Welcome to the North American Subaru Impreza Owners Club Wednesday November 13, 2019
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 04-16-2002, 07:36 PM   #1
Karl
Member#: 13110
Default Transmission/differential drain/fill plug sizes
I know I can use the search, and honestly I have tried. But I come up with tons of posts and they all talk about something else without mentioning sizes. I am sure some of you have done this so what are the sizes for these plugs? I plan on changing the fluid next week, and hope to get what I need before starting. I already have 22mm, 23mm, and 24mm sockets (these are the sizes of the plugs on my Miata). Anything else I may need?
While I am at it, what brand of fluid and what grade do you use? I use MT90 in the Miata transmission (but it is only GL4 rated) . Should I use 75w90 NS in the transmission, and 75w90 in the differential? Opinions??
Karl is offline   Reply With Quote
Old 04-16-2002, 07:55 PM   #2
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
I *think* the plugs are just an insert for a 3/8 drive ratchet (no socket required). They are very easy to see on the back of the diff. I would just crawl under there and check, that way you'll be sure.
The fluid info should be in the owners manual. I can't remember off hand what the fluid viscosities are. Don't forget the rear diff. is an LSD too.
Hope this helped.
Paul G.
paultg is offline   Reply With Quote
Old 04-16-2002, 08:40 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Old 04-16-2002, 09:40 PM   #4
Karl
Member#: 13110
Hey those are good webpages.... exactly what I was looking for.
You know, it would be nice if there is some kind of faq, consolidating all these info into easy to find entries.
Old 04-16-2002, 10:07 PM   #5
scurry
Member#: 13543
I just replaced both my tranny and diff fluid two weeks ago with Redline. I was very surprised to find how black the oil was in both the tranny and diff. This is with only 6K miles on the car. Has anyone else experience this? I do autocross but I cant see this being the cause of the discoloration. The magnetic plugs did have some sludge on them but no major chunks. I just contribute this to normal break-in. I recently changed the clutch in my 91 MR2 (required draining tranny) and the redline tranny fluid was just as red as it was 14K miles ago.
Shawn
scurry is offline   Reply With Quote
Old 04-16-2002, 11:23 PM   #6
kpratte
Member#: 2760
'18 Tundra Platinum
Originally posted by paultg
[b]I *think* the plugs are just an insert for a 3/8 drive ratchet (no socket required).
actually 1/2" drive ratchet..
Oh, and the fluid smells nasty!
- Ken
kpratte is offline   Reply With Quote
Diff Cover Anodized Blue Drain/Fill Plugs krylon Drivetrain 28 01-13-2010 01:12 AM
Removing the drain and fill plug in rear diff. MY00 LGT jsbush Service & Maintenance 6 07-08-2006 11:19 AM
Fill plug size for rear diff 04 sti? 409Industries Service & Maintenance 3 10-04-2005 02:57 PM
Front Differential Drain Plug Torx Bit Size? 02TREX Baja Forum 2 04-11-2005 07:58 AM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 07:06 PM
