Welcome to the North American Subaru Impreza Owners Club Wednesday September 27, 2023
Old 03-07-2003, 07:15 PM   #1
NewSuby
Member#: 15363
2002 WRX Sedan
Default Coolant Leak near Turbo on WRX
Hi All,
I haven't posted in a while. I've got a 2002 WRX with Catback, Uppipe and Intercooler. I've got some sort of coolant leak near or on the turbo. When the car gets good and warmed up the coolant leaks and instantly goes to steam (looks like the car is overheating as steam poors out of the passenger side of the hood and hood scoop). I can tell its burned coolant by the smell. I looked under the hood and can see the steam coming from the area near the turbo/downpipe. I assume its one of the coolant lines going to the turbo, but I can't tell from above.
Has anyone else experienced this problem? Any suggestions on where to start to fix this? My car has approximately 30,000 miles.
Thanks,
EJ
NewSuby is offline   Reply With Quote
Old 03-07-2003, 11:44 PM   #2
Hawk296
Member#: 14555
1995 Impreza L
Baja
ide try tightening the the coolant lines on the turbo and i that didnt work then replaceing the gaskets. from there thats what ide try first from your description
Hawk296 is offline   Reply With Quote
Old 03-08-2003, 01:21 AM   #3
NewSuby
Member#: 15363
2002 WRX Sedan
Thanks, I'll give it a try.
EJ
Coolant leak after turbo Install 855m0n0 South East Region Forum 5 03-27-2018 07:09 AM
Coolant Leaking from turbo deathskrye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-26-2008 09:10 PM
coolant leak after turbo install preacher#1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-12-2007 01:36 AM
coolant leak after turbo install Wookie768 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-02-2007 05:06 PM
06 oil leak near turbo NextCar Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-23-2006 08:45 PM
