values tomorrow at work when I do hopefully my final run to confirm my boost values are correct for 16psi.
Old 12-12-2003, 08:15 AM   #166
chuglobal
Member#: 10041
ISM
Default Run 1
03043734 3408 +10.8 3.7 102 80 00 rich 88 330.00
03044134 3461 +13.9 3.6 101 80 00 rich 84 330.00
03044534 3439 +15.5 3.7 101 90 00 rich 74 310.00
03044934 3549 +15.9 3.7 101 90 00 rich 75 310.00
03045334 3576 +16.4 3.8 102 90 00 rich 76 310.00
03045734 3576 +15.9 3.8 102 80 00 rich 83 310.00
03046134 3683 +15.7 3.8 101 80 00 rich 76 310.00
03046534 3707 +15.7 3.8 101 80 00 rich 78 310.00
03046934 3783 +15.3 3.8 101 90 00 rich 77 310.00
03047334 3796 +16.1 3.8 101 90 00 rich 76 310.00
03047734 3840 +15.9 3.9 101 90 00 rich 80 310.00
03048134 3926 +16.1 3.8 101 80 00 rich 76 310.00
03048534 3940 +16.1 3.8 101 90 00 rich 77 310.00
03048934 3963 +16.4 3.8 101 90 00 rich 71 310.00
03049334 4006 +16.1 3.9 101 90 00 rich 84 310.00
03049734 4079 +15.9 3.9 101 80 00 rich 78 310.00
03050134 4105 +16.1 3.9 101 90 00 rich 75 310.00
03050534 4177 +16.1 3.9 101 90 00 rich 77 310.00
03050934 4224 +16.4 3.9 101 90 00 rich 78 310.00
03051334 4262 +16.4 4.0 101 80 00 rich 77 310.00
03051734 4262 +15.9 4.0 101 80 00 rich 69 280.00
03052134 4329 +16.1 4.0 101 90 00 rich 58 280.00
03052534 4357 +16.6 4.0 101 90 00 rich 64 280.00
03052934 4409 +16.6 4.0 101 90 00 rich 64 280.00
03053334 4426 +17.2 4.0 101 90 00 rich 62 280.00
03053734 4462 +17.0 4.0 101 90 00 rich 61 280.00
03054134 4498 +16.6 4.0 101 90 00 rich 63 270.00
03054534 4578 +16.8 4.1 101 90 00 rich 58 270.00
03054934 4629 +16.4 4.0 101 90 00 rich 62 270.00
03055334 4636 +15.9 4.1 101 80 00 rich 64 270.00
03055734 4610 +16.6 4.1 101 90 00 rich 60 270.00
03056134 4681 +15.9 4.1 101 90 00 rich 65 270.00
03056534 4721 +15.9 4.1 101 80 00 rich 62 270.00
03056934 4782 +15.9 4.1 101 80 00 rich 68 270.00
03057334 4768 +15.5 4.1 101 90 00 rich 61 270.00
03057734 4796 +16.4 4.1 101 90 00 rich 58 270.00
03058134 4837 +16.8 4.1 101 90 00 rich 58 270.00
03058534 4901 +17.4 4.1 101 100 00 rich 57 270.00
03058934 4960 +17.2 4.1 101 90 00 rich 61 270.00
03059334 4938 +16.4 4.1 101 80 00 rich 62 270.00
03059734 5005 +16.1 4.1 101 80 00 rich 69 270.00
03060134 4982 +15.3 4.2 102 80 00 rich 67 275.00
03060534 5027 +15.5 4.2 101 80 00 rich 63 275.00
03060934 5136 +15.5 4.1 108 80 00 rich 67 275.00
03061334 5216 +16.4 4.2 101 90 00 rich 58 275.00
03061734 5192 +17.0 4.2 101 100 00 rich 56 275.00
03062134 5200 +16.8 4.2 101 90 00 rich 80 300.00
03062534 5216 +17.0 4.2 101 80 00 rich 81 300.00
03062934 5265 +15.9 4.2 101 80 00 rich 75 300.00
03063334 5316 +15.1 4.2 101 80 03 rich 87 320.00
03063734 5350 +15.5 4.2 101 80 00 rich 71 300.00
03064134 5393 +15.3 4.3 53 00 00 rich 75 300.00
Old 12-12-2003, 08:16 AM   #167
chuglobal
Member#: 10041
ISM
Default Run 2
04032934 3336 +13.1 3.7 102 90 00 rich 85 330.00
04033334 3454 +15.5 3.7 101 90 00 rich 86 330.00
04033734 3523 +16.1 3.8 101 90 00 rich 81 310.00
04034134 3527 +16.4 3.7 101 90 00 rich 75 310.00
04034534 3576 +16.1 3.8 101 90 00 rich 77 310.00
04034934 3646 +16.1 3.8 101 90 00 rich 78 310.00
04035334 3736 +16.1 3.8 101 90 00 rich 76 310.00
04035734 3757 +15.7 3.9 101 80 00 rich 82 310.00
04036134 3840 +15.7 3.9 101 80 00 rich 79 310.00
04036534 3875 +15.9 3.8 101 90 00 rich 74 310.00
04036934 3916 +16.1 3.8 101 90 00 rich 76 310.00
04037334 3977 +16.6 3.8 101 90 00 rich 77 310.00
04037734 4040 +16.6 3.9 101 90 00 rich 79 310.00
04038134 4035 +16.6 3.9 101 90 00 rich 71 310.00
04038534 4166 +16.4 3.9 101 90 00 rich 76 310.00
04038934 4187 +16.1 4.0 101 80 00 rich 82 310.00
04039334 4219 +16.1 4.0 101 90 00 rich 72 310.00
04039734 4278 +16.1 4.0 101 90 00 rich 70 280.00
04040134 4351 +16.4 4.0 101 90 00 rich 63 280.00
04040534 4351 +16.4 4.0 102 90 00 rich 66 280.00
04040934 4480 +16.1 4.1 102 90 00 rich 63 280.00
04041334 4474 +15.9 4.0 101 80 00 rich 68 280.00
04041734 4504 +16.1 4.0 102 90 00 rich 58 270.00
04042134 4572 +16.6 4.1 101 90 00 rich 57 270.00
04042534 4597 +16.6 4.1 101 90 00 rich 65 270.00
04042934 4668 +16.8 4.1 101 90 00 rich 57 270.00
04043334 4694 +16.4 4.1 101 90 00 rich 59 270.00
04043734 4734 +16.6 4.2 101 90 00 rich 50 270.00
04044134 4755 +16.6 4.1 101 90 00 rich 57 270.00
04044534 4775 +16.1 4.1 101 80 00 rich 66 270.00
04044934 4866 +15.5 4.1 101 80 00 rich 67 270.00
04045334 4901 +14.9 4.1 101 80 00 rich 62 270.00
04045734 4894 +14.9 4.2 102 90 00 rich 61 270.00
04046134 5042 +15.9 4.1 101 90 00 rich 53 275.00
04046534 5012 +16.1 4.2 101 90 00 rich 68 275.00
04046934 5096 +15.7 4.2 101 80 00 rich 70 275.00
04047334 5184 +16.1 4.2 101 80 00 rich 62 275.00
04047734 5151 +15.5 4.2 101 90 00 rich 61 275.00
04048134 5167 +15.5 4.2 101 80 00 rich 80 300.00
04048534 5241 +15.9 4.2 101 80 00 rich 79 300.00
04048934 5282 +15.3 4.2 102 80 00 rich 79 300.00
04049334 5257 +15.1 4.2 101 80 00 rich 74 300.00
04049734 5376 +15.5 4.2 101 80 00 rich 83 320.00
04050134 5402 +14.9 4.2 101 80 00 rich 76 300.00
04050534 5564 +15.5 4.3 101 80 00 rich 83 320.00
04050934 5509 +15.1 4.2 101 80 00 rich 85 320.00
04051334 5973 +14.9 4.3 101 80 00 rich 85 320.00
04051734 5555 +14.9 4.2 101 80 00 rich 92 330.00
04052134 5668 +13.9 4.3 102 70 00 rich 89 320.00
04052534 5688 +14.1 4.3 101 70 00 rich 88 320.00
04052934 5668 +13.5 4.3 101 80 00 rich 89 320.00
04053334 5717 +14.5 4.3 101 80 00 rich 77 320.00
04053734 5717 +15.5 4.3 101 90 00 rich 84 330.00
04054134 5757 +15.3 4.3 101 80 00 rich 89 330.00
04054534 5899 +15.5 4.3 101 80 00 rich 89 330.00
04054934 5797 +14.3 4.3 101 70 00 rich 93 330.00
04055334 6006 +13.9 4.3 101 70 00 rich 92 330.00
04055734 5931 +13.7 4.3 101 80 00 rich 93 330.00
04056134 6060 +13.5 4.3 102 70 00 rich 94 335.00
Old 12-12-2003, 08:17 AM   #168
chuglobal
Member#: 10041
ISM
Default CLB Values w/ ABC @ 6 turns out
[0] [0] [0] [0] [0] [0] [0] [310] [310] [310] [310]
[0] [0] [0] [0] [0] [0] [0] [280] [280] [280] [280]
Old 12-12-2003, 08:39 AM   #169
chuglobal
Member#: 10041
ISM
Default Update
1. These are two runs which I did this morning to work. It's 28 degrees however "feels" like 20s according to the weather channel. It seems like the most variant occurs between 4254-5250 rpm; if you look at the two runs the first run always seems to have a "higher" boost spike than the second run. This seems consistent per my "many" runs during testing.
2. I'm running 16psi @ 3500 - 5250 rpm then 15.5psi @ 5500-6000 and finally <14psi till redline. I'm trying to target 16psi w/ a expected variance of 15.5-16.5 psi. I'm confortable w/ these numbers since I know it is "cold" outside. Do you think it's necessary to fine tune lower the boost values even more in the 4250-5250 rpm range considering the fact that it's cold outside? I could lower the boost values @ 4250 from 80 to 75 and @ 4500 rpm from 70 to 65?
3. The BCS cycle are between 50-90 which is fine as compared to the previous 133. The boost values which I posted are from 3500-6000rpm.
4. I just hope the CLB does what it's supposed to do when it gets "warmer."
Old 12-12-2003, 09:27 AM   #170
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
When it get warmer you may need to make a boost map with slightly higher values.
I'm really surprised you don't get more spiking with your ABC out 6 turns. I've always been advised to only turn it out 1-2 turns and then tune the boost map from there.
mbiker97 is offline   Reply With Quote
Old 12-12-2003, 09:51 AM   #171
chuglobal
Member#: 10041
ISM
Default Yo
When I first started in CLB ... I was tunning the CLB values w/ the ABC @ 1.5 turns out. However my BCS was maxed at 133 which someone suggested was "not" a good idea. Thus I first adjusted the CLB values to between in the BCS range of 50-90, then adjust the ABC to obtain 16psi, then finally made small adjustments to the CLB values. Also CLB is "supposed" to NOT be affected by temperature changes thus I should still see 15.5-16psi when it gets warmer.
Old 12-12-2003, 12:57 PM   #172
big_adventure
Member#: 40501
One WheelSeanPower
What about your first run of those three? You were over 17psi for a lot of it. You got 3 knock events in the cycle at 5300, with no shifting or throttle modulation at all.
Rather than open the ABC 6 turns, you might want to try adjusting the wastegate actuater arm. There is a c-clip you can pop off, and then turn the arm to tighten it. Search on wastegate flutter, and spot the really long thread. Nobody mentions using this solution for your issue, but your boost looks really inconsistent. You can probably tighten it a couple of turns and close that ABC back down a bit.
I wouldn't want to drive my car if I knew it would det somewhat seriously on 1 out of 3 runs.
Good luck...
-Sean
Old 12-12-2003, 01:11 PM   #173
chuglobal
Member#: 10041
ISM
Default Yo
I've actually heard that the ECU reflash fixes some of the knocks in the higher rpm range. I'm assuming the knock would be fixed wither w/ that method or adjusting the A/F on a dyno w/ a WB O2 sensor. It onlys happens in a certain range and if I go WOT in 4th starting in 3.5rpm. During my normal daily driving I get "0" knocks ... if I get aggressive which happens many times, I many get knock but it's because ofthe A/F ... at least that's what I'm puzzling together. If I continue to get knock in normal WOT "after' tunning, then it'll be a problem.
Old 12-12-2003, 02:32 PM   #174
big_adventure
Member#: 40501
One WheelSeanPower
Well, as stated several times before, you need to get that fuel curve slammed out. I'd pull out a pound of boost just to be on the safe side until you do.
If you find a tuner or a friend with a WbO2, you don't need a dyno to do that. You can road-tune the fuel-curve pretty darn well, especially at stage 2.
Or, you can buy a decent WbO2 for $300 - less than any reflash!
Seriously, just look at the cost of the time you've spent on this - it seems like tens and tens of hours.
Not to mention the cost of an engine tear-down if a ring land lets go on you. Don't go there, if you can help it.
I'm running det-free with great power on a UTEC alone - no reflash required. If you've already spent the dough on a UTEC, why would you consider a reflash, especially at stage 2? Or are you talking about a Subaru of America recall-type reflash?
What it comes down to: you won't be able to feel a half-pound of boost. Air is denser at 30F than 50F than 70F. 17psi at 60F is NOT the same thing as 17psi at 30F. Much more O = leaner AFRs, with the same boost and everything. Tune safely if you want that car to last. And tune fuel before doing anything else.
-Sean
Old 12-12-2003, 02:56 PM   #175
chuglobal
Member#: 10041
ISM
Default Yo
1. Yes, I've spent hour and hours learning about the whole ECU tuning. It's actually quite fun and educating.
2. Yes, I was referring to the "free" Subaru ECU reflash.
3. I figured boost was independant of tuning the A/F, it should still remain the same? Also the car should run "leaner" at cooler temperature since it's more dense. Thus the reason for the lower boost values so if I'm shooting for 16psi in cold weather it should be even safer when the temperature increase.
UTEC fuel tuning question Davenow Engine Management & Tuning 2 02-27-2003 01:46 PM
New UTEC software/tuning questions RIDEwrx Engine Management & Tuning 48 01-23-2003 02:20 PM
UTEC Fuel tuning question? muddywaters Engine Management & Tuning 2 01-17-2003 08:44 PM
TXS UTEC sowtware/tuning question RIDEwrx Engine Management & Tuning 1 01-12-2003 06:47 PM
UTEC fuel tuning question rwroth Engine Management & Tuning 2 01-02-2003 06:25 PM
