Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Old 09-27-2017, 10:36 AM   #51
tech45K
Member#: 474949
Originally Posted by AbACUZ View Post
One of the things that need to be added to this thread is the stock aligment numbers for the differnt models.
Yes, that's what I am looking for.
tech45K is offline   Reply With Quote
Old 03-03-2019, 02:42 PM   #52
Grantmac
Member#: 498493
Absolutely going to give this a go in the near future and will try to compare math vs. level vs. smartphone.
Grantmac is offline   Reply With Quote
Old 03-13-2019, 09:17 PM   #53
Norm Peterson
Member#: 498642
'19 WRX Limited 6MT
'08 Mustang GT (the toy)
Patience is the big key to doing your own alignments.
I've been doing all of mine since the early 1980's. Right there in my own driveway, with various methods of making the measurements. After that, it's only "wrench work".
As for coincidence, I finally managed to get the left front camber on our brand-new 2019 WRX close to where I wanted it to be. The right side was 'cake'. All I've got left is maybe a little final toe tweaking, once I do the parallel strings setup.
FWIW, "stock alignment numbers" can mean different things.
First, there's "factory preferred", which is usually what an alignment tech will shoot for.
There's also some tolerance either side of that, and in the case of camber and caster, tolerances on how much difference is allowed to exist between the measurements on the wheels at the same end of the car (called "cross-camber and cross-caster, respectively). This would cover what Subaru feels is still acceptably close.
And then there's the alignment numbers that happen to work best for each individual. This really could be the same as "factory preferred", but if your driving is significantly more "enthusiastic" than whatever average driver that Subaru chose their specs for - or significantly less so - then your alignment numbers probably shouldn't match "factory preferred".
Let's just say that in my own case, the RF camber was essentially at "factory preferred" but the LF camber was barely within both the minimum spec for camber and the maximum tolerance for cross. What's there now is just a touch less negative than the max negative end of the factory range with barely 0.1 of cross.
Norm
Norm Peterson is offline   Reply With Quote
HAHA! OT sez, "Do your own homework, loser!" Strider Off-Topic 3 11-13-2007 05:31 PM
The ultimate tax shelter: Owning your own business fuzzycuffs Off-Topic 78 02-19-2007 10:59 AM
You think "Do your chain hang low" is bad...get a load of this: BigWrecKs Off-Topic 28 09-11-2006 06:36 PM
own your own repair shop credit xtc Tri-State Area Forum 16 02-13-2002 09:54 PM
('93-'01) Do not have your own brain? Get one for your battery then. 25psi Impreza Forum 3 04-16-2001 11:38 AM
