Welcome to the North American Subaru Impreza Owners Club Thursday February 20, 2020
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 01-05-2016, 10:20 AM   #151
shamrock 05
Member#: 120057
2018 WRX (base) 6spd
Originally Posted by Ericthered545 View Post
Not really. How much boost do you think you should be pushing at 7000rpm?
My bad, I misread....you said redline.
Originally Posted by KillerBMotorsport View Post
Forcing the turbo to go beyond its capabilities is only going to make a massive temp spike due to compressor inefficiency. As RPMs increase, the stock turbo just can't maintain full boost, and still be efficient. This is why as boost and pressures rise above OEM levels, the factory TMIC can become overwhelmed. Both turbo and TMIC are pushed beyond design intent.
Also noteworthy, these engines use smaller valves than the previous generation engines and use twin scroll turbocharging technology. Both aim at improved responsiveness and mid-range punch. If you want a high RPM screamer, this is not the platform for you.
So by adding a thicker core intercooler you're increasing how much longer the oem turbo can spool in the higher rpms and keep power going...?
shamrock 05 is offline   Reply With Quote
Old 01-05-2016, 11:26 AM   #152
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
EDITED for you
So by adding a more efficient core you're increasing how much longer the oem turbo can hold boost in the higher rpms and keep power going...?
Intercooler efficiency is always best the higher the temperature differential (ambient to compressor outlet temps). A well designed core will be more efficient (transfer more heat) than a cheap one. Cost is definitely relative as the processes to make a higher quality core are more expensive. It's definitely a get what you pay for product.
As the OEM turbo is pushed, temps climb, increasing that differential. Assuming the core is efficient and has good flow characteristics, yes you can hold boost longer because you are not flow restricted like OEM and the removal of heat from the charge is improved.
KillerBMotorsport is online now   Reply With Quote
Old 01-06-2016, 09:22 AM   #153
shamrock 05
Member#: 120057
EDITED for you
Idk what you edited
But the statement in bold, heres a dumb question......due to flow charistics and temps as the turbo is pushed aka more heat is developed.......isnt that what the hood scoop is for?....generation cooler/faster air flow the faster the car goes. So no matter how thick or thin the IC core is, you're still ramming more air/cooler air through it the faster you go.
Just trying to understand more
Old 01-06-2016, 10:00 AM   #154
shadrag
Member#: 393545
2015 WRX (6MT)
Idk what you edited
You are correct that the more air going through the IC the better it will cool, but this cooling effect doesn't increase as fast as the air temperature increases from the turbo working hard.
shadrag is offline   Reply With Quote
Old 01-06-2016, 10:50 AM   #155
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ true, and from a heat soak perspective, flogging through 1st and 2nd gear airflow comes into the equation very little.
Old 02-15-2016, 03:13 PM   #156
Dorian7
Member#: 364950
2020 WRX
Magnetite Metallic
Are there any dyno's from people running these yet?
Dorian7 is offline   Reply With Quote
Old 03-03-2016, 11:37 PM   #157
hekler
Member#: 388366
2016 SUBARU WRX(cvt)
CBS w/eyesight
Any feedback or reviews would be appreciated?? I am very interested in this
hekler is offline   Reply With Quote
Old 03-04-2016, 12:16 AM   #158
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
I'm at 317whp and 350lbft with aftercooler, chargepipe, TGV deletes, EGR delete, ETS J-pipe & intake. My tuner said the intake temps were fantastic and it was very easy to tune. He said there was alot left but wouldn't go over 350lbft with stock rods.
Barnt is offline   Reply With Quote
Old 03-05-2016, 11:09 AM   #159
mxl16
Member#: 392730
2015 WRX Prem.
ISM
How much boost are you running?
mxl16 is offline   Reply With Quote
Old 03-07-2016, 01:13 PM   #160
Ericthered545
Member#: 411430
2015 WRX
There's one posted in the 2015 WRX dyno thread FBO + Aftercooler/Chargepipe http://forums.nasioc.com/forums/show....php?t=2675766
Mine works nicely as well but I'm Etune. Never had it on a real dyno. Virtual Dyno says its 290/305.
Ericthered545 is offline   Reply With Quote
Old 03-25-2016, 12:56 PM   #161
ahughes
Member#: 396349
2015 wrx
Ice silver metallic
Im sure this is posted somewhere but can somebody post the dimensions of the aftercooler? Thanks trying to see if I can use killer b charge pipe with my Mishimoto intercooler
ahughes is offline   Reply With Quote
Old 03-25-2016, 05:41 PM   #162
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
14" x 10" x 3.5" but keep in mind, not all cores are made the same. There is fin design, density, lay, etc... that effects how efficient the core is at actually transferring heat. And a bigger core does not necessarily mean it cools better, especially if it's priced low. The production process for a quality core takes longer, with more refined/precise equipment and is accompanied by more stringent quality control. You get what you pay for essentially. So in short a huge intercooler will slow the flow more, but not necessarily cool the charge air as well.
Old 04-08-2016, 01:05 PM   #163
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We've had some questions on the trimmed shroud we've been using so I wanted to post a couple pics for clarification...
Pic of the modified cover installed...
Cut along the line drawn at #1. At #2 follow the groove until it intersects the first cut. The cuts can be made with a sharp utility knife. Run a file or deburr tool or sandpaper along the edge to clean up any sharp edge.
Old 04-12-2016, 12:21 AM   #164
Boggie1688
Member#: 165955
2015 WRX Base
I just started working on installing my aftercooler and charge pipe. It looks like I fall into the category of people who's bolts for the charge pipe to turbo are too long.
KB! I'm shooting you guys a quick PM.
Boggie1688 is offline   Reply With Quote
Old 04-12-2016, 10:27 AM   #165
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
Same thing happened to me when I installed mine back in January. I just fired up the grinder and cut off the required amount of metal off the end of the bolt to make it fit. It went right in and I haven't any issues.
Old 04-12-2016, 12:56 PM   #166
Boggie1688
Member#: 165955
2015 WRX Base
No grinder here. My tool collection is still growing. Proud of what I've collected thus far.
In any case, KB is already sending me the correct bolts.
I should have sometime to continue working on the car today. I'm going to just put it all together with the stock bolts, then swap them out when the new ones get here. Just something to help hold things in place while I work.
Old 04-18-2016, 12:14 PM   #167
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There have been a few with bolt issues. Apparently Subaru changed the bolt length (different part number) mid-production which was an unpleasant surprise as some of you have found.
We are now including bolts with every kit. They are also available to anyone who has bought a kit previously.
Old 04-19-2016, 07:55 AM   #168
WeAreThe416
Member#: 389122
2015 WRX Sport
World Rally Blue
Can you show us some pics to illustrate whether we we need to get the bolt kit from you?
WeAreThe416 is offline   Reply With Quote
Old 04-19-2016, 02:57 PM   #169
Boggie1688
Member#: 165955
2015 WRX Base
Pictures won't really do anything justice. The variable is on your car, not theirs. By the time you get down there and actually look and measure, you might as well just pull the pipe off and request the bolts. We are talking mms here.
Old 04-19-2016, 03:06 PM   #170
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'll see if I can find them, but I am pretty sure I tossed them both in the 'Suby bolts bin' after verifying they were different. In hindsight, putting some calipers on them first would have been the way to go. Like Boggie said, it was only a few millimeters difference.
Old 04-23-2016, 01:13 PM   #171
Boggie1688
Member#: 165955
2015 WRX Base
KB. I ran into one small issue. The stock intake won't clear the charge pipe. The part that comes of the box to the top of the radiator. Does this fit on your car? Wondering if I need to do some adjusting or if it doesn't fit at all because of the larger diameter pipe.
Old 04-24-2016, 09:12 PM   #172
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Slide it into the couplers more. It should fit.
Old 04-24-2016, 10:28 PM   #173
wrxStevewrx
Member#: 425343
2015 WRX
Mine touches a tiny bit as well.
wrxStevewrx is offline   Reply With Quote
Old 04-24-2016, 11:04 PM   #174
Boggie1688
Member#: 165955
2015 WRX Base
AHh!! I didn't realize the charge pipe can go into the aftercooler. It fits now. Touches the intake still, but I can clip it in with some force.
Old 05-01-2016, 08:53 PM   #175
dr_wookiee
Member#: 144106
2015 WRX
Lightning Red
I have looked w/o any luck. Can someone post a link or a picture of where to cut the engine cover to fit on top of the aftercooler? I've already cut the engine cover down as shown above, however, it seems like some plastic needs to be trimmed on the back side to get the fastener holes to lay flush.
dr_wookiee is offline   Reply With Quote
