#1 |
Member#: 156347
Vehicle:1997 Milano EK 2004 Platinum Wrex |
![]() Went to warm up the car leaving work this morning the cabin smelt fine and when i was pulling down my street and parked in my driveway i smelt fuel, but didnt think anything of it since my dad was warming up his car and could be exhaust fumes. Then smelt it again while the car was idling going thru the McDs drive thru. Went away after driving. Then tonight heading to work I smelt this again and goes away when driving but when idling still at one spot for a bit the smell comes back.
Just got this problem this morning and now researching it through this thread http://forums.nasioc.com/forums/showthread.php?t=131755 . Have any of you had this problem and have you had it taken care of? if so who did it and were you able to get this covered? |
#2 |
Member#: 170059
RMIC
Vehicle:04 STi Stg 3ish? BUNANA KING! |
![]() i kinda searched on this awhile back i found something about there not being enough back pressure in the exhaust can cause it ill try to find the thread again
#3 |
Member#: 156347
![]() i know about the downpipe thing, i just got back from lunch and it smells like fuel even after having the car fully warmed up. I got back here to work and popped the hood and smelt a fuel odor by the passenger side.
#4 |
Member#: 150315
RMIC
Vehicle:2009 Legacy |
![]() i also have this smell. only when it is cold
#5 |
Member#: 143264
RMIC
Vehicle:2006 WRX TR Obsidian Black Pearl |
![]() Does the 04' WRX stillhave the fuel filter in the engine bay? I think that in 05+ they put the fuel filter in the tank, not too sure. If so change that out as well as check your hose lines. As the temp. gets colder the hoses harden, as you drive the car the lines get hot then cold then hot then cold, this flux in temperature can crack hoses and you might find some lines need to be replaced. I have seen a couple of the 02-03 wrx's needing hoses replaced because of this.
#6 |
Member#: 125937
RMIC
Vehicle:03 WRX I do not like your tweed, chap. |
![]() I've had to replace hoses twice in my engine bay. But it's like a buck for a fuel hose.
#7 | |
Member#: 156347
![]() only when youre stopped as well?
![]() which hoses? |
#8 |
Member#: 132244
NWIC
Vehicle:2006 OBP WRX 2006 BMW 325i |
![]() I just had this same issue on my 06. It turns out that it was the roll over valves (2 each on top of the gas tank) that was the porblem. I did have a cel. After the mechanic dropped my gas tank he found that both roll over valves had the stems broken/cracked and was seeping out gas fumes. evidently subaru has had a rash of these and parts are on backorder. I was lucky and mine only took about 2 weeks to come in and about 4 hrs of labor to fix.-john
#9 | |
Member#: 156347
![]() Quote:
#10 |
Member#: 144219
Vehicle:2007 WRX Urban Gray |
![]() Have an 07 WRX and just threw the CEL, p456. Took it in to Subaru of LV and wanted to charge me $675 to drop gas tank and rear diff +parts. Hope this is the problem, they said it was a rear leak on top of tank, probably the valves. Gonna pick up car and drop tank with my bro. Helps explain gas smell. Oh yeah, out of warranty, 52k.
#11 |
Member#: 122043
MWSOC
Vehicle:n/a n/a n/a |
![]() i belive it is under the intake fuel line with clamps
#12 |
Member#: 185764
RMIC
Vehicle:06 大集 青い |
![]() well why dont you just stop putting gas in it
Duh... ![]() ![]() |
#13 |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
![]() My advice.... Don't wmoke in the car
#14 |
Member#: 132244
NWIC
![]() hahaha yeah it used to drive me crazy, almost smelled like an open container of gas sitting in the trunk
#15 |
Member#: 99397
RMIC
Vehicle:15 WRX, 83 DR30, 93 R32 GTS-T, 93 R32 GTR |
![]() There is a fuel line that leaks on the passenger side. its the fuel line that is under the turbo coolant resivour between the 2 intake manifold runners and back a little bit, i just had to fix it on my friends 02 wrx. I had to pull the manifold off and ended up finding a cracked hose on one and also a loose clamp. so i replaced the hose and all the clamps on the fuel rails. took me aboue 1.5-2 hrs.
![]() Im assuming this is the same problem as yours because its a common problem. There is a thread somewhere called "Raw fuel smell log" most everybody has the same problem. But i see you have already found it. |
#16 |
Member#: 143264
RMIC
![]() Wow BHH you can pull a intake manifold off and put it back on in an hour and a half? Why hasn't Solid hired you?
#17 |
Member#: 175664
RMIC
Vehicle:03 WRX FP Green/Built&Cam'd 2.5L |
#18 |
Member#: 99397
RMIC
![]() The 2.0L intake manifolds are allot easier than the 2.5L
#19 |
Member#: 143264
RMIC
![]() even still, I remember saying with my 05' WRX that it would take the whole day to do the Manifold so he could install my topfeed injectors.
YOUR AMAZING BHH!!!! |
#20 |
Member#: 99397
RMIC
#21 |
Member#: 143264
RMIC
![]() ^^^ I hate you
#22 |
Member#: 125937
RMIC
![]() The fuel filter ones. Both sides cracked, but the front one wore more because the FMIC pipe sorta smashes it.
#23 |
Member#: 1983
RMIC
Vehicle:2008 STi Dark Grey Metallic |
![]() I had this problem with my '02 WRX. It was the fuel rails that needed to be replaced. After that it never happened again... at least while I owned the car. SOA covered it, but I was still under warranty.
#24 |
Member#: 156347
![]() ^^^ who did you take it to?
#25 |
Member#: 1983
RMIC
Raw fuel smell/leak when cold, where did Chicago ppl get theres fixed? | MF-DIF | Mid West Subaru Owners Club Forum -- MWSOC | 74 | 02-14-2009 05:24 PM |
Fuel smell while heater is on. | skoobidoo | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 12-09-2005 11:08 PM |
replacing brake lines on wrx, anything i need to watch out for? | wrxracer55 | Brakes, Steering & Suspension | 8 | 11-02-2003 10:00 AM |
Coolant Leak near Turbo on WRX | NewSuby | Service & Maintenance | 2 | 03-08-2003 01:21 AM |
Goodridge SS vs Stock Brake Lines on WRX | ITWRX4ME | Brakes, Steering & Suspension | 15 | 12-11-2002 07:23 AM |
