Welcome to the North American Subaru Impreza Owners Club Wednesday September 27, 2023
Old 10-31-2003, 05:06 PM   #1
wrxracer55
Member#: 39435
2004 Impreza WRX STI
Default replacing brake lines on wrx, anything i need to watch out for?
any special techniques? do i bleed them like a normal car without abs. wasn't sure b/c of the abs. thanks
wrxracer55 is offline   Reply With Quote
Old 10-31-2003, 05:08 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Get a 10mm flare nut wrench!!! Spray some WD40 on the hard-line connection before attempting to loosen the nut. When you're done, just bleed in the correct order, front right, rear left, front left, rear right. You can go out and slam on the brakes to cycle the ABS if you want afterwards and re-bleed.
Calvin
cnk is offline   Reply With Quote
Old 10-31-2003, 05:21 PM   #3
wrxracer55
Member#: 39435
thanks
Old 10-31-2003, 06:05 PM   #4
Razlak
Member#: 7209
2005 WRX STi
World Rally Blue
Make sure its a GOOD flare nut wrench too, I've seen some really crappy thin ones that will flex like crazy. Craftsman pro, snapon, napa pro are good, pretty much any of the "Professional" line tools that are built stout. Besides its only one wrench you need, and if you DO round off the nut, you'll be replacing a very spendy hard line anyway.
I got a $12 Napa Pro one, its pretty beefy and forged. Took all 4 lines off with absolutely 0 rounding.
Razlak is offline   Reply With Quote
Old 11-01-2003, 08:48 AM   #5
wrxracer55
Member#: 39435
will do, thanks again. also, does anyone know if russell makes speed bleders for our cars? i'm guessing they do. anyone have part numbers?
Old 11-01-2003, 12:49 PM   #6
cnk
Member#: 10757
Check out Oakos.com. That's where I got my speedbleeders. Great vendor.
Calvin
Old 11-01-2003, 11:09 PM   #7
marios03wrx
Member#: 33593
2002 JDM T.K. 2.2
FancyPants Fast UglyWagon
I've done 2 stainless brake line in stalls trying to use a good flare nut wrench. Based off that experince it didn't work and i used plenty of WD-40. the best tools that worked for me where a crows foot,(for the hard line stabality), a pair of robo grips, and a good friend. i'm no pro but almost every mod i've done on my wrx there is always some major challange to over come. So with all this babling i wish you good luck on the install.
marios03wrx is offline   Reply With Quote
Old 11-02-2003, 12:30 AM   #8
MIQ_WRX
Member#: 11382
2002 WRX Wagon
Blue Pearl
I got Goodridge lines and SS Speed Bleeders from Teauges Automotive.
http://home.att.net/~teaguesauto/
If you get the bleeders don't over-tighten them. Others have broken them this way.
Make sure you get all the old washers off the connections before you install the new ones. One new copper washer on each side of the joint.
Follow all the supplied instructions.
-MIQ
MIQ_WRX is offline   Reply With Quote
Old 11-02-2003, 10:00 AM   #9
wrxracer55
Member#: 39435
thanks again
AC Compressor replace. Anything to watch out for? califesaver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-06-2007 08:08 PM
STi on a car carrier. Anything to watch out for? Hollidark General Community 2 06-29-2004 10:24 PM
Anything to watch out for going to Vegas? karazyman Southern California Impreza Club Forum -- SCIC 26 05-08-2004 02:12 AM
Any precaution need to watch out for 2nd hand tower bar purchase??? gerardchau Brakes, Steering & Suspension 3 07-15-2001 01:44 AM
