Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 11-27-2013, 03:02 PM   #51
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Have any of you guys tried welding Aluminum with these welders? I'd love to hear how that went. (I want one to weld Al)
Bad Noodle is offline   Reply With Quote
Old 11-29-2013, 10:05 PM   #52
Subikid90
Member#: 239233
1998 LGT
I did with my longevity 200dx and it worked okay while the welder worked. Nothing like using a dynasty on aluminum though.
Subikid90 is offline   Reply With Quote
Old 11-29-2013, 10:46 PM   #53
illldeca
Member#: 361233
2002 wrx
silver 01g
it wont get hot enough to do certain thicknesses im sure the best thing to do is to clean the aluminum with acetone an then heat with a propane torch before welding with this machine.
illldeca is offline   Reply With Quote
Old 11-29-2013, 11:33 PM   #54
norexyet
Member#: 39149
I wouldn't trade my dynasty 350 for anything. Thing is a beast.
norexyet is offline   Reply With Quote
Old 11-30-2013, 02:59 AM   #55
illldeca
Member#: 361233
2002 wrx
silver 01g
I have one at my station where i work the 2013 one with cordless foot pedal. Its sweet. Its also got allot of features.
Old 05-04-2014, 08:34 AM   #56
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
So would you guys recommend this welder (eastwood 200) for diy tube welding? I want to use it to make intake (aluminum) and exhaust (stainless) tubing for my diy project. Not gonna be welding anything thicker. Maybe brackets.
Old 05-04-2014, 10:08 AM   #57
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
I would certainly recommend this welder for that usage.
You will NOT get a machine that comes close to the features this machine offers with a big brand name at even twice the price.
Dutch Scooby lover is offline   Reply With Quote
Old 05-05-2014, 02:30 PM   #58
Mechie3
Member#: 120152
I had one of these and it started having problems. It would weld then suddenly stop. Had to toggle power for it to work. Called Eastwood. They shipped me a new one and paid to ship back the old one no questions asked. It's worked quite well and, in a pinch, I've been able to use it on 120V.
That is my one gripe, the power cord is short and my 240V is in the corner. For portable projexcts that is fine. When trying to weld on a car frame across the garage it's annoying.
Mechie3 is offline   Reply With Quote
Old 05-05-2014, 09:59 PM   #59
207STi
Member#: 197062
1998 Swapped Impreza
black
I have one of these as well. This is my first tig machine but it functions extremely well. The chief reason I bought it over the other similarly priced Chinese inverters is because they didn't have the awesome warranty that the Eastwood did. My foot pedal has broken in the 6 months I've owned it, but that it my only complaint. They sent me a replacement for free.
207STi is offline   Reply With Quote
Old 05-07-2014, 02:20 PM   #60
Bansheeboy11
Member#: 182415
1999 RS
That foot pedal looks pretty cheap anyways. Im on the fence with one of the Eastwood machines, has anyone swapped the pedal and torch/hose out for better stuff?
Bansheeboy11 is offline   Reply With Quote
Old 05-08-2014, 11:34 PM   #61
reid-o
Member#: 103631
2004 STI
Gray
I would decide if you want pulse features or not and then how thin matters. I've had good luck with everlast and have 2 now. I've made a few schedule 10 manifolds and doe pipes and piping. I would say you don't need pulse but it does help on edge welds like welding a sharp corner on thin gauge. Also the cheaper welders don't have really great low end performance like if you're doing sheet metal or 18-20 gauge stainless. Most will weld 16 gauge alum and stainless with no difference at all. Super thin and super thick depends.
But you can easily do without it pulse. I use it sometimes to fusion weld thin stuff. I would say that any of the 220v tig machines from everlast or equivalent will be fine.
I would spend the money on a good flexloc torch and the best bandsaw you can buy. Seriously. If you can get a big bandsaw and make accurate cuts without having to grind a lot, you don't need a super badass machine. If I had to do it over again I'd spend more money on a belt sander and a bigger bandsaw (or really good chop saw with good blades). Oh a good chair and welding table too. If I had a better bandsaw, a nice belt sander, and a comfy chair, I think I could make nice beads with al'ost any machine.
reid-o is offline   Reply With Quote
Old 05-08-2014, 11:41 PM   #62
reid-o
Member#: 103631
2004 STI
Gray
Originally Posted by reid-o View Post
I would decide if you want pulse features or not and then how thin matters. I've had good luck with everlast and have 2 now. I've made a few schedule 10 manifolds and doe pipes and piping. I would say you don't need pulse but it does help on edge welds like welding a sharp corner on thin gauge. Also the cheaper welders don't have really great low end performance like if you're doing sheet metal or 18-20 gauge stainless. Most will weld 16 gauge alum and stainless with no difference at all. Super thin and super thick depends. But you can easily do without it pulse. I use it sometimes to fusion weld thin stuff. I would say that any of the 220v tig machines from everlast or equivalent will be fine. I would spend the money on a good flexloc torch and the best bandsaw you can buy. Seriously. If you can get a big bandsaw and make accurate cuts without having to grind a lot, you don't need a super badass machine. If I had to do it over again I'd spend more money on a belt sander and a bigger bandsaw (or really good chop saw with good blades). Oh a good chair and welding table too. If I had a better bandsaw, a nice belt sander, and a comfy chair, I think I could make nice beads with al'ost any machine.
One thing about tig welders though is that they hold their resale value fairly well so if you do decide on a bile or red machine you can always,sell it later.
Old 05-13-2014, 09:11 AM   #63
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
How has this thing been holding up? Im considering squeezing the trigger on one.
Originally Posted by PARANOID56 View Post
so i had some extra money and figured with amazons return policy it would be worth to try.
picked up one of the Everlast power Itig 200 Dc tig welders. had a pulse and a bunch of other features that are nice and at around 600 bucks i can always return it.
i currently have the diversion 165 to compare it to. will be interesting. the only thing that bugs me is that it doesn't have a foot pedal (but either did my miller when i bought it)
will post up some reviews when it shows up tomorrow. (love amazon prime )
this guy
rexworx is online now   Reply With Quote
Old 06-05-2014, 02:43 AM   #64
PVASubie
Member#: 380690
2014 WRX
ehh.. response deleted
PVASubie is offline   Reply With Quote
Old 06-05-2014, 04:01 AM   #65
bbjones121
Member#: 253892
I love my Everlast 200DX. Gone through three 90cuft gas cylinders welding aluminum so far. I can adjust to get perfect bead. Stainless steel exhaust was easy well. 5 yr warranty. Read forums about miller and lincoln machines that are inverters, people are just planning on board replacements on those in a couple years. American welder manufacturers need to wake up and price competitively.
bbjones121 is offline   Reply With Quote
Old 06-06-2014, 12:13 PM   #66
PARANOID56
Member#: 22035
2014 Brocoma DCab
71 FJ40, 13 DRZ400SM
my machine is also still going strong. around 4 120cuft bottles though it. only doing mild and a few ss projects. i did pick up the foot pedal and i must say that thing is much nicer built then my miller one that came with my diversion machine
PARANOID56 is offline   Reply With Quote
Old 06-06-2014, 12:44 PM   #67
bbjones121
Member#: 253892
Everlast will negotiate with you also. When i bought mine they upgraded my regulator and foot pedal for no charge because they were out of stock for a week. I also got the tig torch with thumb adjustment for half cost.
Old 06-06-2014, 01:17 PM   #68
sidewayz
Member#: 5810
2001 S366 2.5RS
I use this unit. I have had it for about 4 years and it has been flawless. I also use it on a daily. aluminum, stainless etc etc etc I have welded it with this unit. Buy a nice torch and lens and you are set!
http://www.plasmatigandmig.com/html/inv200_ac_dc.html
sidewayz is offline   Reply With Quote
Old 06-09-2014, 08:34 PM   #69
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
I picked up their mig 140 and that thing is ****ing amazing. Betcha the TIG is too.
sackytar is offline   Reply With Quote
Old 06-09-2014, 10:15 PM   #70
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Love my eastwood, been doing more welding now that its warmer out. Lots of learning but I'm getting there!
Haven't had any issues with the machine
LeeC is offline   Reply With Quote
Old 07-01-2014, 02:25 AM   #71
zns3
Member#: 395081
The eastwood tig is actually pretty good.
zns3 is offline   Reply With Quote
Old 07-01-2014, 02:25 AM   #72
zns3
Member#: 395081
They are a hit or miss though.
Old 08-30-2014, 06:22 PM   #73
pawelzak98
Member#: 277662
2006 impreza wrx sti
UGM
hey guys i just purchased my eastwood for 699 they have a special going on
pawelzak98 is offline   Reply With Quote
Old 09-16-2014, 08:15 PM   #74
JulianT
Member#: 381077
200? TR42
Green
I've had my Eastwood 200 for about a year now. I've welded SS, mild steel and aluminum of various thickness with it. Works great. my neighbor is a master welder 30 years on the job for a chemical company welding some rather unique metals. he used it and was quite impressed with it. all the fittings are standard; I bought a non-eastwood mini touch and is working just fine. ... so, I recommend the 200.
JulianT is offline   Reply With Quote
Old 09-18-2014, 12:14 PM   #75
PARANOID56
Member#: 22035
2014 Brocoma DCab
anybody upgrade to a water cooled torch? been doing a lot of welding with mine and its getting old to have to stop and wait for the torch to cool down
