Welcome to the North American Subaru Impreza Owners Club Monday April 15, 2024
Old 02-07-2006, 12:46 PM   #1
RonD922
Member#: 106957
Default Will Koni Yellows on Stock springs lower my car..
Hello,
I have an 02 Sedan and I am adding Koni Yellows.. I am looking for something more aggressive, as I am young and like to AutoX, Trackdays and in general drive aggressively..
I am adding Koni Yellows and Progressive Front Sway, and I am wondering if anyone has done a similiar setup with stock springs..
I am looking to stay in the SCCA Stock class, so I can only do Shocks, Front Sway (NO Endlinks), Brake Pads, Cage, Harnesses, Tires.. With this in mind, please don't tell me to get coilovers and a big turbo, 17 inch rims, etc..
Also, any thoughts on the best Brake pads out there?? I was thinking Hawk, but I had Pagid Blues on my M3 and was quite impressed..
Is 22m adj Front Sway going to make a difference??
Thanks,
Ron
863-221-8534
RonD922 is offline   Reply With Quote
Old 02-07-2006, 01:12 PM   #2
flyboymike
Member#: 83765
2018 WRX PR
WR Blue Pearl
For autocross, it's pretty tough to fade the stock brakes. I did it once at a school where I got a crazy number of runs, but that's about it. Since the FSB is the only way you're allowed to limit body roll, I'd go for the biggest one I could find. The Stranosports hollow 32 mm swaybar might fit sedans. Otherwise, Whiteline has one that goes up to 27 mm.
flyboymike is offline   Reply With Quote
Old 02-07-2006, 03:48 PM   #3
ericd735i
Member#: 98802
2005 9-2x
I'm assuming you mean the Koni yellow single-adjustable inserts. No, they will not lower your car.
I just put them in my car with stock springs, and they do help tame the out of control body roll that you get with the stock shocks. I haven't run an auto-x yet, but I'm running STX and also have Cobb F & R sways.
ericd735i is offline   Reply With Quote
Old 02-07-2006, 04:03 PM   #4
VpointVick
Member#: 93193
'03 325iT
Mysticblau
The Strano FSB does indeed fit WRX sedans.
VpointVick is offline   Reply With Quote
Old 02-07-2006, 04:10 PM   #5
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Unless I'm badly mistaken, in Stock, you're allowed to change front sway bar and attaching hardware, which includes endlinks, so there's no reason why you could change them if you wanted.
The Strano bar uses completely different endlinks from stock.
Old 06-19-2006, 04:50 PM   #6
SharkWagon
Member#: 99788
1977 Chevrolet
Corvette
Front endlinks are open in Stock classes, they are basiclly considered part of the fsb, thats why you can't swap the rear endlinks.
SharkWagon is offline   Reply With Quote
Old 06-19-2006, 05:26 PM   #7
Arnie
Member#: 1725
2002 Subaru Forester
SG silver
The koni yellows, Whiteline 27mm front bar, endlinks, aggressive front alignment and some r-compounds and your are good to go!
Arnie is offline   Reply With Quote
Old 06-19-2006, 06:30 PM   #8
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
You're.
And yes, Arnie is on the money. There are days I seriously wish for some stock class understeer and sticky tires as it would just be so dang much simpler.
-Biggly
DrBiggly is offline   Reply With Quote
Old 06-19-2006, 06:33 PM   #9
Arnie
Member#: 1725
SG silver
D'oh!
or is it their, there or they're?!?!
Old 06-19-2006, 07:41 PM   #10
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
They are=They're
hossak8 is offline   Reply With Quote
Old 06-19-2006, 07:41 PM   #11
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
D'oh!
Same answer I give the suspension questions: It depends.
-Biggly
Old 06-20-2006, 11:53 AM   #12
Arnie
Member#: 1725
SG silver
Its all good, I'm actually on top of my grammar, I know the proper uses of the above.
Old 06-20-2006, 02:14 PM   #13
Canonshooter
Member#: 103479
'07 Forester XT
Newport Pearl Blue
It was simply an errant "r" on the end of "you." Must be a common typo - I do that all the time too (or is it two? Or to?).
Yes, me too.
Canonshooter is offline   Reply With Quote
Old 06-20-2006, 02:17 PM   #14
Arnie
Member#: 1725
SG silver
yup, didn't check my spelling and typed that extra R.
so what the hell was the topic in this thread?
Old 06-20-2006, 02:22 PM   #15
Canonshooter
Member#: 103479
'07 Forester XT
Newport Pearl Blue
"Does bad grammar cause blown struts?"
Old 06-20-2006, 05:47 PM   #16
SharkWagon
Member#: 99788
1977 Chevrolet
Corvette
I think it's about the Type R
Old 06-20-2006, 06:25 PM   #17
Arnie
Member#: 1725
SG silver
Oh yes, you mean the Koni YeRRow?
FS Stock Springs off my car zerospreza 1993 - 2001 Impreza Specific Parts 1 03-21-2010 01:59 AM
WTS: Koni yellows, GC coilover springs, Cusco Camber plates F+R!!!!!!!! JRsRdWRX Suspension/Brakes/Handling 9 07-11-2007 11:40 AM
Will 05 STi springs lower my 05 WRX? wrxwhip Newbies & FAQs 4 06-02-2006 06:23 PM
will 98RS springs lower my 97L ? IllNastyImpreza Brakes, Steering & Suspension 2 09-02-2005 01:35 AM
Prodrives Springs lowered my car 1.75" MissMyStook Brakes, Steering & Suspension 4 09-29-2002 11:02 PM
