Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 01-25-2002, 12:03 PM   #1
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Default Need a new floor jack, what and where can i buy?
I need a new hydrolic floor jack as my last one (old Sears model) has blown its seals and won't hold any fluid for more than a day. What and Where have some of you bought lately? I'm looking for brands, online sites and prices. I'm looking for the larger ~2 ton units that has a relatively low (relative to the typical Sears jacks) saddle height. I've heard Norco brand is good and fairly inexpensive.
Cosworth is offline   Reply With Quote
Old 01-25-2002, 02:29 PM   #2
FastPorsche
Member#: 11125
2000 Impreza 2.5 RS
Silverthorne
Get a Lincon, you will find these on line at good prices. If you can, I would get the Snap-on, it has a nice low profile to get under low cars and the pump action on it is great, not like a sears or the orange one that you pump 15 times to get it up to the car. The snap on is more like a nascar jack some thing like only 10 pumps to full 21". There about 350.00 worth every penny There esentialy the same jack but the Snap on guy is easer to get a hold of than Lincon. Make sure you get one of the ones not made in Aisa there are three modles, the one from Aisa and leaks out of the box but the other two are probably the best floor jacks in the world. IMHO
FastPorsche is offline   Reply With Quote
Old 01-25-2002, 03:49 PM   #3
jamz
Member#: 8725
2013 Black Company
Annalist
$350??? Holy shmazoli, I suppose if you're into your tools it's worth it, but I'll pump a few extra times and use my $20.00 one.
Of course, I'm only under my car once a week or so, not every day . Got mine from WalMart. Seems to be holding up fine, and if it dies in a year, then another $20.00 for a jack.
jamz is offline   Reply With Quote
Old 01-25-2002, 07:39 PM   #4
AndrewWRX
Member#: 13191
Default Lot's of options on jacks.
If it's a Sears jack I thought they are suppose to replace it if it falls apart?
I have a Craftsman jack that comes with a plastic case, good for taking to the track. But I do have to pump it quite a bit to get the car up. It's a 3.5 ton jack and 2 jack stands was around $50.
I will eventually get a better one from Sears for around $80 which felt real nice when I tried it in the store.
For a money is no object jack check out Griotsgarage.com and look at the all aluminum race jack they have. Some guy at one of the track events had it for his Ferrari. it was light and beutifull to look at and use!
I am still not sure about the jacking points on the WRX anybody know which spots are safe other than where the stock jack points are?
AndrewWRX is offline   Reply With Quote
Old 01-25-2002, 10:29 PM   #5
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
OMG! That Griot's Garage catalog is like porno! I can't believe some of the stuff they have in that thing. I want everything.
Kevin
gtguy is offline   Reply With Quote
Old 01-25-2002, 10:45 PM   #6
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Griot's Garage rocks! I don't know where they got my address, but they sent ma a catalog and I was like " okay, I'll take that and that and that.........and......etc!" They have a great hydraulic floor jack in there that will lift lowered cars and everything. They have all the good stuff. It is expensive though!
Fred Zaplitny is offline   Reply With Quote
Old 01-25-2002, 10:53 PM   #7
STORER
Member#: 2253
2000 2.5 RS
Red
I also purchase the Sears floor jack in the plastic case. Best bang for the buck. Don't forget to get jack stands.
Steve
STORER is offline   Reply With Quote
Old 01-26-2002, 02:57 AM   #8
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
I looked at some of these and all i can saw is WHEW! $400+ for a jack and you can kiss my jackhandle...
I also looked at the snapon and it looks identical to the Norco for less than half! The norco even hass a lower saddle height.
Norco:
Lincoln:
Snapon:
Old 01-26-2002, 08:45 AM   #9
GPH993
Member#: 10830
Talking Jack it up
Andrew,
If you want to lift both rears up, put a block of wood between
the floor jack pad and the rear diff protector which is a nice flat
plate. Once you have your jackstands in place, the front can be
lifted by placing a block of wood between the floor jack pad and
the front crossmember. It is just behind the oil pan and has 2
bolts in it. If you use soft wood, the bolt heads just indent the wood and you have a wider contact patch. Place your jackstands
at the front factory jack points and your up on all four. Be careful
to not bend your pinch-welds at the jack points. If your jackstands will not span the seam, place a small block of wood just inboard of the seam to rest the car on.
GPH993 is offline   Reply With Quote
Old 01-27-2002, 10:08 AM   #10
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
Here's my pick for which jack I'd buy. Nice & low for you with lowered cars. > http://www.geocities.com/Eureka/Vaul...ulicjacks.html
Chuck
Crashton is offline   Reply With Quote
Old 01-27-2002, 10:17 AM   #11
bbbradley
Member#: 7715
2000 Miata
BRG-ish
Chuck
From that site:
"Great maneuverability, due to rounded wheels"
They have to specify rounded wheels??? What other type of wheels are there?
Looks like a good jack, albeit a bit pricey.
/bill
bbbradley is offline   Reply With Quote
Old 01-27-2002, 09:06 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
Old 01-28-2002, 10:56 AM   #13
WeRX
Member#: 3652
1989 Honda Pirate
Type RRRRRR
Those are some pretty nices jacks and all but....
http://www.grainger.com/Grainger/pro...mId=1611718736
for $3,032.00 this one must be the best.
WeRX is offline   Reply With Quote
Old 01-28-2002, 08:05 PM   #14
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Geez!
Mike
MagicMT is offline   Reply With Quote
Old 01-29-2002, 12:40 AM   #15
ShaftnoBalls
Guest
Member#:
3k for a jack! i went to Kragen and got a jack and 2 stands for 40 dollars works fine for me
Old 01-29-2002, 08:00 PM   #16
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Yeah, but will your jack lift 10 tons?!?!
driggity is offline   Reply With Quote
Old 01-29-2002, 11:16 PM   #17
pio!pio!
Member#: 4190
2008 Impreza WRX STi
What about those built in jacks like in JGTC / DTM machines?
Where they attach a hose to the back and i pushes compresses nitrogen gas into it which pushes 4 beams down from the bottom of the car and jacks it up?
HOW MUCH FOR THAT? Maybe have the input nozzle in the trunk so no weird holes. Maybe have the compresses nitrogen as a tank in the trunk so you just press a button in the car to activate the system!
Am I nuts?
How much would this setup cost?
pio!pio! is offline   Reply With Quote
Where can I buy a decent jack + stands leon Mid Atlantic Impreza Club -- MAIC 7 01-06-2005 02:37 PM
What are these things called and where can I buy some? Tobey Interior & Exterior Modification 19 10-30-2003 01:06 PM
Need inexpensive rims and winter tires for STI, what and where to buy ? jaytone STi Forum Archive 17 09-06-2003 06:45 PM
quick: where can I buy a talkabout in houston? what kinna stores have em? and jmott Texas Impreza Club Forum -- TXIC 2 03-22-2002 05:16 PM
