09-24-2006, 10:06 PM | #1 |
Member#: 50193
Vehicle:1999 Rubasu Ziprema Silverthorne |
HELP! What is this? How did it happen? How do I fix it?
I'll first start by saying that my vocabulary surrounding the transmission and driveline is weak. To make up for that I have provided pictures.
I drive a 1999 2.5RS. I was underneath my car checking for exhaust leaks and noticed this brown ooze coming out from where the axle inserts into the transmission. I don't know the exact words to describe it. The axle pictured is my driver side. I don't see any tears on my CV boot, or on the green thing (?). Here it is from directly underneath it: Here's an offset underneath shot: Here's the best I could do for a side shot: And a little closer: What is it? Is it normal for this to happen (I have 110k)? Is this something I can fix on my own w/ hand tools? If so, how? What parts will I need to replace? If not, what's the average labor and parts cost. Thanks for being patient. I'd appreciate all the help I can get. -al
09-24-2006, 10:09 PM | #2 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Not normal. See wrinkleboi's recent thread on replacing axle seals.
09-24-2006, 10:29 PM | #3 |
Member#: 1714
RMIC
Vehicle:1999 RS-T COUPE Black |
this is not an axle seal issue, but rather the inner cup of the DOJ leaking grease out. there is a different grease available from subaru as well as an additional seal that can be installed on the end of the DOJ (dual offset joint) between the doj & the axle seal to repair this problem. see your local dealership to obtain these parts--i can get you the part #'s if you need, but i won't be back @ my shop until tues. hope this helps.
09-24-2006, 10:42 PM | #4 |
Member#: 50193
Subetek,
Thanks! I would really appreciate it if you could provide me w/ the part #'s when you get a chance. In the meantime I will start reading up on the dual offset joint (DOJ). And lastly, is this something that an amateur can do on his own? Thanks, -al |
09-24-2006, 10:43 PM | #5 |
Top Scoob 006
Member#: 14424
South East
Vehicle:BugI w/ 07 STi Swap www.TriStateTuners.com |
subetek! remember me?
and yeah i sure hope thats not tranny fluid, although from your message to me you should change it!! its supposed to be on 30k intervals i believe on your model as well, dont neglect maintenence if you want your car to last. |
09-24-2006, 10:50 PM | #6 |
Member#: 1714
RMIC
Whazzup! You ever coming back out west? I saw your STIThis thread-what a hoot!
What is the best wideband setup, and where do you have it displayed? | singincanary | Tri-State Area Forum | 9 | 01-23-2008 12:11 AM |
What is this and why am I leaking oil out of it? | wizard12 | Off-Topic | 24 | 06-13-2007 10:03 PM |
What is this +1 thing that you guys do? | tEkkGOD | Texas Impreza Club Forum -- TXIC | 10 | 04-14-2004 12:23 PM |
Help! What is this thing on my dogs paw??? | Jessie James | Off-Topic | 8 | 03-15-2004 11:17 PM |
HELP! What is this gunk in my engine bay? PIC. | AngryPuppet | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 10-26-2002 09:44 PM |
