#1 |
Member#: 15654
Vehicle:2002 WRX wagon Black |
![]() I knew there had to be a way to do it....
I removed the tray under the hatch flap and made a box that uses the tray space and the wheel well of the spare tire (yes, the spare is under the box). The box is about .35 ft^3 which is well below the recommended enclosure size for the 12" sub that I installed but I figured I would give it a try. The sub sounds awesome!!! So, what do ya think?
#2 |
Member#: 15654
![]() another shot...
#3 |
Member#: 15599
![]() This is EXACTLY what I am in the process of doing!!! Great minds think alike...
Just for confirmation, can you send me a few dimensions? Like the diameter of the box, the height of the top part, and the height from the bottom of the large top to the bottom of the box. .35 is perfect for my sub (Image Dynamics IDQ10 DVC) so this solution is perfect. Nice job! |
#4 |
Member#: 15654
![]() I used 1/2" MDF for all pieces. The box was actually a little high so I had to take the braces out of the hatch lid (not fun) in order to get the hatch lid to close all the way down. Here are the measurements for all pieces...
Diameter of the circle - 13 1/4" Height of circle pieces - 3 7/8" Length of the top - 22 1/2" Length of the bottom - 27" Length of the left side - 22 1/2" Length of the right side - 23" Height of the top side pieces - 1 3/8" (should be less to let hatch lid close tight) |
#5 |
Guest
Member#:
![]() As an installer, and soon-to-be wrx owner, I'd like to offer a suggestion. If you aren't running much power, small enclosure size will work, just know you're not allowing the woofer to perform the way it was designed...meaning performance isn't close to projected from factory ratings, and you'll go through subs faster...alot faster. If you're hell-bent on 12's, be my guest, but in something like that, a 10" properly-built volume-matched box will hit alot better. Any other questions...you can email me.
[email protected] |
#6 |
Member#: 14320
Vehicle:2002 WRX Sport Wagon |
![]() What if you get a flat tire?
#7 |
Member#: 15654
![]() Lawndart:
The box was made to fit inside the spare tire well. So, the spare tire is still there under the box. I had to replace the factory bolt used to hold down the spare with a regular hex bolt so the box could go down inside the wheel furter. So if I get a flat, I just have to lift the sub box out and set it aside as I get out the spare. |
#8 |
Member#: 12541
Vehicle:02 WRX Wagon Blue |
![]() That looks sweet! How much power are you running to the sub? Do the removed trays come out intact (i.e. for resale/trade in)?
I'm running a 10 with 130 watts in a sealed box and it sounds pretty good, but it sure would be nice to have all the room back. |
#9 |
Member#: 15654
![]() shawndoggy:
The tray came out totally intact. I just have to find a place to store the silly thing. There are a total of 4 storage compartments in the back, but I only had to remove the tray for the main big compartment. I'm running a Rockford 500W 4-channel with the front channels running the front doors and the rear channels bridged running the sub. The sub is a DVC which I hooked in series to give me an 8 ohm load (didn't want to risk it at 2 ohms). I'm not really sure how much power I'm running to the sub. All I know is that it sounds pretty nice. |
#10 |
Member#: 15421
Vehicle:1996 Formula Red |
![]() if you think it sounds good now, you should hear it in a box that's the correct size. .35cu ft. is VERY small for a 12" sub. You need more like 1cubic foot. IMO you should get a 10" sub instead. even with a 10" sub most require more than .35.
BTW, is that .35 before or after driver displacment? |
#11 |
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
![]() wow.....NICE JOB!!!!!
I made one to fit the sedan, but I had to lose my spare. |
#12 | |
Guest
Member#:
![]() Quote:
![]() ...just remember drifting with a spare sucks big time...I wouldn't recommend it. ![]() |
#13 | |
Guest
Member#:
![]() Quote:
I give you props for working it out, but as someone who's "been there, blown that" (from testing new box designs, and extreme volume), I would rework the measurements. It might sound ok now, but you get that into something around 1 cu. in. and you'll double volume and sound quality, as well as the life of the woofer itself. Not bashing...just trying to give advice...buying woofers all the time sucks, and I get the discount. ![]() |
#14 |
Member#: 15654
![]() 0.35 ft^3 is a rough guess on the volume before the driver placement. Its probably closer to 0.20 with the driver. I know this is a ridiculously small enclosure for at 12" but I got the Punch HE2 for about $80 so I thought I would try it out. If I were to go according to spec, I should have an 8" which I might try next if the 12" fails me. I was just shooting for better bass than the crappy Subaru sub.
My original idea was to pull out all the storage compartments from the floor and make a box that used all of that space which would probably get me around 1 ft^3 but then I would have to recarpet everything. I'd like to see someone try it though. |
#15 | |
Guest
Member#:
![]() Quote:
#16 |
Member#: 14450
NESIC
Vehicle:04 S4 88 BMW 325 iX |
#17 |
Member#: 10540
Vehicle:2002 WRX sedan silver |
![]() Nice box, unfortunately the sedan doesnt give up much depth with the spare still in place. bsbg, your pics gave me the idea to try and make the bottom part of my sub enclosure. Its a combination of both of yours, the glassed bottom and the boxed off top portion for added volume. I needed 1-1.5cuft for the 12" driver and ended up with 1.25 after sub displacement. To make everything nice and flush the floor will be raised a couple of inches and will allow the amps to be countersunk. The sub part will be on hinges to get to the spare when all is finished. Its a work in progress, hopefully the wifey will learn me how to post pics. The glassing part has been a learning experience but after a couple of layers I feel I can glass just about anything
#18 |
Member#: 15599
![]() Well, I had a very similiar idea to this, but used nixima'a awesome idea to enhance mine a bit. Plus I threw on some carpet. I just got it done. Here it is. It is using an Image Dynamics IDQ10 DVC with 4 ohm voicecoils to give the amp a 2 ohm load. And let me tell you, this is one nice sub. Small enclosure volume and has better bass extension that my old system. HIGHLY recommended. Thanks again for the great idea nixima!! Plus, with the cover down it is totally hidden. The punchiness of it suffers with the cover down, but the deep bass is still there. I figure if I want better punch, I'll pull the vinyl cover closed and hang the cover open.
Plus, I added several layers of Dynamat Extreme to the floor of the hatch. I don't hear ANY rattles. And even better, the Dynamat only cost me $1 from Sounddomain.com. Now to get my ID seperates into the doors and my system will be complete. All for about $200 more that the cost of the upgraded system and it sounds WAY better. |
#19 |
Member#: 17851
![]() How much Dynamat you get?? and how you get it so cheap??
thx. |
#20 |
Member#: 15599
![]() When I bought all my stuff from sounddomain, they were running a deal where you get the Dynamat Extreme trunk kit for $1 if you bought an Image Dynamics sub, plus I got a Dynamat Extreme door kit for each pair of Image Dynamics door speakers I bought. So, I got a Dynamat Extreme trucnk kit and two Dynamat Extreme door kits for $3.
See here: Image Dynamics Deal and Image Dynamics Door Deal The only downside is that the component speakers are still on backorder. Oh well...it will be worth it. |
#21 |
Member#: 18150
Vehicle:2002 WRX Wagon EJ207 Velocity Red, Liberal kit |
![]() I installed a powered 6.5" Bazooka tube in my wagon. it takes up a little more space thean your sub, but I use my storage space were you mounted yours. And it sounds great.
#22 |
Member#: 15654
![]() 2000vfr800:
Looks great!!! I'm just wondering if you had to take the two supports out of the hatch cover? To me that was about the most difficult thing of the whole process. They really glue the carpet down on the edges. |
#23 |
Member#: 15599
![]() Nope... Thanks to your warning/advice, I made the box shallow enough to not hit the supports. I do think I need to move the hanger hook though...no biggie.
Thanks again for the great idea and suggestions. |
#24 |
Member#: 17812
Vehicle:2002 WRX Wagon silver |
![]() Hey 200vfr800:
Great design! Have you considered just taking off the carpet on your enclosure, and mounting on another piece of carpeted wood on top that would take the place of the hatch altogether? You would no longer have muffled bass problems. Good work though |
#25 |
Member#: 15599
![]() I thought about it, nd will probably do something, sometime, but for now it's plenty good.
FS:(NY) Custom Sub Box For Trunk | steve2k1116 | Interior/Dressup/Audio & Security | 11 | 08-17-2009 05:14 PM |
Custom Sub box for 08 sedan? | Calum W. | Car Audio, Video & Security | 2 | 06-10-2008 07:59 PM |
WTB: Dual 8" custom sub boxes for Impreza coupe | Danny Boy | NESIC Private Classifieds | 5 | 01-01-2007 03:09 PM |
wtb custom sub box for sti | dwaynesti | VIC Private Classifieds | 3 | 09-19-2006 12:45 AM |
FS JL Audio 127 with custom sub box for STi trunk | wrx what | Mid Atlantic Impreza Club -- MAIC | 9 | 01-03-2006 10:51 AM |
