Welcome to the North American Subaru Impreza Owners Club Saturday September 30, 2023
Old 06-06-2023, 05:39 PM   #1
RiasOutbackXT
Member#: 534483
2005 Outback XT
Default 05 OBXT. Will only rev to 2k rpms.
Let me start of by saying this is not a build. I am just trying to get my car back into a drivable state so I can use it again. The car has been sitting for about 6 months. I have replaced the clutch, flywheel, pressure plate, release bearing, CV axles, spark plugs, ignition coils, ignition coil connectors, coolant and fuel hoses as well as the throttle position sensor. There are now no codes showing when I do a scan. No vacuum or coolant or fuel leaks. I do not have boost leak either. Before replacing the TPS the vehicle would not start and show a code for it. I took it off and say that it was completely broken. Replaced with brand new and made sure it works. Car turns over and stays running. Did idle relearn process (couldn't take for test drive) and now while the car is running if I apply throttle it does not go over 2000 rpm. Please help me figure out what is going on. If there is someone that has created a thread to fix this problem please link it. I could not find anything when I was searching. TIA.
RiasOutbackXT is offline   Reply With Quote
Old 06-07-2023, 07:38 PM   #2
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Did you replace the TPS with an OEM sensor?
I've heard of this happening from a clogged cat (possibly your up pipe).
So no matter what, it won't go above 2k rpms?
Did you happen to connect the green test connectors?
monkeyposeur is offline   Reply With Quote
Old 06-10-2023, 12:17 AM   #3
RiasOutbackXT
Member#: 534483
2005 Outback XT
It is not an OEM TPS, but the code disappeared after replacing it. No matter what it will not go above 2k rpm. I am thinking my next step is cleaning/replacing my throttle body.
Old 06-10-2023, 12:46 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
like what is it doing when it hits 2000? can you make a video? that would help alot
Old 06-12-2023, 02:42 PM   #5
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
I'm very weary of using aftermarket sensors.
