Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 06-17-2018, 12:13 PM   #1
climate
Member#: 434960
Default Likelihood of Passing NY State Inspection with Engine Mods
Hi Guys,
Wondering if anyone can comment on my chances of passing NY State inspection. I have a protuned 2015 WRX with the following engine mods:
COBB Resonated Turbo-back Exhaust
ETS Front Mount Intercooler
GrimSpeed Electronic Boost Control Solenoid
GrimSpeed Stealth Box Air Intake
Perrin Inlet Hose
TGV-EGR delete
I moved to NYC from NJ and my NJ new car inspection sticker is good through 2020. However, NY mandates the car get NYS inspection within a year of registration, which I am coming up on.
Thanks!
climate is offline   Reply With Quote
Old 06-17-2018, 01:24 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It has to pass an OBDII scan with no codes present and all readiness monitors set. There is also supposed to be a visual inspection for the emissions equipment being in place and not tampered with, but that varies between stations (whether they care and/or know what they are looking at).
Old 06-17-2018, 01:30 PM   #3
climate
Member#: 434960
Thanks. OBDII should pass if all they are looking for are CEL codes. I dont know how deeply they look into the fact that the ECU has been reflashed a number of times. The COBB turbo back has a CAT, but its a high flow one, which does give off a slight exhaust odor.
Old 06-17-2018, 04:35 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Reflash doesn't matter, the inspection machine can't see that. You need to make sure all the monitors are set or it will fail even with no codes and the light off.
Old 06-24-2018, 03:30 PM   #5
moby4dick
Member#: 51901
'04 WRX
This ^^^. My car has been mod'd well beyond what you have for many years, and always passed except once, when the tire dealer I no longer will go to failed me, for amongst a couple legit reasons, for having NON DOT HEADLAMPS. They were my retro fitted, stock, HID projectors. Since moved on to another minor repair/oil change place that couldn't believe it.
moby4dick is online now   Reply With Quote
Old 06-25-2018, 10:29 PM   #6
climate
Member#: 434960
Thanks, this good to know. Sounds like my chances are pretty good
Old 06-26-2018, 12:47 PM   #7
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
What readiness monitors are we talking about? B/c the monitor for rear O2 will record there being a Cat issue even before it lights up the CEL if it's turned on.
SirBrass is offline   Reply With Quote
Old 06-30-2018, 12:29 PM   #8
moby4dick
Member#: 51901
'04 WRX
If you have an AccessPort you can tell the ECU not to report the error; however the OBDII monitor needs to see that there has been no CEL reported for a certain amount of time so that the monitor says ready. I'm sure other tuning software can do the same.
Old 07-02-2018, 01:44 PM   #9
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
So when one gets the pro-tune, just tell the tuner to have the software not report the code but not turn off the monitor?
Old 09-11-2018, 08:59 PM   #10
Fetteichhornchen
Member#: 105689
https://dmv.ny.gov/brochure/new-york...ection-program
from the list of mods you mentioned I would agree there are no red flags that would fail the car, however Mulder is absolutely right...
Having the CEL off AND the readiness monitors set is necessary. It can also often come down to if the inspector knows or cares what they are looking at.
Fetteichhornchen is offline   Reply With Quote
Old 11-07-2018, 04:48 PM   #11
Alwrxx
Member#: 493717
Anyone know places where they only do visual checks lol?
Alwrxx is offline   Reply With Quote
Old 11-07-2018, 05:39 PM   #12
RJSMITH
Member#: 347474
2002 wrx,01 L coupe
mbp,sr
You have to plug in no way around it
RJSMITH is offline   Reply With Quote
Old 12-16-2018, 03:37 AM   #13
evo2rex
Member#: 40843
2018 STI Type RA
CWP w/ WRB wrap
As long as you're not running a speed density map (had my sti swapped bugeye with a built engine protuned with a speed density map and the obd scanner they used for inspection wouldn't recognize the ecu) you should be good. Worst case scenario put the stock tune or a Cobb ots map on it and drive 30 miles staying off the boost to get the readiness check cleared and then inspect it, thats what I had to do with my bugeye. Dunno if it's the same with the newer ECU's.
evo2rex is offline   Reply With Quote
