Welcome to the North American Subaru Impreza Owners Club Wednesday November 20, 2019
Old 02-18-2019, 04:10 AM   #1
HerBluePearlWRX
Member#: 497923
Default Getting RCE yellows....what else do I need?
What other parts should I get, along with these springs, to maintain proper geometry? 2018 WRX.
HerBluePearlWRX is offline   Reply With Quote
Old 02-19-2019, 02:42 PM   #2
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
Don't need anything else for a fun street car. Rear LCAs are nice to have to get alignment perfect.
Just get a good alignment and add some front negative camber and have fun!
AndyRoo is offline   Reply With Quote
Old 02-19-2019, 04:18 PM   #3
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I'd look at any other little bolt-on upgrades that also require an alignment; simply as a two birds with one stone scenario.
For instance, I did steering rack bushings and Whiteline ball-joint relocation kit with my Feal struts and REC yellows.
Old 02-20-2019, 02:45 PM   #4
prcomte
Member#: 419017
2018 Subaru WRX STI
OBS
On my 18 STI I had to get rear LCA and Toe arms to get the rear alignment to where it wouldn't eat through tires. I don't have RCE yellows, but my drop is roughly the same. Actually a little less. Call Geoff at Cygnus Performance great guy and customer service he will get you all squared away.
prcomte is offline   Reply With Quote
Old 02-20-2019, 04:06 PM   #5
AZP Installs
Member#: 40160
We suggest getting SPC rear arms at a minimum to be able to adjust the rear alignment perfectly. Let us know if we can help with parts and installation.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
AZP Website | Like us on Facebook! | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971)
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 02-20-2019, 05:56 PM   #6
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
With yellows rear camber will go from -2.0 stock to -2.3 give or take a tenth.
You can’t adjust rear camber stock. As long as you keep the toe near zero you won’t see appreciable extra tire wear.
On the front for camber stock you probably have -0.8. You’ll actually loose a tenth or two adding yellows but you can and should adjust to get as much as you can -1.3. Again keep the toe near zero and you’ll see no additional wear.
uofime is offline   Reply With Quote
Old 02-21-2019, 11:44 AM   #7
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
Originally Posted by uofime View Post
Again keep the near zero and you’ll see no additional wear.
Think you've got a typo and meant to say "keep the toe near zero" which is good advice.
Last edited by AndyRoo; 02-21-2019 at 04:31 PM. Reason: makes typo while correcting typo...nice.
Old 02-21-2019, 03:34 PM   #8
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
Originally Posted by AndyRoo View Post
Think you've got a typo and meant to say "keep the toe near zero" whic is good advice.
Whoops fixed it
Old 02-21-2019, 04:31 PM   #9
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
Whoops fixed it
Apparently I make typos too lol.
Old 10-19-2019, 06:31 PM   #10
HerBluePearlWRX
Member#: 497923
Thanks guys! I didn't see all the replies before, but I just saw them today!
