Welcome to the North American Subaru Impreza Owners Club Wednesday September 27, 2023
Old 05-31-2023, 12:25 PM   #1
barneymcveigh
Member#: 533950
Default Positive Battery terminal
So the positive battery terminal is worn out and although the nut is all the way tight its still loose on the post. SO much so that sometimes my car wont start and it has even killed the car mid drive. My question is can i replace with just any generic terminal kit from my local auto store or do i need a specific subaru one. car is a 2015 wrx base for what its worth.
barneymcveigh is offline   Reply With Quote
Old 05-31-2023, 12:41 PM   #2
19std
Member#: 510366
Bro i got a piece of lead from advanced oreileys zone.
Theyre called terminal adapters or caps whatever.
If it doesnt fit or is too big or what ever just crush it on there with pliers. Cost like 3 bucks.
19std is offline   Reply With Quote
Old 05-31-2023, 01:00 PM   #3
barneymcveigh
Member#: 533950
ok I guess i was just overthinking it lol. thanks
Old 05-31-2023, 02:00 PM   #4
19std
Member#: 510366
No worries man, i was in exact boat your in, my replacment battery terminal was a liiitle smaller than stock terminal, so would periodically short out, I got lucky and just found those lead caps.
Stay away from copper or other metals than lead due to potential galvanic corrosion issues.
Old 06-01-2023, 08:46 AM   #5
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
81608YC000 Subaru factory terminal. About $12-$13. Takes a 12 mm socket/wrench, clean the post and you're done. No cutting the battery cable or rigging the cable end under the wire clamp bolt on a generic lead replacement.
BTW: if you bolt the cable on the wire clamp bolt on a generic lead replacement and the terminal doesn't use a steel nut on the underside (most don't) then the lead WILL strip and the cable will eventually loosen. That's why I suggest spending a few dollars more and use OEM.
Elbert Bass is offline   Reply With Quote
Old 06-01-2023, 10:30 AM   #6
19std
Member#: 510366
^^^ interesting point, yeah makes sense. Probably cheaper in the long run, unless your stranded, which happened to me, so nice "to get you home" repair.
In my case my lead in my bearings let go well before the 3 dollar cap.
Old 06-07-2023, 05:54 PM   #7
barneymcveigh
Member#: 533950
thanks I just ordered this part
Old 07-17-2023, 03:32 PM   #8
benhatchins
Member#: 534856
It is generally recommended to use a specific terminal kit designed for your make and model of vehicle. While generic terminal kits from local auto stores may fit and function, using a terminal kit specifically designed for your car ensures the best fit and compatibility.
benhatchins is offline   Reply With Quote
