Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 10-14-2019, 08:17 PM   #1
BRGT
Member#: 406470
2013 STI Hatchback
Ice Silver Metallic
Impreza WRX STi STI Suspension Differences: 2015-2017 vs. 2018-2019
Hey guys,
After searching around I haven't found any definitive info on the differences between these years of STI strut/springs.
I know Subaru revised the suspension in 2018, and they have different part numbers, so there must be some differences in dampening or spring rates (probably to compensate for the 2018's 19" inch wheels). I am guessing that the 2018+ suspension is a little softer to compensate for the bigger wheels, but I'd like to find more specifics.
Does anyone have any info? Thanks for the help!
2015-2017 part numbers:
Front: 20365VA000
Rear: 20310VA000
2018-2019 part numbers:
Front: 20365VA400
Rear: 20310VA410
BRGT is offline   Reply With Quote
Old 10-21-2019, 02:43 PM   #2
BRGT
Member#: 406470
2013 STI Hatchback
Ice Silver Metallic
Bump. Anybody have any info?
Old 10-21-2019, 09:54 PM   #3
Blktrax
Member#: 220971
2002 WRX 224K Mi.
There is no technical data in the Service manual.
Only Stated in the 2018 New Car Info
Also consider there is the 3rd option of the Bilstien Type RA for 2018 also.
1. FRONT STRUT COMPL
The damping force of the front strut COMPL has been modified to improve handling stability and ride comfort.
2. COIL SPRING
The front coil spring constant has been modified to improve handling stability and ride comfort.
1. REAR SHOCK ABSORBER
The damping force of the rear shock absorber has been modified to improve handling stability and ride
comfort.
2. COIL SPRING
The spring constant of the rear coil spring has been modified to improve handling stability and ride comfort.
3. REAR STABILIZER
The diameter of the rear stabilizer has been modified to improve handling stability and ride comfort.
Blktrax is offline   Reply With Quote
Old 10-22-2019, 03:42 PM   #4
BRGT
Member#: 406470
2013 STI Hatchback
Ice Silver Metallic
Thank you for the response! I appreciate it. That starts to piece things together.
Does anyone know where you can get technical data on this stuff?
Old 10-22-2019, 05:35 PM   #5
gasgaskid
Member#: 455827
Note that this on the STI's, i wonder if there where any changes on the newer WRX's? I upgraded my 2016 Base to 2016 Premium shocks, struts and springs, still on the firm side but a lot better than stock.
gasgaskid is offline   Reply With Quote
Old 10-22-2019, 06:08 PM   #6
BRGT
Member#: 406470
2013 STI Hatchback
Ice Silver Metallic
I don't recall if there were changes to the WRX's or not in 2018. Good upgrade for you though going to the inverted fronts.
