Welcome to the North American Subaru Impreza Owners Club Saturday September 30, 2023
Old 04-06-2023, 02:57 PM   #1
tspunk
Member#: 345444
2013 Impreza 5-door
Default Anyone ever have loose steering issue?
Last year my Subaru (2012 2.0i Sport Premium Hatchback) started randomly getting loose steering only when turning left.
Resistance of the wheel will be the same turning left and right, and then all of a sudden, turning left has almost no resistance.
Mechanic tried to look and said tie rods are fine and can't tell what's going on.
I'm going to have another mechanic look at it and see if he can dig deeper.
Basically, sometimes while I am taking a left turn, holding the steering wheel at regular resistance for that turn, all of a sudden it breaks loose so I accidentally turn even more. A little scary.
tspunk is offline   Reply With Quote
Old 04-06-2023, 03:01 PM   #2
19std
Member#: 510366
I have a 2012 that has had lots of stuff wrong with it, all wheel bearings were crap from factory, fb oil consumption recall.
But steering is perfect. 180k going strong.
Edit: base sedan manual if that helps...
19std is online now   Reply With Quote
Old 04-08-2023, 01:17 PM   #3
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
That car has electric power steering. When you have that issue do you ever see a "steering wheel" light on your instrument cluster? Are your check engine/ABS lights on? It could simply be your steering angle sensor going bad, but you need to find a shop that has ability to pull more than just basic OBDII codes/data.
Old 04-10-2023, 03:47 PM   #4
tspunk
Member#: 345444
2013 Impreza 5-door
hi, nope, nothing on my dash at all. it's so weird. i'll ask about steering angle sensor. i was thinking of telling him to go ahead and replace the tie rods too just in case.
Old 06-01-2023, 07:59 AM   #5
B1GpapaN3CR0
Member#: 534434
Might be worth looking at the sway bar end links
B1GpapaN3CR0 is offline   Reply With Quote
