08-08-2017, 06:07 AM | #29576 | ||
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
I started looking into this deeper because I worried that if I left it any longer, I'd kill the compressor. So it appears that there *could* be a leak somewhere, but I don't know where. This leak, is causing some oil + refrigerant to leak making the system run dry on lubricant. Although this is just on reading, the signs are pointing to this.. So I plan to bring my car to my mechanic and have them check it out eventually..
08-08-2017, 06:09 AM | #29577 |
Member#: 301179
BAIC
08-08-2017, 07:40 PM | #29578 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
I searched and couldn't find anything about if our cars have a limited slip diff.
I found an old thread that didn't really come to a conclusion. I'm not sure how it would work with the independent brakes that the stability and traction control use. Although it makes me think it is an lsd because people claim it drifts really well with the stability control fuse removed. Anyone have any insight? |
08-08-2017, 08:05 PM | #29579 | |
Member#: 428450
Imprezas come with open diff. Stability button mainly works by removing power input when it detects wheel spin. Also with abs. I'm sure others will elaborate on this. |
08-09-2017, 02:22 AM | #29580 | |
Member#: 301179
BAIC
LSD is a mechanical unit that sends power to the wheel with less traction. Doesnt use brakes. TC is an electronic unit that sends power to the wheel with less traction. Uses brakes to manipulate an LSD. |
08-09-2017, 03:35 AM | #29581 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
5MT models have a true center LSD.
08-09-2017, 01:13 PM | #29582 |
Member#: 428450
08-09-2017, 01:24 PM | #29583 |
Member#: 319157
I don't think he specified, but yes, we have open front and rear.
VDC can activate the brakes in order to move power around as an LSD would. |
08-09-2017, 04:47 PM | #29584 |
Member#: 421858
Vehicle:2012 Impreza |
I'm getting 30-31mpg after adding octane booster and gumout regane complete, which is 10-30% naphtha, 10-30% PEA (the **** that matters), and the rest stuff we don't care about.
Unfortunately can't think of a way to check my IAM since my piece of crap phone died and the new one I'm using REFUSES to connect to the OBDII reader. |
08-10-2017, 06:27 PM | #29585 |
Member#: 421858
Got it to work today IAM is still 0.75. I call bull****. There's no way it's still having to retard the timing with octane booster in the tank.
08-18-2017, 10:40 PM | #29586 |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
anyone replace coolant yet? going to do mine in about 10 days. for some reason when I installed my block heater long ago I had to drop the exhaust, but according to the service manual I don't have to drop exhaust for coolant change??? i'm guessing I do again since i have the block heater installed and not just the factory plug but I do have the correct low profile block heater for the FB20
08-19-2017, 11:49 AM | #29587 |
Member#: 421858
Remember how you were ****ting on me for using green coolant? Yes, I changed it. Don't waste your time changing it unless you're going to do a flush at least twice with distilled water. Changing coolant without flushing is like leaving a third of your oil in when you do an oil change.
By the way, peak global lifetime is an acceptable replacement despite what Subaru will tell you. Still add the radweld "conditioner" **** though. |
08-19-2017, 03:03 PM | #29588 |
Member#: 314216
I'm using OEM coolant, i know if i drain it at the block i will get most of it out.... have 2 gallons on hand ready to go back in.
Just not sure if i have to drop the exhaust, i had to for block heater installation, just cant remember what exactly the clearance issue was |
08-19-2017, 03:43 PM | #29589 |
Member#: 421858
If you don't flush even once it doesn't matter how you drain the coolant because it'll **** up over the next change or two from the sludge that it'll turn into from having aged coolant in the system still.
08-19-2017, 04:38 PM | #29590 |
Member#: 314216
2012 Impreza thread
Considering how nice and blue it still is i dont think so. Not like flushing it is difficult either especially with the block drain......
No sense in arguing with you about this, i have never had doing it this way, people have issues when they dont change it |
08-19-2017, 04:58 PM | #29591 |
Member#: 421858
It's not flushing it if you're just running water through it with the drain open. An actual flush is filling it with distilled or at least purified water and running it through the heater core, then draining and filling it. Adding a bit of extra antifreeze to account for the water that's still there.
08-19-2017, 09:18 PM | #29592 |
Member#: 314216
You can run water through the heater core you know? And if you want to make sure all the water is out use compressed air... I'm not the slightest bit worried about the amount left over from draining and refilling it though. All oil isnt drained out in an oil change, nor is all the fluid in a transmission, this isnt much different as long as it hasnt been neglected which my car hasnt....
08-19-2017, 09:21 PM | #29593 |
Member#: 314216
Did learn today that my low oil light comes on at 1/2-2/3 qt low. 2nd time i have seen it in 140k worth of driving. First was me turning on key during an oil change so pretty much empty. Lol.
Down 1/2 qt in 4500 miles, so still 1qt in 9000. Mix of 0w30 and 0w20 does seem to use a bit more than just 0w20 |
08-19-2017, 10:11 PM | #29594 |
Member#: 421858
It probably started burning oil because it was crying at the thought of you not doing a proper flush.
08-20-2017, 12:19 PM | #29595 |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
So I'm on a very long road trip and my car started making a noise very recently (and suddenly) that sounds an awful lot like a throw out bearing going, and shows all the signs of being that. I'm at 85k. Anyone else run into this? Is it probably okay to do a couple of thousand highway miles to get home before I get it fixed?
08-20-2017, 01:39 PM | #29596 |
Member#: 421858
What do all of yours's (how do you even grammar this?) oil look like at 5-7k miles roughly? Mine is black as dirt so I'm sending in a sample to blackstone to see what's up. Could be nothing or could be engine falling apart.
08-20-2017, 01:51 PM | #29597 |
Member#: 425248
Vehicle:2015 Impreza Prem 4d Dark Grey Metallic |
As basic as this sounds, mine's pretty black coming out at about 6k. Nothing quantitative to provide . Definitely agree with the service interval of 6k per the manual for my '15.
08-20-2017, 02:05 PM | #29598 |
Member#: 421858
I was going to go 7500 but might change at 6000 if this analysis comes back ****.
08-20-2017, 03:29 PM | #29599 |
Member#: 314216
I still change every 12.5k....per blackstone and me running Amsoil Signature
08-20-2017, 05:41 PM | #29600 |
Member#: 421858
I ran Castrol Magnatec this round because it was almost free at AAP or Autozone (can't remember which), and I will go another change with that, then unless they have another round of really cheap 0w-20 Magnatec I'll start buying Castrol Edge since it's essentially the same except slightly better in some ways I guess.
I doubt the 0w-20 Magnatec is going to go on sale at any stores this winter since none of them seem to even carry it anymore. It's never been in stock at the few places that still have a shelf space for it any time in the last 7 months. |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
