01-14-2017, 03:03 PM | #1 |
Member#: 130729
NWIC
Vehicle:2004 WRX JBP |
EJ207 in WRX flashing CEL
Hi, so the story is that i swapped an EJ207 into a 2004 WRX about 2 years ago. Due to some circumstances i was unable to get it tuned at the time but it's crunch time now so i made a tuning appointment at PRE Racing for Monday. I mean to tow the car down there and finally get it tuned as it's been sitting for that long, 2 years.
Today i got it all prepped and pulled out of the garage. It had run fine plenty of times prior and still was running well. I decided to take it for a short 5 mile drive to get a feel for it. about 2 miles from home i saw the CEL start to flash. Mind you this is the same gas that was in it when i swapped the motor and it has a base tune on it currently from IA Performance thats very detuned. The CEL would flash then go away. Didn't do it when just sitting idling. I've read that flashing CEL means misfire. Could it be the gas, or could it be a seal went bad from it sitting too long? I'm planning to pull the plugs and see what i can find out from them. Also planning to pump all the gas out and refill with fresh stuff. Any input is welcome, i'm worried i waited too long and something went bad in the engine.
01-14-2017, 03:09 PM | #2 |
Member#: 456937
Would start with gas before going to all that trouble.....should b a drain plug on each side of the tank on the bottom....at least mine does
01-14-2017, 06:54 PM | #3 |
Member#: 42548
Vehicle:2020 STI Series Whit Ceramic White |
2 years of sitting gas = potential problem for sure. as dan mentioned, start there as it's likely your problem.
01-14-2017, 09:39 PM | #4 |
Member#: 430207
MWSOC
Vehicle:2002 WRX Wagon Sedona Red |
Misfire on all 4 cyl. When I spun a bearing my car sat for a year before I got it running. Old gas caused 4 misfires and a blinking CEL. New gas made it all go away.
01-15-2017, 01:43 PM | #5 |
Member#: 130729
NWIC
It didn't go away with new gas. Seemed to at first, got it to operating temp, went another few miles and it started again.
Could the plugs be fouled or corroded from sitting? Only one way to find out I guess right... |
01-15-2017, 02:58 PM | #6 |
Member#: 130729
NWIC
Pulled the plugs and have oil on both passenger side plugs. What are possibly scenarios besides blown seal?
01-15-2017, 04:01 PM | #7 |
Member#: 130729
NWIC
I hope to god i'm this stupid.
I had it in test mode, aka, the 2 green plugs connected. Now i just have to hope i didn't do any damage. Still doesn't explain the oil on the 2 plugs though. Any input? I feel like a complete jackwagon. |
01-17-2017, 09:56 PM | #8 |
Member#: 130729
NWIC
That was it.
Car dyno'd 304 hp 300 tq. |
01-17-2017, 10:29 PM | #9 |
Member#: 42548
Glad to hear it was an easy fix!
01-17-2017, 10:51 PM | #10 |
Member#: 130729
NWIC
Only after i put fresh plugs in. LOL
Oh well, i'm sure it wasn't a bad thing to have nice new plugs for tuning. |
