Welcome to the North American Subaru Impreza Owners Club Thursday November 14, 2019
Old 10-28-2014, 11:09 AM   #26
mabubakr
Member#: 316802
2003 WRX
Originally Posted by jdmjack View Post
This link don't work no mo'. Any working links?
I think I found what you were looking for. It describes the differences in 02/03 brake pads:
http://www.clubwrx.net/forums/suspen...fferences.html
mabubakr is offline   Reply With Quote
Old 11-02-2014, 12:08 AM   #27
Sebar34
Member#: 398962
2014 New WRX
Blue Galaxy
Traducir del: inglés
2015 wrx upgrade info ???
Sebar34 is offline   Reply With Quote
Old 02-04-2015, 10:44 AM   #28
g005e
Member#: 391229
Hello guys,
Can someone please tell me the Subaru reference number for Brake booster with badge on it:
864-06318
it is listed as STI brake booster but i cannot find the Subaru number .. if any it should be 26402FE280 for RH or 26402FE290 for LH
I saw another booster with ref 864-06319 and it was LH.
So is this correct:
26402FE290 LH 864-06319
26402FE280 RH 864-06318 ?
What do you think/know?
Thank you in advance.
Cheers!
g005e is offline   Reply With Quote
Old 11-29-2015, 01:57 PM   #29
mrbumps
Member#: 435183
I have a 2003 forester X with WRX struts but I have rear drum ONLY brakes. I want to swap to rear disc brakes.
Do I need to swap out the knuckle only from a 2004 WRX or do I need to swap out the axles also?
mrbumps is offline   Reply With Quote
Old 10-22-2016, 10:06 PM   #30
ky335i
Member#: 456927
check leaking cv axles or check for any differential gear oil or tanny fluid. At time the cause of sticky brakes or brake drag can be due to fluid contamination that came from somewhere either in front end or rear end situation. Most of what i come by can be also clogged brake lines or pistons. but that require more diagnosis and special tools. But easy way is to check for any fluid leak that you might see around your brakes like rotors or near hub or knuckle. this can have a serious effect on fuel consuption and feels as if car has loss of power.
ky335i is offline   Reply With Quote
Old 10-23-2017, 05:03 PM   #31
vmphil
Member#: 463931
2017 WRX
Red
any info or part numbers for ordering 2018 Jurid brake pads for 2015-2017 WRX?
vmphil is offline   Reply With Quote
Old 11-14-2017, 09:41 AM   #32
Scala
Member#: 274028
2018 WRX + EcuTec
The Front Pad Kit is 26296SG011. List $84.95
The Brake Pad Kit is 26696AG051. List $79.95
Don't forget to let us know how they fit and perform.
SS lines would help as well.
Scala is offline   Reply With Quote
Old 12-12-2017, 01:49 PM   #33
vmphil
Member#: 463931
2017 WRX
Red
awesome! Thanks!
Old 03-25-2018, 11:44 PM   #34
Lagger1
Member#: 467632
+1
Anyone confirm the above kit are in fact Jurid's? Looking at the numbers it's hard to tell
Lagger1 is offline   Reply With Quote
Old 06-29-2018, 02:34 AM   #35
chanrobi
Member#: 482531
Awesome thanks!
chanrobi is offline   Reply With Quote
Old 11-02-2018, 12:48 PM   #36
Felix85
Member#: 493476
Front Hawk DTC-70 brake pads
Does anyone use these electrodes in street driving?
How do they work?
Felix85 is offline   Reply With Quote
Old 11-02-2018, 01:37 PM   #37
Scargod
Member#: 260314
2007 STI
silver gray metallic
How do they work?
Electrodes? Do you jest? NO, NOT COMPATIBLE WITH STREET DRIVING.
Scargod is offline   Reply With Quote
Old 12-08-2018, 09:19 PM   #38
petersensignej
Member#: 490223
I am doing research and here's my interpretation of your inquiries: Increasing the rotor estimate alone may do only enable it to run somewhat cooler and just in the event that you are truly pushing the breaking points. They will be heavier. Without expanding the cushion territory you won't achieve much, in the event that anything. The rotors should be a good thickness.
petersensignej is offline   Reply With Quote
Old 12-09-2018, 03:03 PM   #39
Scargod
Member#: 260314
2007 STI
Default Moderator!
Why are you copying and butchering my earlier post?
Old 12-13-2018, 01:39 PM   #40
1sikRX
Member#: 418222
awesome! Thanks!
The rears are the same, fronts are Jurid. Has anyone tried this yet?
1sikRX is offline   Reply With Quote
Old 04-18-2019, 07:50 PM   #41
MostWantedClick
Member#: 500532
Default Cts V
I’ve seen people swap CTS V brakes on the wrx I wonder if there’s a kit to swap them in
MostWantedClick is offline   Reply With Quote
Old 04-19-2019, 07:02 AM   #42
Scargod
Member#: 260314
2007 STI
I think so. Call Ken of KNS Brakes. (919) 420-0021
Old 05-10-2019, 09:56 AM   #43
vmphil
Member#: 463931
2017 WRX
Red
I asked at the parts counter and they said that they are incompatible.
not sure I believe that considering how random parts from random years of Subarus tend to bolt up like legos....
FS in nova: RS and other parts 4wheelmotion Private 'For Sale' Classifieds 65 06-22-2006 10:39 PM
Lots of popular items back in stock: Helix and others... Gruppe-S Engine/Power/Exhaust 12 07-21-2005 06:30 PM
FS: In-Dash DVDs and other Headunits *cheap!* Deezy Vancouver Impreza Club Forum -- VIC 2 08-21-2004 05:33 PM
What laws apply to driving in parking lots and other non-publicly owned land? Trizzle Off-Topic 9 02-14-2004 02:02 AM
Big meet info and others from Specialty! GS116 Vancouver Impreza Club Forum -- VIC 117 06-14-2001 03:54 PM
