Welcome to the North American Subaru Impreza Owners Club Monday November 18, 2019
Old 02-19-2014, 04:20 AM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default 2015 STI Steering Rack 13.1!! Anybody Planning to swap?
Just wondering if it will fit older Subarus, the 19 ratio on the Forester is just ridiculous, feels I am driving an 18-wheeler. 13.1 = delicious.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 02-19-2014, 09:38 AM   #2
T-37
Member#: 175624
0304 WRX WRX
SY WRB
That was actually the first thing that came to mind when they released specs for the '15. I'm sure it won't be a direct fit, but I'd imagine it should be possible with enough fabrication. It's tough to say until somebody gets their hands on one and tries it though. I'd love to put one in my '04 WRX...that may end up being my winter project next year
Old 02-19-2014, 01:45 PM   #3
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Fabrication is letigiously dangerous, Q-Rack had a lot of issues, hopefully is a direct fit.
Old 02-19-2014, 02:27 PM   #4
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Eh, unless you're selling them or telling people how to install them (or selling the car,) why be worried about litigation?
I'm not particularly afraid of fabbing brackets, even if it requires cutting up and welding a crossmember. It would be nice to have a quick rack that you can pick up at any dealership in the states for a "reasonable" price. Q-racks recent issues are why I'm even considering going to the effort.
Old 02-19-2014, 02:40 PM   #5
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
If we could it would be amazing....
Old 02-19-2014, 02:41 PM   #6
Web Foot STi
Member#: 39086
2004 STi
Having an STi, I'm more concerned how compatible it is with the older steering angle sensor. The Q- rack was not.
Web Foot STi is offline   Reply With Quote
Old 02-19-2014, 03:47 PM   #7
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
2004 STi not aware they had steering angle sensors back then?
Old 02-19-2014, 03:54 PM   #8
Web Foot STi
Member#: 39086
2004 STi
They do. That's what the clock spring is. Change the road wheel angle to the steering wheel angle ratio and it messes up the DCCD.
It's some of the other sensors in the center consol that came later.
Old 02-22-2014, 07:06 PM   #9
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
I'm pretty sure the 07 STI was the first to get the steering angle sensor. The clock spring is NOT a steering angle sensor.
car_freak85 is offline   Reply With Quote
Old 02-22-2014, 08:43 PM   #10
Web Foot STi
Member#: 39086
2004 STi
All I know is the DCCD doesn't like the Q-rack. The firstto try it gave up. This a ~decade old memory test.
Old 03-02-2014, 01:53 AM   #11
hrkahn
Member#: 343711
2013 STI
really would love to know if it's a direct fit
hrkahn is offline   Reply With Quote
Old 03-02-2014, 08:25 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i'm in the market for a new rack these days (excessive shaft play in my original).
somebody grab an '15 sti rack and take a picture of the mounting points!!
Old 04-26-2014, 12:01 AM   #13
salvi
Member#: 188132
which racks will work on a GC? Will new STI even work and what's up with this sensor u mention?
salvi is offline   Reply With Quote
Old 04-26-2014, 12:36 PM   #14
slide
Member#: 1130
2013 STI Hatch
I'd love a quicker rack for my '13...
slide is offline   Reply With Quote
Old 04-28-2014, 04:19 PM   #15
rexworx
Member#: 103232
GTX 3071R'd 11WRX
The 2015 wrx has a electric rack. Anyone know about the STI?
Old 04-28-2014, 04:54 PM   #16
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
EG33 05 Forester
sti rack is hydraulic like normal
carnz-pj-410 is offline   Reply With Quote
Old 04-28-2014, 10:21 PM   #17
slide
Member#: 1130
2013 STI Hatch
So, in theory, if it did fit, would we not also have to reprogram the traction control etc to accept the new quicker steering angle?
Is this reprogramming even available?
Old 04-29-2014, 11:57 AM   #18
dobie0791
Member#: 72713
2005 STi
Rallispec sells an OEM group N 13:1 LHD steering rack.
Only $4000
dobie0791 is offline   Reply With Quote
Old 04-29-2014, 02:08 PM   #19
Power6
Member#: 72730
2001 Lexus ES300,
2016.5 Mazda CX-5
Nope. Only current solution is turn off VDC or disable it and ABS. There is likely not enough economic gain in anyone reverse engineering the VDC unit so not likely to ever change. Perhaps someone will figure out how to intercept the steering angle sensor and change the signal, but it speaks directly to the CAN BUS so not sure how feasible that is either.
Power6 is offline   Reply With Quote
Old 04-29-2014, 02:15 PM   #20
T-37
Member#: 175624
0304 WRX WRX
SY WRB
The last option sounds like the simplest solution.
That or starting with a WRX so you don't have to worry about DCCD
Old 04-29-2014, 03:31 PM   #21
Power6
Member#: 72730
2001 Lexus ES300,
2016.5 Mazda CX-5
Even then modifying the SAS may not be easy at all. Nobody has tried it yet.
DCCD is not the problem here, it is relatively minor to have the level of center diff lock not be quite right due to incorrect steering angle input.
The VDC on the other hand (which all WRX/STI since 08 have) goes a bit nuts when the wheels are turned further than it expects! If you don't care about turning VDC off every time you drive no big deal.
Old 04-29-2014, 03:39 PM   #22
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Thats what I thought but wasnt sure...
Old 04-30-2014, 09:46 AM   #23
funk32
Member#: 245787
GD Race Car
I have a q-rack and there are no issues with the DCCD as there is no steering angle sensor for the 04's and I thought it wasn't until 08 but I haven't really looked into it.
funk32 is offline   Reply With Quote
Old 05-02-2014, 11:16 AM   #24
dobie0791
Member#: 72713
2005 STi
2006+
Old 05-02-2014, 11:53 AM   #25
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
somebody get a part number for this bad boy.
