Welcome to the North American Subaru Impreza Owners Club Wednesday September 27, 2023
Old 01-21-2023, 05:12 PM   #101
BoxerTorres
Member#: 531399
2018 WRX
Ice Silver Metallic
Originally Posted by protivakid View Post
I added a wire to the middle pin slot of the door switch. As far as which pin I used, at the end of the project I had a bunch of spare pins from everything I bought and one happened to be close visually to the oem pins so I used that. Sorry I don't have a specific answer.
Thanks. I decided to just ground the wire. Now the unit shuts off as soon as I shut down the ignition, whether or not I’ve opened the door.
Sent from my iPhone using NASIOC
BoxerTorres is offline   Reply With Quote
Old 01-23-2023, 12:50 PM   #102
protivakid
Member#: 265148
2016 WRX
That works too as long as you keep the engine running when a good song is on
protivakid is offline   Reply With Quote
Old 03-09-2023, 11:29 AM   #103
Lucky0373
Member#: 533375
2016 WRX
Grey
Is it possible to have a radio with nav, but not with HK system?
Lucky0373 is offline   Reply With Quote
Old 03-10-2023, 03:17 PM   #104
protivakid
Member#: 265148
2016 WRX
I wouldn't recommend it unless you get them real cheap, but if you wanted to buy a HK Map WRX Radio, and a non-HK Map Outback radio, you could try to swap the HK radio face into the Outback radio base. The connector is the same but I'm not sure if they are pin compatible. May work great and do what you want, may not work at all, or may damage the units.
Old 05-15-2023, 01:39 PM   #105
Koxem
Member#: 534279
Hello. I have a Forester 2017 touring. there is a map and H.K. is it possible to put it without a map? be sure to change the amplifier.
Koxem is offline   Reply With Quote
Old 05-16-2023, 10:29 AM   #106
protivakid
Member#: 265148
2016 WRX
The Map radio would probably be simpler but you could remove the amp and re-wire to get a Phone radio working in there. This would be uncharted territory.
Old 05-16-2023, 12:33 PM   #107
Koxem
Member#: 534279
thanks for the answer. we will experiment
Old 06-12-2023, 02:35 AM   #108
Lucky0373
Member#: 533375
2016 WRX
Grey
(There's probably something on this that i missed), but would this also be a similar way to using a 2019 STi radio to a 2016 WRX or would it be entirely different?
(the 2019 STi radio does not have HK and map)
Old 06-13-2023, 08:53 PM   #109
protivakid
Member#: 265148
2016 WRX
The 2019 STI Radio CAN have HK & Map if the buyer got the Limited model. If they went with a premium then correct you would have the more basic "Phone" button radio.
If you are swapping a 19 prem wrx radio in to a 16 prem wrx then the swap should be pretty easy, would need a few things like the door switch wire and the newer usb jack but the radio itself might work with the existing harness.
Old 06-17-2023, 12:29 AM   #110
Lucky0373
Member#: 533375
2016 WRX
Grey
would it also be the same fore a 19 base Sti to a 16 base WRX?
Old 06-22-2023, 08:38 AM   #111
protivakid
Member#: 265148
2016 WRX
You'd want to add the USB and the wire to the door switch but otherwise it may swap right in to your 2016
Old 08-04-2023, 11:16 AM   #112
Declan99
Member#: 534914
Many thanks for putting this information out there. Been wanting to do this for awhile now, hoping to find a good price on the head unit.
Declan99 is offline   Reply With Quote
Old 08-04-2023, 01:10 PM   #113
RRATS
Member#: 510835
2020 OB Touring XT
Crystal Black Silica
I sent you a message
RRATS is offline   Reply With Quote
Old 08-14-2023, 04:11 AM   #114
RRATS
Member#: 510835
2020 OB Touring XT
I have 2 used radios and 1 new amp if anyone is interested in doing this.
Amp 86221VA050
Radio 86471VA630
Radio 86471VA730
Old 08-29-2023, 01:26 PM   #115
1FSTREX
Member#: 109348
2018 STI Limited
ISM
Hey all, big thanks for this post and the plethora of information. I will say that the post can be a bit overwhelming and it's actually a LOT easier than anticipated. All you need is a CarPlay (map button) Harman Kardon head unit, new 2.1A USB port, the matching Harman Kardon amp, and you can buy every adapter you need from Auto Harness. They were super helpful and got me everything I needed for $160.
I do have one problem that I am hoping someone might be able to shed some light on. After I installed all the new parts, everything fired right up. I went through my functions checks and found one problem:
1. The driver side switch for the passenger window does not work now.
2. The passenger side switch for the window works BUT the auto up/down does not work.
Note: When I first checked the windows, the driver side switch for the driver window worked but the auto up/down did not work. After trying a few times (~30 seconds), the auto up/down featured started working. Its been a few days now and problems 1 and 2 are still persisting.
1FSTREX is online now   Reply With Quote
Old 09-01-2023, 02:08 PM   #116
protivakid
Member#: 265148
2016 WRX
This was all uncharted territory when I completed the swap 3 years ago. Care to share a pic of the harness they pre-built for you?
Not sure about the window issue, did you tap into any of those wires?
Old 09-05-2023, 02:47 PM   #117
1FSTREX
Member#: 109348
2018 STI Limited
ISM
Dude, what you accomplished and gave to the community was phenomenal! I was so excited when I found your post and that I could add CarPlay to my STI. I sincerely appreciate it!
Unfortunately, I did not take any pictures of the harnesses, but I reached out to Auto Harness and Brian knew exactly what I needed and I think they are all listed on the website as well.
Dang, I was hoping maybe somebody might have had the same issue as me with the windows. I did not tap into anything, everything was plug and play for me. So strange. I am going to try and uninstall everything and reinstall to see if that helps. I am wondering if I maybe accidentally pinched a wire when I was putting the head unit back into the dash?
Old 09-06-2023, 11:37 AM   #118
protivakid
Member#: 265148
2016 WRX
The only thing I can think of, is what does Brian's harness connect to in order to determine when the driver's door is opened to shut the radio off?
Old 09-06-2023, 01:47 PM   #119
1FSTREX
Member#: 109348
2018 STI Limited
ISM
He uses wire that you ground out. Just the plug goes into the back of the HU, has a black wire running off of it, and I just soldered on a connector and grounded it to the radio bracket.
But do you think that would cause the passenger side window switch not to work?
Old 09-11-2023, 09:03 PM   #120
1FSTREX
Member#: 109348
2018 STI Limited
ISM
Encase anyone runs into this problem too, there was no issues with the installation, wiring, or instructions provided by the OP. Super simple fix, because the battery was unhooked for so long, the window module needed to be reset.
1. Car set to ON but not started
2. From the side that is not working, roll window down half way.
3. Roll window all the way up and hold for one second.
4. Roll window all the way down (non-auto, single click)
5. Auto roll the window back up.
