Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 10-13-2019, 11:37 AM   #1
RJSMITH
Member#: 347474
0219 Bug,bug,coup,va
mbp,sr,wrb
Default Gd fixed 4/2pots on 2019 wrx?
Anyone know if its possible to put the gd 4/2pots on a 19 wrx. stock brakes aren't that appealing in a visual sense and would like to be able to fit the wide range of wheels that this caliper setup normally allows. I'd assume the fronts bolt right up but the rear will most likely need a bracket. Also would need to figure out if the shields will work and what rotors since its 5x114. Thanks
RJSMITH is offline   Reply With Quote
Old 10-13-2019, 12:18 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
Im pretty sure the fronts will fit no problem, but the rears will need adapters, the best thing to do is call KNS brakes and ask them just for comfirmation
subaru_gc8 is offline   Reply With Quote
Old 10-13-2019, 01:24 PM   #3
RJSMITH
Member#: 347474
mbp,sr,wrb
Posted on fb as well checking out primitives setup
Old 10-15-2019, 03:54 PM   #4
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
I run two pot rears, need KNS brackets, dual drilled rotors, and sti lines. Dust shields are fine since they’re only marginally larger in diameter.
uofime is offline   Reply With Quote
