Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 10-19-2019, 05:18 PM   #1
medussa
Member#: 507398
2006 Impreza Wagon
Default 06 Impreza wagon warning
Make sure to have a look at your front LCA next time you have the wheel off! Mine broke off. Bad rot at the cradle. I cant post pics off my pc no url
medussa is offline   Reply With Quote
Old 10-19-2019, 08:32 PM   #2
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
There was a recall for that... take it to the dealer and you should get new control arms.
CaptainSlowbaru is offline   Reply With Quote
Old 10-20-2019, 10:03 AM   #3
medussa
Member#: 507398
2006 Impreza Wagon
They were no help and said they cant because it passed the punch test in 2012 and its old and out of warranty, SOA said the same thing. I have to eat it and get it flat bedded to the garage. Every bolt is stuck and ill just break them off. Funny too because I think the airbag was done last year.
Old 10-20-2019, 07:33 PM   #4
2pot
Member#: 301042
20090FE000
WVX34 repair kit wagon
2pot is offline   Reply With Quote
Old 10-21-2019, 09:03 AM   #5
medussa
Member#: 507398
2006 Impreza Wagon
2pot, I don't know what those are. Links? I need more info. I have a Mevotech arm but I broke the ball joint bolt on the knuckle so im over it. Im going to try to call Subaru Corp in Japan at 9 this morning as they have a recall helpline.
Old 10-21-2019, 09:11 AM   #6
2pot
Member#: 301042
That's the Subaru part number for the replacement arms, joints and bolts - about $150
Old 10-21-2019, 01:51 PM   #7
medussa
Member#: 507398
2006 Impreza Wagon
Thank You, If that's for both sides I should have got those. My single arm was 121. Shes off to the shop on Wednesday. SOA nor the dealer told me about that, one guy said just put used STI arms on it.
Old 10-21-2019, 02:22 PM   #8
2pot
Member#: 301042
Old 10-21-2019, 08:55 PM   #9
medussa
Member#: 507398
2006 Impreza Wagon
Thank You again. I sent SOA an email with a copy of that with notice of page 3 under dealership responsibility and the pics I took of the break and rust. We'll see. Much Appreciated!
Old 10-23-2019, 10:02 PM   #10
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
My argument to SOA would be that the rust proofing spray obviously did not prevent the rust, as intended. So they either didn't apply the spray at all, or didn't apply it correctly. The point of that spray is to prevent exactly what happened to your LCA's. Good luck!
Old 10-25-2019, 05:27 PM   #11
medussa
Member#: 507398
2006 Impreza Wagon
I was told by a Grant Noble at SOA that my car is out of its 36k warranty period and they will not extend warranty service. I already have the car at my Trusted mechanic, so this is in spite now. I could have died OR killed anyone in the oncoming traffic, to me, that's a big deal.
Old 10-25-2019, 05:42 PM   #12
motorbykemike
Member#: 273868
if it were my car, and I think it's a big deal also, I would absolutely replace the other arm also
motorbykemike is offline   Reply With Quote
Old 10-26-2019, 06:32 PM   #13
medussa
Member#: 507398
2006 Impreza Wagon
While at my guy its getting both rear axles done and the driver rear wheel bearing. I told him that as soon as its on the lift to check the driverside LCA and to call if it needs replaced. Ill call on Monday and see if I have to get the front driver side done. I know its a pain because I had to get the rear lateral links and bolt to do the rear bearings. Its a cut and replace type of job. Friday, I picked my grandson up for school and got him home right before I went out to take care of my Mother, I could have killed anyone. Compassion, Thank You....
Old 11-05-2019, 05:58 PM   #14
medussa
Member#: 507398
2006 Impreza Wagon
I took the car in, it took a week to get done but I noticed they put the rear axles on the wrong sides so the RR axle boot looks streched out. Is it ok to have them on the wrong sides or will something bad happen??
Old Today, 08:00 PM   #15
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
Rear axles are the same left to right. They have some 'splainin' to do.
(this is one of the reasons I don't like aftermarket parts on Subarus )
